Arthritic joints
by Eddie
05/27/16 08:55 PM
Trouble Installing Filter
by Astro_Guy
05/27/16 08:09 PM
Kia P0138 Code From Old Amsoil Stabilizer ??
by Quadrasteer
05/27/16 07:43 PM
Micro Guard Filter
by Jason1221
05/27/16 07:38 PM
'88 Caddy Brougham 307 c.u. oil selection
by momo
05/27/16 07:34 PM
Kawasaki FX730V
by Jason1221
05/27/16 07:30 PM
'88 Caddy Brougham 307 c.u. oil filter
by momo
05/27/16 06:57 PM
Milk intolerance question
by LoneRanger
05/27/16 06:33 PM
2010 Hyundai Elantra H/B...oil requirments
by Oregoonian
05/27/16 06:27 PM
Hyundai and Kia Coolant Part Interchange?
by nobb
05/27/16 05:44 PM
Volkswagen Looks to Build Its Own ‘Gigafactory’
by HTSS_TR
05/27/16 04:55 PM
QSAD 5W20 UOA 5,504 miles 2011 TAURUS 3.5
by dustyroads
05/27/16 04:48 PM
LEVY, Timmytimmy, Peakboy91, TimingBeltKing, watergate528
57997 Registered Users
72 registered (aquariuscsm, 2015_PSD, ABerns, 007, 69GTX, andyd, 6 invisible), 1492 Guests and 320 Spiders online.
57997 Members
66 Forums
249502 Topics
Page 2 of 2 < 1 2
#2081960 - 11/19/10 10:55 PM Re: Oil Leak - 2004 Lincoln LS V6 [Re: Norse]
adamrc Offline
Loc: Nashville, TN
Originally Posted By: Norse
Did you try the White Shepherd?
I bought a bottle of it but I haven't used it yet. It says on the bottle to drive continuously for one to two hours or until oil leak has stopped. Most of the time, the car is driven for no more than 30-40 minutes so I figure I'll dump the bottle in before a longer trip. I'll post an update once I try it.
#2081962 - 11/19/10 11:10 PM Re: Oil Leak - 2004 Lincoln LS V6 [Re: adamrc]
JustinH Offline
Loc: Texas
I would have torqued the oil pan bolts as the FORD PARTS GUY suggested before I dumped a bottle of GLUE into the crankcase.
Heck, if anyone has seen leaky lincolns it has to be this guy.
'10 Toyota Rav4 Sport
'08 Toyota Matrix
#2082012 - 11/20/10 01:20 AM Re: Oil Leak - 2004 Lincoln LS V6 [Re: JustinH]
bdcardinal Offline
Loc: Santa Barbara, CA
duh parts guys dont know anything...
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
#2082178 - 11/20/10 09:50 AM Re: Oil Leak - 2004 Lincoln LS V6 [Re: adamrc]
lipadj46 Offline
Loc: Western NY
white shepherds is not glue it is a very effective seal conditioner, very polar (does not mix well with oil at low temps)so I think it is ester based. That being it won't do a thing for an oil pan gasket leak though. Man up and reseal the oil pan with a new gasket or right stuff.
2002 Toyota Corolla, 65k miles, Mobil 1 0w30
2004 WV Passat Wagon 94k Miles, Rotella T6
2002 Land Rover Discovery Totaled RIP
#2134883 - 01/11/11 09:02 AM Re: Oil Leak - 2004 Lincoln LS V6 [Re: adamrc]
adamrc Offline
Loc: Nashville, TN
Well I ended up running the White Shepherd seal conditioner and I'm still having the leak. I'm thinking it's leaking some oil onto the exhaust or something because when I run the car for the first few minutes when it's cold, I can smell burning oil coming through the heater vents as it's warming up. I may just have to end up buying a oil pan seal and changing it out. Does anybody know the part number or a good place to get one? I've done a decent amount of mechanic work before so I think I can do it myself. This car was in the Nashville flood of May 2010 and so it sat in about a foot of water at the time of the flood and I'm thinking that the dirty flood water may have affected the oil pan seal and is causing some of the issues.
#2135200 - 01/11/11 02:01 PM Re: Oil Leak - 2004 Lincoln LS V6 [Re: adamrc]
bdcardinal Offline
2R8Z-6710-AA for the oil pan gasket MSRP is 51.68. That gasket fits a ton of applications.
Replacing the gasket isn't too DIY friendly unless you feel like dropping the subframe in your driveway.
#2135243 - 01/11/11 02:25 PM Re: Oil Leak - 2004 Lincoln LS V6 [Re: bdcardinal]
adamrc Offline
Loc: Nashville, TN
Thanks for the part number bdcardinal. Not what I wanted to hear about dropping the subframe. I'm not sure if I'd be up to doing that. I guess I'll have to find some shop around the around to do the job for me. It almost looks like there may be some leakage around the gasket of the front piece (it's flat and in the front of the engine). I might have to have it replaced as well. It's separate from the regular oil pan.
#2143920 - 01/19/11 06:00 PM Re: Oil Leak - 2004 Lincoln LS V6 [Re: adamrc]
TravisT Offline
Loc: Yucca Valley, ca
Hey guys, I have a 2002 lincoln ls with the v6 and replaced my own oil pan gasket in the summer of 2010, it wasn't easy but do-able. I wasn't able to drop the pan out of the car due to the sub frame, but what I did was loosen the motor mounts and used a 2x4 from the passanger side of the car and a jack from under the car and at the front of the motor, I moved the motor up enough so I could get my hands in the the oil pan (after I had unbolted it of course) then I cleaned the surface as best I could, the old gasket left a bit of residue behind and I had to clean it with some fine emry cloth. Then to remove the old gasket I had to unbolt the oil pump from inside the engine (2 bolts, easy) and the gasket has an exact push pull squeze method of removing and putting the new one in. I was able to bend the new gasket (very careful!)in place and bend it back to shape. If you can visualize this, the pan isn't lower than the crank, so you have to go down and around it. I then put on some high temp rtv sealent to the pan and bottom of the engine, (not easy) Don't forget to put the oil pump back on. I also had to remove the alternator to get to all the oil pan bolts. I am not a mechanic but I do my own vehicle maintence and this was a all day event by myself. I have read this repair can cost upward of $1000, so it was worth it to me. Hope this helps, I couldn't stand all the oil spots mine was leaving and the burning oil smell was horrible, and to date no leaks. Again I have heard this was a common problem on the V6 motor, I bought mine in 2008 with 24000 miles and It was leaking then.
#2144181 - 01/19/11 09:38 PM Re: Oil Leak - 2004 Lincoln LS V6 [Re: TravisT]
TravisT Offline
EDIT: I had to remove the starter not the alternator
#2144643 - 01/20/11 11:35 AM Re: Oil Leak - 2004 Lincoln LS V6 [Re: adamrc]
D189379 Offline
Loc: Canada City, Canada
If it's hitting the exhaust, the oil leak is not on the oil pan. Look higher. Maybe the valve covers are dripping down?
(Unless this engine has some sort of high oil pan and low exhaust.)
Page 2 of 2 < 1 2
