Foam gun?
by demarpaint
02/13/16 06:47 AM
How do you wash your tomatoes ?
by Merkava_4
02/13/16 05:26 AM
Ground effect
by mjoekingz28
02/13/16 04:36 AM
20w50 thick? i present to you Penrite's 50w70!
by FordCapriDriver
02/13/16 03:46 AM
08 caravan / oil seeping from spark plug
by Mark72
02/12/16 11:25 PM
Holley Accelerator pump probem
by nwjones18
02/12/16 10:56 PM
Sealant for threaded air hose fittings.
by BigD1
02/12/16 10:37 PM
on line data search programs - which is best?
by bmwjohn
02/12/16 10:11 PM
What size air compressor is needed
by ram_man
02/12/16 09:45 PM
DHS wants to force car owners to use OEM parts
by faltic
02/12/16 08:54 PM
Castrol Edge 5w30 no longer A5/B5
by slacktide_bitog
02/12/16 08:20 PM
Best Oil Analysis?
by countryboy9799
02/12/16 07:28 PM
wdleighton1, RTS, jhmed80, engus, Rob_Pol
56902 Registered Users
52 registered (BigCahuna, AlienBug, 2002 Maxima SE, Al, BlueOvalFitter, 04SE, 4 invisible), 805 Guests and 109 Spiders online.
56902 Members
66 Forums
244629 Topics
#2204704 - 03/18/11 08:16 PM Brake fluid for Mercedes; DOT 4 Plus...
Galo Offline
Loc: Indy IN
...but apparently there is no DOT 4 Plus "rating", just DOT 4. Any info or suggestions?
Thank you.
#2204720 - 03/18/11 08:39 PM Re: Brake fluid for Mercedes; DOT 4 Plus... [Re: Galo]
Quattro Pete Offline
Loc: Great Lakes
Which year/model mercedes?
'02 530i (PPE 5W-40)
'15 Q5 3.0T (Edge 5W-40)
#2204753 - 03/18/11 09:31 PM Re: Brake fluid for Mercedes; DOT 4 Plus... [Re: Galo]
Doug Hillary Offline
Loc: Airlie Beach Australia
Hi,
Galo - This should be available from an MB Dealers. VW & Volvo use it too I believe
Regards
Doug
#2204768 - 03/18/11 09:55 PM Re: Brake fluid for Mercedes; DOT 4 Plus... [Re: Galo]
rshunter Offline
Loc: Ohio,USA
If it's a modern Mercedes-Benz, with systems like ABS, ASR and ESP, I'd recommend using ATE SL.6 brake fluid.
'99 Eurovan GLS,'06 Raider DuroCross V8 Ext,'08 GTI DSG,'14 PriusPLUS
#2204806 - 03/18/11 10:45 PM Re: Brake fluid for Mercedes; DOT 4 Plus... [Re: Galo]
JHZR2 Offline
Loc: New Jersey
Go to the MB Bevo site and they may list manufacturers, brands, etc.
#2204830 - 03/18/11 11:23 PM Re: Brake fluid for Mercedes; DOT 4 Plus... [Re: Galo]
Ken2 Offline
Loc: Washington St.
Yes, but...but there are fluids that are superior to DOT 4. As said above, buy from any European car dealership parts counter or one of the ATE or other European brands. DOT 5.1 is another unofficial rating, and probably the same as 4+. It meets the same performance standard as (silicone) DOT 5, but has the same chemical composition as DOT 4+, similar to DOT 4, close to DOT 3.
Every gun that is made, every warship launched..a theft from those who hunger and are not fed, those who are cold and not clothed.
Gen. Eisenhower
#2205102 - 03/19/11 11:15 AM Re: Brake fluid for Mercedes; DOT 4 Plus... [Re: Galo]
unDummy Offline
Loc: RI
The 4+/5.1 is a way of marketing something better than what the available spec is. Low Viscosity-DOT4 is another.
DOT4 is an excellent brake fluid. If you bleed every year or 2, you don't need to worry about moisture dropping the boiling point to danger zone, especially if you don't race or drive on the autobahn.
If you never plan on bleeding the system again, or purposely neglect the fluid, visit the dealer and buy the labeled DOT4+. I don't want you to be able to blame the fluid for failure caused by negligence or abuse.
Those who say it cannot be done, should not interrupt the person doing it.
Your automaker lied!
Is this a spelling/grammar forum or BITOG?
#2243557 - 04/26/11 05:49 AM Re: Brake fluid for Mercedes; DOT 4 Plus... [Re: Galo]
artificialist Offline
Loc: Florida
At the auto repair shops I have worked at, we just use ordinary DOT4 and never have a problem.
2010 Lancer Ralliart Sportback
