Originally Posted By: unDummy
I hate when they state TR instead of an actual number.
Did you have vehicle since it was new? original clutch?
Is the drain plug magnetic? What did it look like?
Appearance of old fluid?
TBN/TAN would've been interesting.
If 75w90 is required, why not just run MT90?
The numbers are too low for the mileage and viscosity. Makes you wonder how accurate Blackstone is, or if gear oil was changed during another service or repair.
I've had the car since 2005 and 110k mi. Original clutch, turbos and fluid as far as I know. No records indicate otherwise, unless they were misplaced. Drain plug is factory and not magnetic. Fluid looked like used motor oil but with a gear oil odor.
The reason for running the mixture of MT-90 and MTL is to improve shifting in cold weather. If I didn't see temps below the 20s in winter I would most likely run straight MT-90 or possibly the Amsoil equivalent.
I'll do another change around 275k mi and we'll see how those numbers compare. I'd be willing to bet these are accurate for the full mileage on the car.
