GM to test self-driving taxis
by xfactor9
05/06/16 01:09 AM
Resurfacing Brake Rotors
by The Critic
05/06/16 12:02 AM
Largest M1 filter for Jeep 4.0
by ARMY_Guy
05/05/16 10:50 PM
Mobil 1 or Castrol edge?
by sky06
05/05/16 09:48 PM
1 piece lug nut recommendations?
by dlundblad
05/05/16 09:07 PM
1996 Chrysler Coolant
by outoforder
05/05/16 09:02 PM
Hat Tip to RMEuropean
by sleddriver
05/05/16 08:54 PM
Toro OHV considered flat tappet type...
by Duffyjr
05/05/16 08:48 PM
Tire Rack now carries the Falken Azenis RT615k
by slacktide_bitog
05/05/16 07:30 PM
Walmart now carries Nokian tires
by slacktide_bitog
05/05/16 07:16 PM
Heater Core Leak?
by bprat318
05/05/16 06:54 PM
R2C air filters
by Srt20
05/05/16 05:55 PM
waldawg, Defcon, drivingaford, funkyheff, Ralph62
57814 Registered Users
23 registered (Boczech, alcyon, Doug Hillary, carlprop, 4 invisible), 1 Guest and 0 Spiders online.
57814 Members
66 Forums
248535 Topics
#2194802 - 03/09/11 10:22 PM Flashpoint >n by grade. What does it mean?
jorton Offline
Loc: San Antonio, TX
In blackstone reports, why do different grade oils have different flashpoint >numbers?
05w-20 = flashpoint >355
00w-30 = flashpoint >375
05w-30 = flashpoint >365
10w-30 = flashpoint >360
00w-40 = flashpoint >365
05w-40 = flashpoint >375
15w-40 = flashpoint >385
05w-50 = flashpoint >400
Can pistons ever get hotter than 355f? 400f?
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
#2194824 - 03/09/11 10:45 PM Re: Flashpoint >n by grade. What does it mean? [Re: jorton]
2003f7 Offline
Loc: Kewaunee WI
Piston temps can reach 1200* f or more.
2002 Ford Excursion 6.8
2003 Ford Taurus 3.0 24v
#2194881 - 03/10/11 12:11 AM Re: Flashpoint >n by grade. What does it mean? [Re: jorton]
dtt004 Offline
Loc: Orange County, CA
Hi.
Ok to the above poster, flash point is usually measured in degrees C. 400 degrees C = 752 degrees F. By the way, I have never seen a car's pistons reach 1200 F. No offense, but that is theoretically impossible given the limits of the aluminum alloy used for pistons nowadays. The piston would simply melt. I do not know of any pistons that can withstand 1200 degrees F. The maximum threshold before failure is usually 700 K, which is about 426 degrees C.
A simple way to think of flashpoint is the point at which is vaporizes from a liquid into an ignitable gaseous phase mixture.
The number goes up with increasing oil viscosity because viscosity is directly proportional to the strength of the bonds in the carbon molecules inside the oil. This is why a higher viscosity oil will always provide greater protection by permitting an oil film to adhere to the lubricated parts at higher temperatures. Additives have an effect, but not as significant as the base stock itself.
That's why I believe the science behind these molecules rather than the marketing that is done; when a manufacturer says a lower viscosity oil will provide protection, what they are really saying is "it will provide enough protection for its intended use." And for the most part, people will never notice the difference. But from a science/engineering perspective all factors must be taken into account. Higher viscosity oils simply provide better film strength/adherence at higher temperatures. Those are simply laws of physics, thermodynamics, and fluid mechanics.
Technical Design Engineer
1991 Toyota MR2 Turbo
1993 Mazda RX-7 Turbo
1996 Toyota Tacoma V6 4x4
2005 Acura NSX
2008 Lotus Elise
2004 Kawasaki Ninja ZX-10R
#2194904 - 03/10/11 12:49 AM Re: Flashpoint >n by grade. What does it mean? [Re: jorton]
Brons2 Offline
Loc: Austin, Texas
This should go in the "Oil Analysis - General Questions" forum.
Mine: 2007 Kia Rondo LX 2.4 I4 5 pass, M1 HM 10w30, OEM filter
Hers: 2010 Rav4 Sport 2.5 I4, M1EP 0w20, OEM filter
#2196266 - 03/11/11 05:59 AM Re: Flashpoint >n by grade. What does it mean? [Re: jorton]
jorton Offline
00w-40 = flashpoint >375
Flashpoint temps are centigrade. Changed 0w-40 from 365 to 375.
- Mario Andretti
#2196383 - 03/11/11 09:00 AM Re: Flashpoint >n by grade. What does it mean? [Re: jorton]
INDYMAC Offline
Loc: Magnolia, TX
Flashpoints can be listed as C or F. The flashpoints that are mentioned above are in F.
2013 Toyota Tundra DC 4X4 5.7L FFV
2012 Toyota 4Runner 2WD SR5
2004 Honda S2000
#2197382 - 03/12/11 07:32 AM Re: Flashpoint >n by grade. What does it mean? [Re: jorton]
jorton Offline
10w-30 = flashpoint >375
Now I don't know if synthetic is the same flashpoint as dino in the same grade.
Changed 10w-30 from 360 to 375.
- Mario Andretti
