Linux Distro for laptop
by LeakySeals
08/29/16 09:24 AM
GM Pickup Trucks With G-80 Locker Read This
by Silverado12
08/29/16 09:12 AM
M1 EP 0w20, 12764 mi oci, 50302 mi 2013 RAV4
by SF0059
08/29/16 08:25 AM
AC blows dead animal smell with a huge vibration!
by puredata
08/29/16 08:04 AM
Oil consumption early vs. late in OCI
by skaughtz
08/29/16 08:03 AM
Kaepernick disses national anthem
by grampi
08/29/16 07:19 AM
rain rusted rotors...
by columnshift
08/29/16 07:02 AM
Did MY headlights with Toothpaste, It Works !!
by bobbob
08/29/16 02:59 AM
Jury Duty
by dishdude
08/29/16 12:42 AM
Mercon LV or MaxLife
by buck91
08/28/16 11:46 PM
VW Electric Plans
by Y_K
08/28/16 10:49 PM
Oil Recommendation for Nissan 3.5 V6 113,000 miles
by BlueSmoke16
08/28/16 10:10 PM
gioburk, turrican, GGilbert, leje0306, DLL
58951 Registered Users
101 registered (09_GXP, 4WD, Andrei, AirgunSavant, akela, 97f150, 9 invisible), 1535 Guests and 7 Spiders online.
58951 Members
66 Forums
253715 Topics
#2168751 - 02/11/11 11:51 PM Best way to add Techron treatment
sceco5 Offline
Loc: Midwest US
Lately I have been thinking about adding a bottle of Techron to my car since I am at 50K miles, and I have never put any kind of fuel additives or treatments in it. My car has developed a miss that makes the car jerk back during steady crusing speeds at 55mph, but it only happens once or twice during a 30 mile trip. I am kind of stumped why it is occuring, since everything looks fine mechanical wise after inspecting it. I am hoping maybe adding a bottle of Techron could clean this up.
I know that it is reccomended to put in a bottle of Techron oon an almost empty tank, and to change the oil a short while afterwards becuase it can get nto it. My questions are
Should I use Techron, and then run the tank close to empty 2 or 3 times prior to chaninging the oil? That way its a good certainty that most of the Techron is out of the fuel system.
Should I also replace my plugs and fuel filter when changing the oil from Techron use? Is it possible that Techron can cause fouling to the plugs?
As you can see, I do not have much experience using Techron, or fuel additives or treatments for that matter. grin Since I always use Shell 93 V Power fuel, is there really a reason that I should have to use Techron in the first place? I always thought the whole point of the V Power nitrogen enriched fuels was to prevent carbon buildup and to keep the fuel injectors clean, but advertising gimmics can be deceiving. Like I said, Techron is my next option at figuring out this miss, since I don't have any other ideas at the moment. So I appreciaite any help you all could give me
#2168899 - 02/12/11 07:58 AM Re: Best way to add Techron treatment [Re: sceco5]
Dupree Offline
Loc: Utah,Vernal (oil land)
The top Techron fuel cleaner, Gumout Regane, or Redline Si-1 are all good candidates. I like to do it before an oil change just in case there is any dilution. I think it is unnecessary but a wise precaution. Just put it in a low tank fill up and drive. I wouldn't worry about rinse out tanks after it isn't anything super harmful just a preventative maintenance item on your fuel system. Yes I do feel it is a good thing even when running a top tier petrol. I hope that answers your questions sir.....
Edited by Dupree (02/12/11 08:01 AM)
74 Dodge Dart Swinger /-6
94 Subaru Legacy
99 Ford Superduty
01 Subaru OutBack H6
08 Ford Explorer EB
12 Subaru Tribeca Limited
#2168972 - 02/12/11 09:27 AM Re: Best way to add Techron treatment [Re: sceco5]
Vikas Offline
Loc: NorthEast
Have you checked EGR system? Your symptoms indicated clogged EGR system
#2168982 - 02/12/11 09:36 AM Re: Best way to add Techron treatment [Re: sceco5]
Durango Offline
Loc: Los Angeles, California
I too add a bottle or two of Techron either before or after my 3K services. The instructions on the bottle appear to need attention though. It's hard to pretty much empty a tank of gas and buy a bottle of techron for $15 bucks and then spend close to $80 bucks to fill it up. In the real world just add it when you can.
Durango
#2168991 - 02/12/11 09:44 AM Re: Best way to add Techron treatment [Re: sceco5]
Bamaro Offline
Loc: Balto.
I'm not sure why there would be a need to change the oil after using something like Techron, Regane, etc. ???
2015 Elantra
2009 Cobalt totaled by inattentive driver
1970 Camaro
2016 Civic
2015 Rogue
2014 Mazda3
#2168997 - 02/12/11 09:49 AM Re: Best way to add Techron treatment [Re: Bamaro]
Durango Offline
Bamaro,
Oil is different than gasoline.
Durango
#2169177 - 02/12/11 01:50 PM Re: Best way to add Techron treatment [Re: sceco5]
RTexasF Offline
Loc: Brownsville, TX
They also make Techron in a size for 20 gallon tanks instead of just twelve. My local Auto Zone had the smaller size @ buy one get one free yesterday. That made it a better buy then the larger bottle. I see no reason to change oil after using it, makes no sense to me whatsoever. Unless your car is due for fuel filter & spark plug changes there is no reason to do so after running a simple fuel system cleaner.
#2169453 - 02/12/11 08:50 PM Re: Best way to add Techron treatment [Re: sceco5]
Dupree Offline
there are some theories that the minute amount of gas wash you encounter with the oil can wash the oil down more so than usual with a fuel cleaner in there. Its nothing to worry about, but at the same time why not do it around oil change for a routine. And in the unlikely event it does degrade the oil in any way problem solved.
94 Subaru Legacy
99 Ford Superduty
08 Ford Explorer EB
#2169853 - 02/13/11 10:03 AM Re: Best way to add Techron treatment [Re: Durango]
Bamaro Offline
Loc: Balto.
Bamaro,
Durango
Obviously but except under severe very limited circumstances, why change the oil?
2015 Elantra
1970 Camaro
2016 Civic
2015 Rogue
2014 Mazda3
#2170074 - 02/13/11 02:17 PM Re: Best way to add Techron treatment [Re: sceco5]
mongo161 Offline
Loc: Coney Island, NY
I add Techron concentrated Fuel System Cleaner/Gumout Regane concentrated Fuel System cleaner to my fuel at every fill up.
I have a empty 6 ounce bottle from the Gumout Regane Concentrate that contains 3 ounces of TC-W3 and 3 ounces of a combination mix of Techron/Gumout Regane. TC-W3 is a UCL and the Techron/Gumout Regane is for keeping the system clean....especially with all the ethanol in the Gas sold.
The way I look at it is this.....They don't sell Chevron/Texaco gasoline in my market area so by adding some to each fill up of 12 gallons of gasoline I'm getting the benefits of Techron/Regane.
I don't see any problems and stick to my regular OCI's. I would not try to schedule adding a cleaner for the fuel system around an oil change....why not use a cleaner, in smaller amounts, at each fill up.
I get by with a little help from my friends....listen with your eyes....it's the ONLY way to believe what you hear...
#2170325 - 02/13/11 07:35 PM Re: Best way to add Techron treatment [Re: sceco5]
Johnny Offline
Loc: Retired | Wausau, WI
To keep it simple, we use to recommend the customer pour in a bottle of REGANE at every oil change. Unless there is some strange problem adding the Techron or REGANE at the time of the oil change will not harm the new oil.
But, to each their own.
#2170484 - 02/13/11 11:13 PM Re: Best way to add Techron treatment [Re: Johnny]
Malo83 Offline
Loc: Cali
I use Regane regularly with no problems, was buying a bottle at Wally world one day and some guy told me that I shouldn't use the stuff because it ate up all the seals in his carb no-no I just looked at him and said REALLY!!! LOL
#2170503 - 02/14/11 12:03 AM Re: Best way to add Techron treatment [Re: sceco5]
Audi Junkie Offline
Loc: PA
I tell people to get two bottles. Add one to 1/2 tank and drive it down to 1/4, add another bottle and fill it up.
Currently, I'm using about 25% Techron with my 2-cycle oil, every fill at 500:1
2008 Opel Astra 1.8 VVT 5M
2010 VW Tiguan 2.0 TSI 6M
(APR Powered)
#2170629 - 02/14/11 07:59 AM Re: Best way to add Techron treatment [Re: sceco5]
Eddie Offline
Loc: Florida, Cape Coral
I add one Techron Cleaner (large size for 20 gal for my 18.7 gal fuel tank) before an oil change. I had a weird UOA and the tester said it MAY be because of the additive. So, if I'm going to get a UOA done, I don't use it shortly before an oil change.
CX5 Touring 2.5L :-)
#2180488 - 02/24/11 01:55 PM Re: Best way to add Techron treatment [Re: Durango]
JHZR2 Offline
Loc: New Jersey
Durango
Why would it be any more/less to do this than fill up a half tank twice?
