Grinding Granite Yourself?
by coopns
05/25/13 07:58 PM
NSS Labs - Browser Security Comparative Analysis
by ZeeOSix
05/25/13 07:18 PM
How old are these windows?
by Chris142
05/25/13 06:40 PM
Getting rid of old cell phones
by JHZR2
05/25/13 06:26 PM
Where does the term "weight" come from?
by tom slick
05/25/13 06:19 PM
Yet Another WM Clearance on Oil
by Greg L
05/25/13 06:03 PM
hydrostatic woes
by ram_man
05/25/13 06:00 PM
Looking for Longer Fram Ultra Oil Filter
by 147_Grain
05/25/13 05:38 PM
Autozone clearance
by docsteveg
05/25/13 04:29 PM
any advantage of 10W-30 over 5W-30 or 0W-30?
by LScowboy
05/25/13 03:39 PM
1985 ford f150 5 liter keeps shorting coil....help
by GoHeels1981
05/25/13 03:09 PM
Craiglist Selling Tips?
by Rock_Hudstone
05/25/13 03:07 PM
goodolboy, Rick_Kean, patmoetighe, ohbehave, Maritimer
45560 Registered Users
127 registered (2010_FX4, 05LGTLtd, acbent, AandPDan, Alcibiades, 16 invisible), 1427 Guests and 233 Spiders online.
45560 Members
64 Forums
193951 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#2241518 - 04/23/11 10:48 PM Briggs & Stratton Spark Plug Wire
bakechad Offline
Loc: Chicagoland
I have a 7 year old Troy-bilt push mower with a B&S Quantum 6.5 HP motor.
I just did my annual maintenance which includes: new spark plug, air filter, oil change, lubrication, change to freshly sharpened blade & clean the underside of the deck.
All went well and it started on the first pull as usual.
When I reconnected the spark plug wire, I noticed that it was full of cracks. No big deal, I figured I'd pick one up at the small engine shop when I drop my spare blade off for sharpening.
I pulled out my B&S service book and looked at the diagrams. As far as I can tell, I cannot replace the spark plug wire without replacing the entire ignition armature. Is this correct?
Thanks
Chad
2006 Honda CR-V - Valvoline Synthetic 5w20
2006 Dodge Caravan (2.4L) - NextGen 5w30
#2241542 - 04/23/11 11:22 PM Re: Briggs & Stratton Spark Plug Wire [Re: bakechad]
mechjames Offline
Loc: Richmond, BC, Canada
That is correct.
If the cracks are bad, you can wrap the wire with electrical tape.
Replacement armatures should be between $40 and $60 if you need to replace it.
86 Ford Mustang 5.0L 170km - MaxLife 5w30
96 Ford F250 7.3L Diesel 240km - Rotella 15w40
#2241648 - 04/24/11 02:21 AM Re: Briggs & Stratton Spark Plug Wire [Re: bakechad]
expat Offline
Loc: Canada
Heat shrink tubing works very well.
#2241676 - 04/24/11 04:51 AM Re: Briggs & Stratton Spark Plug Wire [Re: bakechad]
Texan4Life Offline
Loc: Texas
+1 electrical tap or heat shrink tubing. unless you want to pony up for a new ignition coil.
The pics of the mouse nest i found under my engines cover, I had about an inch of wire that was nibbled on. It hadn't exposed the wire yet, just the insulation under the rubber. After looking up how much a new coil was I put electric tape on it since it was still working fine.
2005 Dodge Ram 1500, 5.7L
[Current Fill: Castrol Edge 0w-20][Napa Platinum]
#2243351 - 04/25/11 10:08 PM Re: Briggs & Stratton Spark Plug Wire [Re: bakechad]
RS700L Offline
Loc: Pennsylvania
As long as it works, keep using it. I would tape up the chewed part though. See how long it lasts.
1997 Ford Expedition, 5.4L
1968 Wheel Horse Raider 9ish
Allis Chalmers C
“I started out with nothing and have some of it left.”
#2243376 - 04/25/11 10:30 PM Re: Briggs & Stratton Spark Plug Wire [Re: bakechad]
engineerscott Offline
Loc: Southeast USA
Is the end of that plug wire soldered to the coil or is it some kind of crimped connection? If it is soldered you can probably replace it without too much trouble.
Like everyone said, electrical tape or heatshrink will work as well. If you do heatshrink I'd slip it over the wire and connect it to the plug and only then shrink it down with a heat gun. If you shrink it while the plug wire is straightened you might find it difficult to make that fairly tight radius bend once the shrink cools.
