5.4 3V under valve cover pics & solenoid failure
by 04SE
05/28/16 03:50 PM
New safety spec for 2017 F1 cars...
by mcrn
05/28/16 03:35 PM
M1-101 after 10k on a 95 Sunfire 2.2 OHV pushrod
by slacktide_bitog
05/28/16 03:18 PM
Base Oil Content and Marketing
by MolaKule
05/28/16 03:08 PM
Best OTC fuel injector cleaner
by 007
05/28/16 03:06 PM
A brief BMW R1100RT story
by Finn
05/28/16 02:29 PM
2015 6.7L Powerstroke Fuel Filter Change
by 2015_PSD
05/28/16 12:51 PM
Caliper question
by supton
05/28/16 12:48 PM
Impressed with Yokohama Geolander A/T G015
by K20FA5
05/28/16 12:13 PM
Need a good tire pressure guage that read over 60
by MetalSlug
05/28/16 11:55 AM
Castrol 0w40 vs M1 0w40 FS ?
by Ndx
05/28/16 11:14 AM
what old Snapper parts to save
by edwardh1
05/28/16 10:56 AM
mungchimp, troutwest66, AIRJAC3, bpete65, LEVY
58001 Registered Users
83 registered (04SE, A310, 2015_PSD, AIRJAC3, Al, 87sammy, 7 invisible), 1586 Guests and 338 Spiders online.
58001 Members
66 Forums
249530 Topics
Page 1 of 3 1 2 3 >
#2189551 - 03/05/11 11:14 AM oil for drag racing
HighStrung Offline
Loc: Western NY
Hello all,
I am new to the forums. I drag race a 225" racetech dragter with a 468 BBC on methanol ( roller lifters). The builder of the engine recommended that I use Pennzoil 10w-40 and change it every 20 passes. I did that last year and have apparently not had any issues. ( although I have yet to pull a rod bearing a look for wear). With all the reading on the website, talking with friends that I race with, I see opinions on oil are like a$$holes...we all got one. So given that, I am looking for some more opinions on oils for drag racing with a Meth engine and some recommendations on weights. I have been looking at the Brad Penn oils in 10w-40 and at the Rotella T 15w-40. Anybody have any experience with the oils? Any opinions? Thanks for any help! -Mark
Edited by HighStrung (03/05/11 11:15 AM)
#2189563 - 03/05/11 11:32 AM Re: oil for drag racing [Re: HighStrung]
DrDusty86 Offline
Loc: TX
REdline, or RP XPR 3.1. FYI oil opinions are like religions everybody WORSHIPS one...but some are just CRAZY. A$$holes is when some people's opinion stinks...HHHAAAHHH
#2189578 - 03/05/11 11:42 AM Re: oil for drag racing [Re: HighStrung]
Hemi426 Offline
Loc: PA
The Brad Penn Penn Grade 1 oils are pretty decent race oils from my experience. I run the straight 40 wt. in my street/strip Dodge 440. You may want to try this oil over a 10w-40 even if you're going to change it often due to the methanol. Pennzoil GT 25w-50 is supposed to be a decent oil also. At my local track, most of the higher class racers tend to use Penn Grade 1 although some do use Valvoline VR-1. Good luck and hope I have been a little bit of help.
P.S. Welcome to the Forums! smile
Edited by Hemi426 (03/05/11 11:50 AM)
#2189584 - 03/05/11 11:44 AM Re: oil for drag racing [Re: HighStrung]
SteveSRT8 Offline
Loc: Sunny Florida
A great one is Amsoil Dominator series. Purpose built racing oil.
The number one Ford builder uses Royal Purple XPR.
Lots of choices.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#2189613 - 03/05/11 12:13 PM Re: oil for drag racing [Re: SteveSRT8]
daves87rs Offline
Loc: Michigan
Lots of choices.
This. I know that really like RP...
Whatever you are, be a good one.
#2189624 - 03/05/11 12:30 PM Re: oil for drag racing [Re: HighStrung]
electrolover Offline
Loc: TEXAS
everyone i know running alcohol use vr1 20/50 or sae50
rotella is a good oil but the high detergents tend to foam with high rpms
2004 F150 5.4 160k-Castrol TXT 5/40, Distance+ 3410-KREEN
2004 Explorer 4.0 130k-PU 5w30, Distance+ 3410
#2189634 - 03/05/11 12:40 PM Re: oil for drag racing [Re: HighStrung]
440Magnum Offline
Loc: Texas
With an engine like that, I'd tend to go for a true racing oil. Add another vote for Redline or Royal Purple XPR.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 Cherokee 4.0, '11 Grand Cherokee 3.6
#2189641 - 03/05/11 12:49 PM Re: oil for drag racing [Re: 440Magnum]
Hemi426 Offline
Loc: PA
Penn Grade 1 is a true racing oil. Tom Hemphill from Clarkburgh, PA uses it in his Top Sportsman engine and many race engine builders recommend it.
#2189735 - 03/05/11 01:51 PM Re: oil for drag racing [Re: HighStrung]
Loc: TEXAS
since no one has mentioned joe gibbs i will. its probably the best race oil out there.
vr1 is also a "true race oil" and affordable.
#2189757 - 03/05/11 02:12 PM Re: oil for drag racing [Re: HighStrung]
Torino Offline
Loc: Henderson, Nevada
Redline.
#2189796 - 03/05/11 02:48 PM Re: oil for drag racing [Re: HighStrung]
badawg350 Offline
Loc: Black Hills,South Dakota,U.S.A...
I use Conklin 20w-50 racing and have had excellent results on methanol
Don't Get On It If You Can't Stay In It!
#2189826 - 03/05/11 03:23 PM Re: oil for drag racing [Re: HighStrung]
HighStrung Offline
Loc: Western NY
Keep it coming...taking it all in....I appreciate the responses!
#2190002 - 03/05/11 06:55 PM Re: oil for drag racing [Re: Hemi426]
440Magnum Offline
Loc: Texas
Maybe... but Brad Penn's advertising turns me off. They practically brag that the crude is so good that they hardly have to refine it at all (yes, I'm exaggerating a little). NOT a selling point in my book...
As others mentioned, there are other good racing oils out there- Gibbs, Roush, Valvoline, Amsoil. But for the OP's engine, I stand by my pick of Redline or RP XPR.
#2190012 - 03/05/11 07:04 PM Re: oil for drag racing [Re: 440Magnum]
Hemi426 Offline
Loc: PA
He's going to be changing the oil every 20-25 runs. I doubt he wants to use something that costs $10-11 per qt. I don't know how many quarts his sump holds but a boutique oil would get very expensive very quickly.
Edited by Hemi426 (03/05/11 07:12 PM)
#2190183 - 03/05/11 09:20 PM Re: oil for drag racing [Re: Hemi426]
440Magnum Offline
Loc: Texas
That's a very good point and certainly argues in favor of a less expensive oil... but then rebuilding the engine is even more expensive. At any rate, if it were mine I'd feel better with something a little more robust than a street car oil like PYB 10w40. I'd also research what oils are the most methanol tolerant.
Page 1 of 3 1 2 3 >
