GM to test self-driving taxis
by xfactor9
05/06/16 01:09 AM
Resurfacing Brake Rotors
by The Critic
05/06/16 12:02 AM
Largest M1 filter for Jeep 4.0
by ARMY_Guy
05/05/16 10:50 PM
Mobil 1 or Castrol edge?
by sky06
05/05/16 09:48 PM
1 piece lug nut recommendations?
by dlundblad
05/05/16 09:07 PM
1996 Chrysler Coolant
by outoforder
05/05/16 09:02 PM
Hat Tip to RMEuropean
by sleddriver
05/05/16 08:54 PM
Toro OHV considered flat tappet type...
by Duffyjr
05/05/16 08:48 PM
Tire Rack now carries the Falken Azenis RT615k
by slacktide_bitog
05/05/16 07:30 PM
Walmart now carries Nokian tires
by slacktide_bitog
05/05/16 07:16 PM
Heater Core Leak?
by bprat318
05/05/16 06:54 PM
R2C air filters
by Srt20
05/05/16 05:55 PM
waldawg, Defcon, drivingaford, funkyheff, Ralph62
57814 Registered Users
24 registered (Boczech, alcyon, Doug Hillary, carlprop, 4 invisible), 1 Guest and 0 Spiders online.
57814 Members
66 Forums
248535 Topics
#2225223 - 04/07/11 04:55 PM life expectancy of steering/suspension parts
Silver_civic Offline
Loc: Pennsylvania, U.S.A.
Hello and kinda curious so thought I would ask. What would you folks here say is the average lifespan of steering components like inner and outer tie rods, and ball joints ans suspension parts like stabilizer links and sway bar bushings and a arm bushings? Was surprised that my friends 01' civic LX rear struts were worn out with more mileage than mine has. How long would you say struts and shocks usually last also?
thanks
adam
#2225232 - 04/07/11 05:03 PM Re: life expectancy of steering/suspension parts [Re: Silver_civic]
Trav Offline
Loc: MA, Mittelfranken.de
It 100% depends on the area and conditions.
In Germany i rarely replaced a shock,ball joint,tie rod or anything else from wear,it happens but very infrequently.
Wheel bearings,brakes and similar parts with high rotation speeds take a lot of abuse.
The roads are for the most part like high speed billiard tables.
In Massachusetts i cant keep them in long at all,a few years and they are shot to pieces in the SUV.
Huge pot holes and salt beat them to death.
#2225261 - 04/07/11 05:39 PM Re: life expectancy of steering/suspension parts [Re: Silver_civic]
cchase Offline
Loc: New England
I had a shake in the steering wheel on my truck that I was trying to get to the bottom of for the better part of a year.
It has 372,000 miles on it and all the suspension and steering bushings, tierod ends, and ball joints are original. They were all still good according to several suspension/alignment places I took it to last fall hoping to find some worn out component. Several places did not believe me that they were original (although its easy enough to confirm with the ball joints as only the factory has them riveted in). The truck has lived its entire life in New England.
The shake ended up being caused by the pitman arm, for what it's worth.
Go figure.
#2225328 - 04/07/11 06:47 PM Re: life expectancy of steering/suspension parts [Re: Trav]
Steve S Offline
Loc: East of IGO
+1 as should be expected from a professional!!!
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
#2225815 - 04/08/11 07:34 AM Re: life expectancy of steering/suspension parts [Re: Silver_civic]
Craig in Canada Offline
Loc: Toronto-ish, Canada
It also depends a lot on how you drive. My dad and I have cars which are the same platform (BMW E39) although they are quite different (mine's a sport package 6cyl w/ stick, his a non-sport 8cyl w/ auto). I like to drive harder than he does and his bushings and ball joints are lasting longer than mine by mileage whenever we've compared like pieces.
I put more stress on these components more often so they wear faster.
#2226477 - 04/08/11 07:30 PM Re: life expectancy of steering/suspension parts [Re: Silver_civic]
Spector Offline
Loc: Chattanooga, TN
Camry had the struts and plates replaced at 160,000, rear struts and plates at 210,000. Original rack and pinion. two half axles with boots somewhere in that 213,000 miles and 19 years
