Old wall furnace
by Jarlaxle
08/26/16 02:55 PM
automatic side folding mirror squeak
by Grambo
08/26/16 02:11 PM
Anybody own a new Mazda 6?
by AirgunSavant
08/26/16 01:58 PM
Do Employees Of Car Companies Get New Cars Cheap ?
by crazyoildude
08/26/16 01:54 PM
Amsoil SVG 75W90, 50K, 04 Duramax 196K
by dhellman12
08/26/16 01:53 PM
When an orifice is needed & when it is not (long)
by ryaneirich
08/26/16 01:38 PM
UT-Austin Response to CC
by sleddriver
08/26/16 01:36 PM
Grease darkening quickly on bicycle bearings
by Wheel
08/26/16 12:54 PM
Just replaced valve cover gasket
by JeepWJ19
08/26/16 11:48 AM
You Got A Merv People!
by AirgunSavant
08/26/16 11:17 AM
Total Quartz 9000 Energy 0W30 - Synthetic or not?
by Seweryn
08/26/16 10:32 AM
Options for Cadillac DTS with the Northstar Leak
by Ddub
08/26/16 10:21 AM
rgmbedzi3, wildkid2008, dccode, dromonk, sledhead1
58930 Registered Users
96 registered (1JZ_E46, adamrc, Al, AirgunSavant, AlaskaMike, 2015_PSD, 10 invisible), 1760 Guests and 33 Spiders online.
58930 Members
66 Forums
253588 Topics
#2247789 - 04/30/11 02:40 PM Oil leak stopping additives??
Lead Shoes Offline
Loc: Mn
So I have oil leaking from what I believe to be my rear main on my Honda Civic, I used UV dye and found oil coming out of my transmission bell housing gasket, and my clutch slips some days and not others probably because it has oil on it.. and the rear main is about the only way it would get in there. Its not a bad leak, I lose maybe a quart every 1500 miles, I was wondering do oil leak stopping additives work? and which one would be best for my application?
1992 BMW 325i 183k
Castrol 0w40/Mahle
#2247800 - 04/30/11 02:56 PM Re: Oil leak stopping additives?? [Re: Lead Shoes]
Towncivilian Offline
Loc: Florida, USA
Stop leak additives are generally just oil thickeners which just mask the problem. Some have had good experiences with Valvoline Maxlife oil, which contains seal conditioners to slow or stop leaks.
2001.5 Pathfinder SE 3.5L A/T 2WD - ML NG 5W-30/PL14610
2007 Altima S - PU 5W-30/M1-110
2009 G5 - PU 5W-30/XG9018
2012 G37 S - ST 5W-30/PL14612
#2247805 - 04/30/11 03:08 PM Re: Oil leak stopping additives?? [Re: Towncivilian]
rshunter Offline
Loc: Ohio,USA
+1
Do a MaxLife oil change and let it do its thing. Your Civic is the perfect example of a vehicle that would benefit from a HM oil, with 200K miles on the clock.
'99 Eurovan GLS,'06 Raider DuroCross V8 Ext,'08 GTI DSG,'14 PriusPLUS
#2247806 - 04/30/11 03:10 PM Re: Oil leak stopping additives?? [Re: Lead Shoes]
mikered30 Offline
Loc: PA
ATP re-seal works ok.
#2247812 - 04/30/11 03:25 PM Re: Oil leak stopping additives?? [Re: Lead Shoes]
mongo161 Offline
Loc: Coney Island, NY
Maybe just repair the leak and change the gasket.
I get by with a little help from my friends....listen with your eyes....it's the ONLY way to believe what you hear...
#2247816 - 04/30/11 03:30 PM Re: Oil leak stopping additives?? [Re: Lead Shoes]
Lead Shoes Offline
Loc: Mn
Well I'm replacing the clutch, pressure plate, flywheel, throwout bearing, and input shaft bearing this summer I was just looking for a band aid that worked..
Edited by Brenden (04/30/11 03:34 PM)
1992 BMW 325i 183k
Castrol 0w40/Mahle
#2247833 - 04/30/11 03:58 PM Re: Oil leak stopping additives?? [Re: Lead Shoes]
Bluestream Offline
Loc: Waterloo, ON
Try one of the high mileage oils' they have seal swell agents in them.
2000 Cavalier 2.2 A4
2000 VW Beetle 1.8T M5
2000 Ford Explorer 4.0 4X4
1991 BMW 735iL
"A fool and his money are soon parted" - Thomas Tusser
#2247885 - 04/30/11 05:44 PM Re: Oil leak stopping additives?? [Re: Lead Shoes]
glum Offline
Loc: Charlotte, NC
No, they don't have "seal swell agents" in them.
Wish I could say it's been nice, BITOG.
#2248329 - 05/01/11 07:58 AM Re: Oil leak stopping additives?? [Re: glum]
Bluestream Offline
Loc: Waterloo, ON
Ya, they do.
From Valvoline Max Life Synthetic blend bottle:
"Seal conditioners help reduce oil consumption and leaks"
From QS Higher milage engine oil bottle:
"Reduces oil consuption through worn or leaking seals"
1991 BMW 735iL
#2248335 - 05/01/11 08:05 AM Re: Oil leak stopping additives?? [Re: Lead Shoes]
demarpaint Offline
Loc: NY
Read up on this. It is for leaks as well as oil burning, the company has a solid reputation too. It's worth looking into.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2221694#Post2221694
God Bless Our Troops
#2248419 - 05/01/11 10:38 AM Re: Oil leak stopping additives?? [Re: Lead Shoes]
ltslimjim Offline
Loc: WatUpDoc
^I agree. +1. Add a bottle of that as per the instructions with a good conventional for a trial run.
92 Civic Hatch (stolen frown RIP)
07 Honda Fit Sport (A/T) WELCOME thumbsup
#2248724 - 05/01/11 04:57 PM Re: Oil leak stopping additives?? [Re: Lead Shoes]
EricF Offline
Loc: SF Bay Area
Definetely try Re-Seal by ATP.. it's not a thickener and I have real world results from it.
1993 Ford Ranger XLT 4.0L 4x4 (240k) 5W-30 Synpower
2006 Saturn Relay-3 3.5L (85k) 5W-30 Synpower
2012 Ford Fusion SE 2.5L (39k) 5W20 M/C Semi Syn
#2249254 - 05/02/11 10:48 AM Re: Oil leak stopping additives?? [Re: Lead Shoes]
adamrc Online   content
Loc: Nashville, TN
The only success I've had with any stop leak product is Lubro Moly Oil Saver. I highly recommend it.
#2249255 - 05/02/11 10:49 AM Re: Oil leak stopping additives?? [Re: Lead Shoes]
Nick R Offline
Loc: Albany, NY
1. Mix some random ingredients together.
2. Call it oil additive
3. ????
4. PROFIT
2013 Ford Focus SE 2.0L/73,000miles/Motorcraft Blend 5W-20/FL-400S
#2249535 - 05/02/11 04:37 PM Re: Oil leak stopping additives?? [Re: Lead Shoes]
Lead Shoes Offline
Loc: Mn
Im going with the Lubro Moly Oil saver, see what it gets me, its the only one I really found with a solid reputation, ill post back after the suggest 1k miles for it to do its thing.
1992 BMW 325i 183k
Castrol 0w40/Mahle
