Do I need a better tire for PNW trip?
by The_Eric
Yesterday at 11:51 PM
Turtle Beach PC headset hack
by asand1
Yesterday at 11:34 PM
Lengthy question for the seasoned oil gurus
by Jetstreamz06
Yesterday at 11:10 PM
Jeep Cherokee Heater Valve - Brands?
by Nick1994
Yesterday at 11:00 PM
Hyundai Entourage/Kia Sedona minivans
by Number_35
Yesterday at 10:41 PM
Oil in air breather tubing
by Nissan101
Yesterday at 10:06 PM
Dust caps needed to protect wheel bearings?
by Drew99GT
Yesterday at 09:51 PM
2014 Mazda CX5 SkyActiv
by Matt_V
Yesterday at 09:38 PM
getting rid of pwc with intermittent problem?
by motor_oil_madman
Yesterday at 08:36 PM
Difference between silicone caulking ?
by Merkava_4
Yesterday at 06:15 PM
The Top Dexos2 Oil Available in the USA is What?
by Best F100
Yesterday at 05:24 PM
Virgin Puro L14006 [Cut open]
by Run
Yesterday at 05:13 PM
kevinstoyhauler, jimx1169, W9HDG, LloydChristmass, dodge96
58019 Registered Users
25 registered (AdRock, dohnuts, AlEinstein, Bill_G, 01_celica_gt, 2 invisible), 641 Guests and 318 Spiders online.
58019 Members
66 Forums
249581 Topics
Page 1 of 3 1 2 3 >
#2237496 - 04/19/11 11:29 PM 180 or 195 thermostat?
scott37300 Offline
Loc: Wisconsin
I have a 04 impala with the 3.8L. I am going to be changing the thermostat on it along with some other maintenance I am going to be doing. While looking for a thermostat I found they come in 180 degree and 195 degree. What is the benefit of either of them? I assume the 180 will open up quicker so it means it will take longer to get up to operating temp? Anyone know what the stock thermostat is in an 04 impala 3.8L? Also if it matters I am in WI with cold winters.
Thanks
#2237505 - 04/19/11 11:59 PM Re: 180 or 195 thermostat? [Re: scott37300]
fsskier Offline
Loc: Iowa
I do not know of any car that uses less than a 190 degree thermostat for original equipment.
Benefits of a 180 degree thermostat: well, few... perhaps if your car overheats a lot, or has been modified for much more power you could benefit. Remember, at 210 degrees or more, they are both wide open, so neither will be better going across death valley. But the 180 degree thermostat would give you an engine 10 degrees cooler at the bottom of a long hill, that may help if you are towing a heavy load with a marginal cooling system.
Benefits of 192 degree: Better mileage, much better heater output in the winter, oil temperatures rise high enough to boil out excess fuel and moisture in the winter.
I believe Ford lead the parade to the 192 degree thermostat in about 1965, at the time the development studies - that they published in the SAE journal - showed that oil dilution with fuel and water was greatly reduced by going up to 192 degrees... their controlled wear tests indicated that engine life may increase by 30 percent for those using cars for lots of winter short trips. This is about the time Ford was shocking everyone with their recommended 6,000 mile oil change, and they felt the 192 degree thermostat was an important component of the longer oil changes.
Sorry to get so long, sometimes my keyboard just takes off!!
fsskier
Edited by fsskier (04/20/11 12:01 AM)
Edit Reason: grammar
#2237509 - 04/20/11 12:03 AM Re: 180 or 195 thermostat? [Re: scott37300]
Colt45ws Offline
Loc: Central Washington
I would only use the 180 if the car was reprogrammed to expect it.
-Colton
2002 Ford Crown Vic PI, 182k "Highwayman"
Ex-Kootenai County, ID Unit #42
Maxlife 5W20
Lubegard Bio/Tech oil treatment
Ultra XG2
#2237510 - 04/20/11 12:05 AM Re: 180 or 195 thermostat? [Re: scott37300]
tinmanSC Offline
Loc: Oswego, IL
The stock is probably 195 for the 3.8L, so they are offering a colder stat as is possible to get with most engines. Other than racing applications, there are generally no benefits to a colder thermostat unless you are trying to deal with a specific problem. Since you haven't mentioned any temperature issues with this engine, the stock thermostat would be the best choice, imho.
Cost of Hobby=2L
(Where L=Cost of Lubricant)
95 Lexus SC300 [email protected], 2000 [email protected] both VML Full Syn+Purolator PSL20195(soon to be Wix)
#2237514 - 04/20/11 12:12 AM Re: 180 or 195 thermostat? [Re: scott37300]
JimPghPA Offline
Loc: Pittsburgh,PA U.S.A.
They should both limit the coolant flow until the temperature they are rated for is reached.
Personaly, I like to use 180 if there is any chance that the cooling system might have some buildup clogs from years of use.
A cooler thermostat will give less MPGs, but also gives a little better cooling safety margin when you load the cooling system on hot days with the AC on.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
#2237518 - 04/20/11 12:14 AM Re: 180 or 195 thermostat? [Re: fsskier]
fsskier Offline
Loc: Iowa
Since you are in Wisconsin, let me add an additional note: In 1965 I was commuting with a 59 Ford 6 stick.... a decent combination, but I was always looking for improvements. College days, work nights, off at 1 am, always cold half way home... I learned of the 192 degree thermostat - I had a 180 in at the time , bought one and put it in. I was expecting that it would be difficult to tell the difference but WOW... the heater went from warm to HOT.
People in Florida might not care, but Badgers (Wisconsin) certainly do!!
#2237530 - 04/20/11 12:41 AM Re: 180 or 195 thermostat? [Re: scott37300]
Quest Offline
Loc: beaver land EH?
If your engine calls for 180, then go with 180. If it calls for 195F, then run 195F.
Deviating away from the factory thermostat on computer controlled OBD-II engines will cause drivability problems, or even engine troubles down the road.
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#2237545 - 04/20/11 01:37 AM Re: 180 or 195 thermostat? [Re: scott37300]
Cause4Alarm Offline
Loc: Maine
The 180 is for the supercharged version......
96 Tahoe 4x4
Engine: Total 9000 0w30, K&N oil filter
Trans: Valvoline full synth dex vi
Transfer case: Amsoil uni atf
Diffs: Amsoil severe gear 75w90
#2237574 - 04/20/11 06:29 AM Re: 180 or 195 thermostat? [Re: scott37300]
sciphi Offline
Loc: Upstate NY
The 180* thermostat is for preventing the nylon upper intake manifold and lower intake manifold gaskets from disintegrating as quickly on the 3800 Series II. It's also a very slight performance modification. I've had a 180* thermostat in my Buick to keep the upper intake manifold happy for 70k miles with no reduction in heater capacity or any other negative effects. It warms up quickly, gets good fuel mileage, and is a little bit of added protection for the upper intake.
Both versions got the 195* thermostat.
Not recommending one either way. It's up to the OP to decide which way go go.
Edited by sciphi (04/20/11 06:31 AM)
2013 Toyota RAV4 XLE
2012 Chevrolet Cruze Eco
#2237666 - 04/20/11 08:42 AM Re: 180 or 195 thermostat? [Re: sciphi]
scott37300 Offline
Loc: Wisconsin
Thanks for the explination everyone. I will go with the 195, I think that is what OEM is but not positive.
#2237694 - 04/20/11 09:06 AM Re: 180 or 195 thermostat? [Re: fsskier]
Hokiefyd Offline
Loc: North Carolina
Many Asian engines actually use a 180*F thermostat as OEM. My Camry does, and my Corolla did. Heck, my Acura MDX with the J35 engine and old Nissan truck with the KA24E actually use a 170*F thermostat.
Most vehicles with outlet-side thermostats (many domestics still use this) use 195*F thermostats. Many newer engine designs use inlet-side thermostats, which typically run at a cooler temperature.
Cheers,
Jason
2009 Honda Ridgeline RTL
2005 Acura MDX Touring
#2237710 - 04/20/11 09:23 AM Re: 180 or 195 thermostat? [Re: scott37300]
pbm Offline
Loc: New York
I'd stick with the OE temperature stat.
I'd also buy the best stat I could find because if it's anything like my Buicks 3.1, it's a PITA to change.
#2237785 - 04/20/11 10:36 AM Re: 180 or 195 thermostat? [Re: scott37300]
Craig in Canada Offline
Loc: Toronto-ish, Canada
Use whatever came in the car when new. Running too cool is bad for all kinds of reasons (efficiency, fuel dilution, fuel efficiency, wear, emissions etc...) and it won't actually do anything to solve an actual problem if you are overheating.
Modern engines are designed to run hotter. Even late 90s/early 2000s BMW V8s (i.e. not all that new) use 226F thermostats. This creates a high amount of system pressure which results in some long term plastic longevity challenges but assuming the fan system is working correctly the system has no trouble keeping temperatures under control in hot stop and go plus AC conditions even starting at 226F.
Edited by Craig in Canada (04/20/11 10:36 AM)
#2237947 - 04/20/11 01:23 PM Re: 180 or 195 thermostat? [Re: scott37300]
SteveSRT8 Offline
Loc: Sunny Florida
You are unlikely to find ANY OBDII vehicle with less than a 195 as stock.
Unless you're tuning for power hotter is better. Period.
And the hotter it is the easier it is to maintain that temp, as the differential temp makes it easier to give up the heat.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#2238081 - 04/20/11 03:25 PM Re: 180 or 195 thermostat? [Re: Hokiefyd]
dailydriver Offline
Loc: Bucks County, Pa.
My stock thermostat is a 186*/187*.
Not much difference to a 190/195/197 I know, but it is still under 190*. wink
I have 186/187* stock, 180* and 160* t-stats to choose from. I might try a 180* MotoRad this summer (with subsequent high/low fan settings reprogrammed, of course) when I change/flush out the Death Cool and install new silicone hoses.
2000 Z28 1SC 6 speed 180K miles
4L Motul 300V 0W-40, 2L Motul 300V 0W-20
M1-206 oil filter
Motul Gear 300 75W-90
Red Line D4/MTL in the T56
Page 1 of 3 1 2 3 >
