Cooper Discoverer CTS
by mannymachine
06/19/13 06:21 PM
Under valve cover of a 2AZ-FE
by asiancivicmaniac
06/19/13 05:57 PM
what is your cleaning/detailing routine?
by gregk24
06/19/13 05:47 PM
synthetic AC booster
by Donald
06/19/13 05:40 PM
Wolfgang Fuzion - Just a picture
by bourne
06/19/13 05:35 PM
2000 Silverado Trans Problem
by pgun67
06/19/13 05:11 PM
Baldwin Filter Electronic Catalog
by NorWest5
06/19/13 04:51 PM
Chevron/Havoline 0w-20, 7200 miles, 2006 Montego
by ToyotaNSaturn
06/19/13 04:36 PM
2013 Accord K24W1 DI - TGMO 0W20 SN - 5873 miles
by Leonardo629
06/19/13 04:19 PM
Vichy
by JHZR2
06/19/13 04:05 PM
Brake Choice
by Sawdusted
06/19/13 04:01 PM
Oil and filter recommendation 2005 Chevy Uplander
by gregk24
06/19/13 03:24 PM
janh, fwb35, Fullsize14, ZRagsdale, bobstevens
45912 Registered Users
114 registered (97tbird, 901Memphis, 147_Grain, 94MaxGXE, Artem, 99Saturn, 10 invisible), 1433 Guests and 236 Spiders online.
45912 Members
64 Forums
195375 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
Page 1 of 2 1 2 >
#2142633 - 01/18/11 02:16 PM Mobil 1 ATF vs. Amsoil ATF vs. Redline D4
Oregoonian Offline
Loc: Bend, Oregon
I am a few thousand miles away from draining my tranny fluid (Mercon V) on my 03' Ford Focus automatic.
I'm considering going to a full synthetic... instead of Mercon V...mainly for longer OCI's. Or...should I just stay with Mercon V and 30K OCI's? Also...would you suggest installing a Magnafine Transmission when doing the change?
Your suggestions and experience with the above Syn ATF's would be appreciated.
___________________________________________
03' Ford Focus SE Auto (2.3L Duratec) / 94K
M1 5w20EP / OCI: 1 yr. or 10K / M1 EP 102 Filter
Edited by Oregoonian (01/18/11 02:20 PM)
03' Ford Focus SE (2.3L Duratec PZEV)/ 114K +
M1 0w20/Fram 'Ultra'/OCI: 7,500 X 2 (on Ultra)
Autolite APP103 Dbl. Plat.
ATF: Mercon V w/Lubegard Red
#2142642 - 01/18/11 02:29 PM Re: Mobil 1 ATF vs. Amsoil ATF vs. Redline D4 [Re: Oregoonian]
unDummy Offline
Loc: RI
If you go longer ATF OCI's, you need a Magnafine, Permacool, or Racor ATF filter.
Stick with your Mercon-V and 30k intervals if you don't want to install additional filtration.
Any of the full synthetics would be an excellent choice. Coin toss.
Those who say it cannot be done, should not interrupt the person doing it.
Your automaker lied!
Is this a spelling/grammar forum or BITOG?
#2142644 - 01/18/11 02:31 PM Re: Mobil 1 ATF vs. Amsoil ATF vs. Redline D4 [Re: Oregoonian]
pbm Offline
Loc: New York
I would switch to synthetic and install a Magnafine which should allow you to go 50 or 60K between ATF changes. My Buick runs great on Mobil 1 ATF. The 3 synthetics that you've listed are all excellent but I'd probably choose Redline.
#2142651 - 01/18/11 02:40 PM Re: Mobil 1 ATF vs. Amsoil ATF vs. Redline D4 [Re: unDummy]
Chris Meutsch Offline
Loc: Cincinnati
I used to run 60K on Amsoil on my Civic with no filter and never had a problem at all. Now my CR-V does indeed have a "secret" filter that Honda doesn't tell you about in-line.
More filtration is better I'd assume; just relaying my positive experience without one.
"I don't think anyone in this thread gives a [censored] about your B.S. stories. Put away your 2 cents, no one wants them."
----hypervish, 5/23/13
#2142664 - 01/18/11 03:01 PM Re: Mobil 1 ATF vs. Amsoil ATF vs. Redline D4 [Re: Oregoonian]
buster Offline
Loc: NJ
I think Amsoil makes a great ATF.
#2142702 - 01/18/11 03:34 PM Re: Mobil 1 ATF vs. Amsoil ATF vs. Redline D4 [Re: Oregoonian]
Conrad Offline
Loc: Upstate NY, USA
Can't comment on performance, but I've never smelled anything so bad in my life as Mobil 1 ATF. I'm not sure I could leave the cap off the bottle long enough to use it without losing my lunch. I've smelled lots of stinky gear oils and ATF, but this stuff is beyond belief.
Best,
Conrad
#2142720 - 01/18/11 03:50 PM Re: Mobil 1 ATF vs. Amsoil ATF vs. Redline D4 [Re: Oregoonian]
Ben99GT Offline
Loc: MS
I like Red Line D4, personally.
2001 F150 Supercrew
1991 Mustang LX notch
1999 Mustang GT
#2142729 - 01/18/11 03:56 PM Re: Mobil 1 ATF vs. Amsoil ATF vs. Redline D4 [Re: Oregoonian]
tig1 Offline
Loc: Illinois
I've used M1 ATF for as long as they have made it, and it does very well in all of the Fords I have put in. 40K with M1 is pretty much the OCI I use.
2007 Ford Fusion 115,000 miles
M1 0-20
2007 Ford Focus 110,000 miles
M1 0-20
M1 ATF
M1 10-30 in all OPE
#2142796 - 01/18/11 05:26 PM Re: Mobil 1 ATF vs. Amsoil ATF vs. Redline D4 [Re: Oregoonian]
Artem Online   content
Loc: Florida
I've used M1 ATF in my 98 Toyota Camry V6 for 60k / 4 years and have had great results. Super smooth shifts in all temps and conditions even near the end of my OCI. I replaced it with Amsoil and am liking that as well. (obviously the shift quality is better because its new fluid) 198k on the original tranny and filter.
I've never used Redline's ATF because its hard to get and becomes even more expensive with a shipping charge.
I say you go for whatever is easier to get. They are all excellent oils, in my opinion.
06 Scion tC 108k - 10w30 Valvoline NextGen
1990 Mazda RX-7 - 145k - 15w40 Rotella T
98 Toyota Camry V6 - 239k - Doing Mobil 1 0w40 + MMO cleaning
#2143236 - 01/19/11 12:11 AM Re: Mobil 1 ATF vs. Amsoil ATF vs. Redline D4 [Re: Oregoonian]
Audi Junkie Offline
Loc: PA
I thought MercV was synthetic?
Of those, I use AMSoil ATF and would use Redline. Redline is my first choice in a MTF.
My preference for that AT would be for more MercV or an OTC mfg spec ATF, like +4 if compatible or definitely MaxLife as maybe the very best choice.
2008 Opel Astra 1.8 VVT 5M
2010 VW Tiguan 2.0 TSI 6M
(APR Powered)
#2143706 - 01/19/11 01:43 PM Re: Mobil 1 ATF vs. Amsoil ATF vs. Redline D4 [Re: Oregoonian]
AzFireGuy79 Offline
Loc: Arizona
Redline D4. I have personally used it for years in many different applications.
2008 Chevrolet 2500HD 6.6 DMAX, CCSB,Z71
2011 JEEP Grand Cherokee Overland HEMI 5.7
#2144220 - 01/19/11 10:39 PM Re: Mobil 1 ATF vs. Amsoil ATF vs. Redline D4 [Re: AzFireGuy79]
Oregoonian Offline
Loc: Bend, Oregon
Thanks for all you comments and advice. Like someone said... "its a coin toss".
Decided to go with the M1 ATF...although (after doing some research) I think the Amsoil product might be a bit superior.
The reason I'm going to M1 Syn ATF is....its about 25% to 30% cheaper than Amsoil....easily available locally... some good reports from some BITOG guys whom I respect...and the Amsoil product is just to much of a hastle to obtain (cost & shipping etc.).
I plan on putting on a Magnafine filter and doing 40K to 50K OCI.
______________________________________________
Ford Focus (2.3L Duratec) / 94K
M1 5w20EP / M1 EP 102 Filter / 1 Yr. or 10K OCI
Edited by Oregoonian (01/19/11 10:48 PM)
#2144327 - 01/20/11 05:02 AM Re: Mobil 1 ATF vs. Amsoil ATF vs. Redline D4 [Re: Oregoonian]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
Just curious how much $ M1 ATF is in Bend?
#2144743 - 01/20/11 12:37 PM Re: Mobil 1 ATF vs. Amsoil ATF vs. Redline D4 [Re: Pablo]
Oregoonian Offline
Loc: Bend, Oregon
$7.29 a quart....I'll need 7 quarts.
#2144868 - 01/20/11 02:34 PM Re: Mobil 1 ATF vs. Amsoil ATF vs. Redline D4 [Re: Oregoonian]
PW01 Offline
Loc: Louisville, Kentucky
You'll like the M1 ATF. I've used it for years in my Ranger, which calls for Mercon V
01 Ford Ranger 4.0 SOHC V6, 4x4 - Mobil 1 High Mileage 5w-30, Motorcraft FL820s
99 Honda Accord EX V6 sedan - Mobil 1 5w-30, Bosch 3312
Page 1 of 2 1 2 >
