Windows Live Mail Question
by Wingman
02/05/16 06:21 PM
Royal Enfield Himalayan....Giddy Up!
by BigJohn
02/05/16 06:17 PM
clear no tint 1994 dakota windshield?
by bmwjohn
02/05/16 06:14 PM
New HDEO OIls.....a question?
by BigJohn
02/05/16 05:29 PM
I Finally Pulled the Trigger...
by MCompact
02/05/16 05:22 PM
Best oil filter for Toyota 1GR-FE
by DrRoughneck
02/05/16 05:17 PM
How long can unused oil filters sit?
by SkyXSteel
02/05/16 05:16 PM
Particulate Filters and Ash
by BigJohn
02/05/16 05:09 PM
1956 Triumph 500.
by DC_Stewart
02/05/16 04:32 PM
VW Diesel oil filters ?
by DC_Stewart
02/05/16 04:23 PM
Any experience with 98-02 corolla?
by barkingspider
02/05/16 04:11 PM
nice video
by raaizin
02/05/16 03:36 PM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
96 registered (901Memphis, 2015_PSD, 3for3, 05LGTLtd, 04SE, 7 invisible), 1582 Guests and 144 Spiders online.
56834 Members
66 Forums
244279 Topics
Page 1 of 2 1 2 >
#2171187 - 02/14/11 05:31 PM 96 Accord Trans Fluid Change
bustednutz Offline
Loc: Virginia Bch. VA
I am going to be buying a 96 Accord. Its in great shape, but has never had a trans service. It has 180k miles and I want to do a drain and refill with HONDA Trans fluid.
I was thinking about doing an initial drain and refill with an oil change as well. Then in 5k do it again with the next oil change. Trying to get some fresh fluid in there after all these years.
So whats everyone think of this plan?
#2171226 - 02/14/11 05:57 PM Re: 96 Accord Trans Fluid Change [Re: bustednutz]
EricF Offline
Loc: SF Bay Area
Sounds good to me.
1993 Ford Ranger XLT 4.0L 4x4 (240k) 5W-30 Synpower
2006 Saturn Relay-3 3.5L (85k) 5W-30 Synpower
2012 Ford Fusion SE 2.5L (39k) 5W20 M/C Semi Syn
#2171247 - 02/14/11 06:14 PM Re: 96 Accord Trans Fluid Change [Re: bustednutz]
chubbs1 Offline
Loc: Merritt Island FL, USA
I would do a change for sure. That is a loooong time. Your plan sounds good, or you could take it to a Honda dealer as my second option and do it all at once, I don't think that is necessary though just a second option.
BTW Which Honda fluid were you going to use??
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#2171262 - 02/14/11 06:28 PM Re: 96 Accord Trans Fluid Change [Re: bustednutz]
garlicbreadman Offline
Loc: USA
with 180k on the clock, you might just want to leave that tranny fluid in there if it shifts fine. it can start to slip with new fluid
#2171294 - 02/14/11 06:54 PM Re: 96 Accord Trans Fluid Change [Re: garlicbreadman]
chad8 Offline
Loc: michigan
Do the drain /fill. If it slips or breaks , its time has come anyway. Time to refresh the fluid.
#2171312 - 02/14/11 07:12 PM Re: 96 Accord Trans Fluid Change [Re: bustednutz]
Eddie Offline
Loc: Florida, Cape Coral
I certanly thing the posters plan is a good one and that is what I would do. I would NOT do a flush.
CX5 Touring 2.5L :-)
#2171338 - 02/14/11 07:34 PM Re: 96 Accord Trans Fluid Change [Re: bustednutz]
bustednutz Offline
I'm going to use whatever fluid is required for that year vehicle from the Honda dealer. Were their other options?
I have no intentions of doing a flush.
Edited by bustednutz (02/14/11 07:35 PM)
#2171375 - 02/14/11 08:15 PM Re: 96 Accord Trans Fluid Change [Re: bustednutz]
RH+G Offline
Loc: NY
U will know how many drain and fills have been done when u take the drain plug out by looking at the magnet on it.
#2171899 - 02/15/11 12:32 PM Re: 96 Accord Trans Fluid Change [Re: RH+G]
Hootbro Offline
Loc: DELAWARE
This!
I bought my son's 1996 Accord with 177K on it with not one single transmission fluid change having been done. The drain plug magnet was saturated with shavings. Also suggest if you have a small magnetic pick up tool end, sweep just inside the drain hole to get the remaining shavings out.
Also, these transmissions for this year spec Dextron II as a suitable sub but anything Dextron III rated will work. Transmission filter is not serviceable unless you split the transmission casing. Simple drain and refill is about 2.5 quarts.
For me, the improvement was immediate on the first drain and refill. I would recommend about three drain and refills spread out over 1K miles each to get mostly fresh fluid cycled through.
Also recommend the turkey baster method of sucking out the power steering fluid from the resevoir and install correct Honda Spec power steering fluid. Do not use ATF or another universal spec fluid. Auto Zone sells Honda spec fluid if needed.
Edited by Hootbro (02/15/11 12:36 PM)
2015 RAM 2500 6.4 HEMI 4x4
2013 FIAT 500
2010 Toyota FJ Cruiser 4x4
#2172142 - 02/15/11 04:54 PM Re: 96 Accord Trans Fluid Change [Re: bustednutz]
bustednutz Offline
Thats very interesting about using Dex II or III. I was always told to use the "Honda" fluid in these transmissions.
Are we all certain that Dex can be used? If it can be used safely, then it would same me a few bucks. But I don't mind spending xtra to get the right stuff.
#2172160 - 02/15/11 05:10 PM Re: 96 Accord Trans Fluid Change [Re: bustednutz]
caravanmike Offline
Loc: ohio
their is a cutoff year between dex III and z-1. who knows the specific year?
Oils I use: Any 5w-30,5w-20 conventional
#2172327 - 02/15/11 08:00 PM Re: 96 Accord Trans Fluid Change [Re: bustednutz]
Hootbro Offline
Loc: DELAWARE
Owners manual for this year calls out the Honda Premium formula ATF or DEX II. I know the later years went to an exclusive Honda only formula but this is not the case here.
http://techinfo.honda.com/rjanisis/pubs/om/AC9696/AC9696O00159A.pdf
Since technically they are no longer issue a license for DEX II or III, you can find a compatible product from most normal ATF brands than are actually a universal MERCON/DEX formula and you will be fine. IIRC I used Pennzoil multi-vehicle ATF and was fine.
Edited by Hootbro (02/15/11 08:02 PM)
2013 FIAT 500
#2172402 - 02/15/11 09:28 PM Re: 96 Accord Trans Fluid Change [Re: bustednutz]
RH+G Offline
Loc: NY
I have been using Mobil 1 since 2001
#2172405 - 02/15/11 09:29 PM Re: 96 Accord Trans Fluid Change [Re: RH+G]
bustednutz Offline
What year is your Honda?
#2172455 - 02/15/11 10:31 PM Re: 96 Accord Trans Fluid Change [Re: bustednutz]
bigdawg74 Offline
Loc: Olympia, WA
Usually whenever I buy a used vehicle, I assume the previous owners did not do any preventative maintenance, unless proven otherwise with a maintenance log. Right off the bat, all fluids (oil, tranny, PS, brake, and coolant) get changed. That way I have a base point to go off of for future fluid changes.
As far as ATF choice, I would stick w/ the Honda Z-1. Maybe do a couple of quick (1000 mile)runs with a Dex3, but then the final fill go with the Z-1. I drain/fill the ATF every 20k in my '02 Accord.
'10 Hyundai Tucson Ltd. 2.4L
PP 5w20~OEM filter
'11 Chevy Silverado 4.3L V6
Dlr Bulk 5w30~unk filter
Page 1 of 2 1 2 >
