Extended Warranty Requirement
by TiredTrucker
1 minute 6 seconds ago
RARE HID installation
by Kira
Today at 08:51 AM
ATP AT-205 good engine cleaner ?
by kr_bitog
Today at 06:16 AM
List of VOA's from Russian Oil Club
by spiderbypass
Today at 01:43 AM
Quicksilver Prem Plus
by jmw116
Today at 01:39 AM
Creating white letter tires
by turtlevette
Today at 12:22 AM
Hypothetical Question On Incorrect Filters
by Triton_330
Today at 12:18 AM
Pennzoil $2.99/qt at tractor supply!
by Chris142
Yesterday at 10:25 PM
Brother passed away this morning
by oilboy123
Yesterday at 10:21 PM
Changed oil tonight - what a fine evening
by pacem
Yesterday at 10:10 PM
Interesting observation on Ultra
by RusskiBoSS
Yesterday at 08:48 PM
2009 Honda Civic Cooling fan running continuously
by Doog
Yesterday at 08:31 PM
Hokie_Dave, ant3a, afterburnerbg, SupraSaiyan, Bighorn2500
57973 Registered Users
77 registered (Andrei, 4wheeldog, Bandito440, alienyzf, Bgallagher, 5 invisible), 1707 Guests and 350 Spiders online.
57973 Members
66 Forums
249376 Topics
Page 1 of 2 1 2 >
#2220734 - 04/03/11 10:22 AM Check engine light flashing/engine sputtering bad
aquariuscsm Offline
Loc: South Texas,USA
My gf`s 1998 Olds 88 3800 Series II V6). Check engine light is flashing and the engine is sputtering/missing really bad. What in the world could be causing this? I`ve never had this happen on any car I`ve owned before.
A side note,the water pump is slightly leaking,but surely this has no correlation,right?
Edited by aquariuscsm (04/03/11 10:22 AM)
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Syntec 10W40/Fram Ultra
Amsoil MTG(tranny)
Amsoil 80W90 GL5(rear diff)
Mobil 1 ATF
Redline Water Wetter
#2220738 - 04/03/11 10:24 AM Re: Check engine light flashing/engine sputtering bad [Re: aquariuscsm]
eljefino Offline
Loc: ME
Flashing CEL means misfire. Usually one of the basics: spark, fuel, or compression.
#2220743 - 04/03/11 10:28 AM Re: Check engine light flashing/engine sputtering bad [Re: aquariuscsm]
RF Overlord Online   content
Loc: Cape Cod, MA
Get the codes read. Most FLAPS will do it for free.
Get the codes read; we can help you better diagnose the issue if we know the codes.
Did I mention that you should get the codes read?
Supercharged '03 Mercury Marauder - Trilogy Motorsports #61
PP 5W-30 / MC FL820S
Y2K Grand Marquis GS - daily driver
QSUD 5W-20 / MC FL820S
#2220744 - 04/03/11 10:28 AM Re: Check engine light flashing/engine sputtering bad [Re: aquariuscsm]
Drew99GT Offline
Loc: Colorado Springs
Funny; I just put a new fuel injector in my Dad's 1999 Olds 88 with the same problem! But it could be any number of things like eljefino indicated. Check engine light flashing means get it fixed ASAP as a misfire is detected and raw fuel is going through the exhaust. Could plug the converter.
#2220746 - 04/03/11 10:29 AM Re: Check engine light flashing/engine sputtering bad [Re: RF Overlord]
Drew99GT Offline
The code will likely be a misfire detected in one cylinder. It won't help diagnose the problem.
#2220750 - 04/03/11 10:32 AM Re: Check engine light flashing/engine sputtering bad [Re: aquariuscsm]
FowVay Offline
Loc: Southeastern USA
Ignition coil problem??
#2220756 - 04/03/11 10:34 AM Re: Check engine light flashing/engine sputtering bad [Re: Drew99GT]
eljefino Offline
Loc: ME
If it's a misfire on two cylinders that share a coil, that hints pretty strongly at that ignition issue...
A single cylinder might more likely be an injector; I had that on my 97 silhouette 3.4.
#2220764 - 04/03/11 10:42 AM Re: Check engine light flashing/engine sputtering bad [Re: Drew99GT]
Loc: Cape Cod, MA
Sure it will...it might eliminate a vacuum leak. It could also point to an injector circuit problem, or it may confirm that it IS a misfire on one cylinder. Either way, it will give the OP a direction so he doesn't start blindly throwing parts at an unknown problem.
#2220784 - 04/03/11 11:03 AM Re: Check engine light flashing/engine sputtering bad [Re: aquariuscsm]
Cause4Alarm Offline
Loc: Maine
These engines like to eat intake gaskets....it'll throw only misfire and system lean codes
96 Tahoe 4x4
Engine: Total 9000 0w30, K&N oil filter
Trans: Valvoline full synth dex vi
Transfer case: Amsoil uni atf
Diffs: Amsoil severe gear 75w90
#2220789 - 04/03/11 11:10 AM Re: Check engine light flashing/engine sputtering bad [Re: aquariuscsm]
aquariuscsm Offline
I`m also going to drain that orange [censored] and replace it with green glycol when I replace the water pump.
Amsoil MTG(tranny)
Mobil 1 ATF
#2220838 - 04/03/11 12:37 PM Re: Check engine light flashing/engine sputtering bad [Re: aquariuscsm]
Cause4Alarm Offline
Loc: Maine
Don't put old school coolant in there or kiss you're new water pump goodbye
96 Tahoe 4x4
#2220853 - 04/03/11 12:53 PM Re: Check engine light flashing/engine sputtering bad [Re: aquariuscsm]
Steve S Offline
Loc: East of IGO
Since this is BOB IS THE OIL GUY the problem is to change the oil. If you used synthetic oil there never would be any engine problems. What does the code read? the code will lead you to a problem.
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
#2220890 - 04/03/11 01:30 PM Re: Check engine light flashing/engine sputtering bad [Re: aquariuscsm]
adamjeeps Offline
Loc: Virginia
Could be a bad fuel pump.
2013 Lincoln MKT EcoBoost
2012 Caddy SRX
2005 Dodge Dakota 4x4
#2221053 - 04/03/11 05:17 PM Re: Check engine light flashing/engine sputtering bad [Re: aquariuscsm]
mechtech2 Offline
Loc: Chicago Area
Like they said, you gotta get those codes read first.
Why not use the troubleshooting system that is built in?
#2221202 - 04/03/11 07:43 PM Re: Check engine light flashing/engine sputtering bad [Re: aquariuscsm]
aquariuscsm Offline
Got the codes. Bad sparkplug.
Amsoil MTG(tranny)
Mobil 1 ATF
Page 1 of 2 1 2 >
