More destruction ahead?
by andrewg
21 minutes 11 seconds ago
Sticky intake valves
by Ozzmosis
27 minutes 28 seconds ago
2003 Ford Explorer Sport XLT Differential Fluid
by TalNum
35 minutes 6 seconds ago
QSUD in Ecotec: 2 qts. consumed in 3K !
by Benzadmiral
44 minutes 13 seconds ago
Utica or SK Torque Wrench?
by ET16
48 minutes 7 seconds ago
Fly me to the Moon...
by reemoe2
53 minutes 28 seconds ago
Old HONDA almost too good to be true in Wisconsin
by SumpChump
Today at 08:56 AM
VW and Shell accused of trying to block EV push
by wemay
Today at 08:30 AM
(previously repaired) cracked 351 block. trash?
by tomcat27
Today at 08:12 AM
CarQuest #84045, 600 miles CUT OPEN
by car51
Today at 08:10 AM
Molybdenum, is there a downside?
by 5170
Today at 07:52 AM
Cleaning 'Foggy' Headlights
by coopns
Today at 07:45 AM
Doxxy, Jetstreamz06, TalNum, Spinnizle, JustinL
57758 Registered Users
94 registered (AirgunSavant, 2015_PSD, 901Memphis, 86cutlass307, Alex38, 13 invisible), 1856 Guests and 306 Spiders online.
57758 Members
66 Forums
248293 Topics
Page 1 of 3 1 2 3 >
#2195882 - 03/10/11 07:23 PM Bosch Distance Plus D3323 and Particle Count
chubbs1 Offline
Loc: Merritt Island FL, USA
I just received a particle count report as part of my BlackStone UOA. I posted the ISO Code 14/13/10 that accompanied the UOA. Today I got a letter in the mail with the actual particle count..
>=2 Micron 203
>=5 Micron 75
>=10 Micron 21
>=15 Micron 8
>=25 Micron 1
>=50 micron 0
>=100 Micron 0
This is absolutely amazing to me, though I have seen few particle counts on here, this blows others out of the water. I have to say these filters are excellent and though expensive if you wait until they have a deal at AAP I highly recommend. My UOA link is http://www.bobistheoilguy.com/forums/ubb...;gonew=1#UNREAD
Edited by chubbs1 (03/10/11 07:24 PM)
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#2195902 - 03/10/11 07:35 PM Re: Bosch Distance Plus D3323 and Particle Count [Re: chubbs1]
ZeeOSix Offline
Loc: PNW
The Bosch Distance Plus is hard to beat. Maybe a little pricey, but you get what you pay for.
A filter's brand name doesn't matter ... what's inside does.
#2195903 - 03/10/11 07:35 PM Re: Bosch Distance Plus D3323 and Particle Count [Re: chubbs1]
btanchors Offline
Loc: Herndon, VA
This certainly beats all the UOA Particle counts I have ever done. Perhaps I should try a Distance Plus on my Tundra as the next filter...
#2195924 - 03/10/11 07:50 PM Re: Bosch Distance Plus D3323 and Particle Count [Re: chubbs1]
JRed Offline
Loc: Virginia
The Bosch DistancePlus is a Purolator PureONE with a thicker can.
Save even more money by buying PureONE filters. They're the exact same thing internally but cheaper. Exact same filter media.
Edited by JRed (03/10/11 07:51 PM)
06 Subaru Impreza WRX - Sold. The only mechanical thing I'll ever love.
07 Toyota Prius - Cheap synthetic and PureOne filters.
#2195981 - 03/10/11 08:28 PM Re: Bosch Distance Plus D3323 and Particle Count [Re: chubbs1]
Eddie Offline
Loc: Florida, Cape Coral
How do we know or have gotten this data JRed
CX5 Touring 2.5L :-)
#2196024 - 03/10/11 09:06 PM Re: Bosch Distance Plus D3323 and Particle Count [Re: JRed]
Letter_K Offline
Loc: Minnesota
I'm pretty sure everything we've seen on BITOG shows that they have different media than the PureOne. Both are made by Purolater.
Check out Riverrat's post (you may need to scroll down) It is the one with the pictures of the cut open filter. Look at the pictures and writeup - It ain't the same.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1865537&page=30
Also, they are $5 off at Pepboys this month. The ad lists it with 5 quarts of Syntec (or GC) for $22.99 after rebate, but the rebate is only really a Bosch filter rebate.
2004 Buick Rendezvous Mobil 1 5w-30 EP, Mobil 1 Filter
2007 Honda Accord - Mobil 1 0w-30 AFE, Mobil 1 Filter
#2196065 - 03/10/11 09:56 PM Re: Bosch Distance Plus D3323 and Particle Count [Re: JRed]
chubbs1 Offline
There is no way it is a P1 internally. I just don't see how that is possible with the claims Bosch D+ makes. It may be made by the same Co. but it is way nicer than a P1. I will try it eventually and do a particle count but Btanchors particle counts with P1 were not as good and it is a larger filter that is supposed to be more efficient. The size I use (P14610) has a less efficient rating than the larger P1's.
Edited by chubbs1 (03/10/11 10:01 PM)
Edit Reason: Add
'12 Charger SXT
'12 Charger SXT
#2196262 - 03/11/11 05:47 AM Re: Bosch Distance Plus D3323 and Particle Count [Re: chubbs1]
Sayjac Offline
Loc: The Old North State
Fine filter, but @~$13.50 regular price for my 7-8k average OCI's, overkill. And for your 3.1k, though I didn't see a time interval, I'd say the same. JMO Not that familiar with reliabilty of UOA particle counts, but the numbers look good.
While the P1's may/may not show as good a UOA particle count, for the $3-5 price, the value for construction/efficiency, just works better for me. Haven't seen any published micron rating for the BDP, without it, one could only assume it's figured the same as the P1, but with the greater advertised holding capacity.
And it is true that the PL14610 has the higher micron number, it also has substantially more media area than the larger 14459, odd. Be curious to know the media area of the equivalent 3323 BDP.
All that said, I'll be using a BDP 3323 next OCI, as I picked 3 up for ~$4.50 each with 3 AAP PP oil/filter change specials, a deal for sure. So I'll get a close up look after use.
Thanks for posting.
#2196367 - 03/11/11 08:40 AM Re: Bosch Distance Plus D3323 and Particle Count [Re: Sayjac]
daman Offline
Loc: Bad Axe, MI
From what we've seen here the DP and P1 are about the same with the exception the DP has thicker media then the yellow P1 hence the dirt holding capability's clamed by DP,now is there something more then that to it? not sure but from the naked eye that's the only difference.
i know rob(river_rat)looked at these under a microscope but un sure if he looked at these two maybe he'll chime in.
there's plenty of posts and pics on these two filters using the search function.
"Always"....Mobil 1
Current fill: AFE 0w30
#2196375 - 03/11/11 08:50 AM Re: Bosch Distance Plus D3323 and Particle Count [Re: chubbs1]
Virtuoso Offline
Loc: Cow town, NE
That's great! Thanks for posting.
#2196613 - 03/11/11 12:54 PM Re: Bosch Distance Plus D3323 and Particle Count [Re: chubbs1]
ltslimjim Offline
Loc: WatUpDoc
Good posts sayjac and daman.
92 Civic Hatch (stolen frown RIP)
07 Honda Fit Sport (A/T) WELCOME thumbsup
#2196663 - 03/11/11 01:34 PM Re: Bosch Distance Plus D3323 and Particle Count [Re: chubbs1]
typ901 Offline
Loc: N. 'Burbs of Chicago, IL
Uh Oh is this is going start a K&N v M1 oil filter style comparison for P1 v. DP!
#2196684 - 03/11/11 01:49 PM Re: Bosch Distance Plus D3323 and Particle Count [Re: JRed]
kcfx4 Offline
Loc: indiana
I know the cartrige type my mazda takes, the Bosch and P1 are different
If it has an engine, but not a blue oval or yellow deere, i probably dont own it
#2196698 - 03/11/11 02:04 PM Re: Bosch Distance Plus D3323 and Particle Count [Re: chubbs1]
chubbs1 Offline
Thank you all for the posts, I know it wasn't a long run and I got the report the day after I changed the filter. I was going to leave it on but my oil OCD made me think I had to change the filter. I am saving it to use again. That thing is just a well built filter and I really wonder if many could beat it. I am now officially recommending BD+ to anyone who asks. OTOH, it is probably my luck that BlackStone made a mistake.
'12 Charger SXT
'12 Charger SXT
#2196746 - 03/11/11 03:09 PM Re: Bosch Distance Plus D3323 and Particle Count [Re: chubbs1]
Striker Offline
Loc: Ontario,Canada.
Now are the regular Bosch Filters (Non Distance Plus) simply PureOne units with a different can?
Than the Distance Plus filters are their own Bosch filters, correct?
1999 Trans Am WS6- 24,995 miles- German Castrol (considering other alternatives?)
1990 Mustang LX Coupe- 80K miles- Synpower 10W30+Puro Classic
Page 1 of 3 1 2 3 >
