Accord door lock issue....
by gregk24
07/31/16 12:26 AM
2000 Corolla vvt-i rattle on startup?
by 55Test
07/30/16 11:24 PM
Brought home a beater today
by exranger06
07/30/16 11:03 PM
Can someone explain to me the nomenclature of ammo
by Vern_in_IL
07/30/16 10:52 PM
Common for bad shift solenoids to shift good warm?
by DemoFly
07/30/16 09:50 PM
Riding mower with non bearing front wheels
by JHZR2
07/30/16 09:17 PM
Mail popup
by Eddie
07/30/16 09:05 PM
Tundra headlight restoration..
by kenwin30
07/30/16 09:00 PM
High mileage and severe service...
by OneEyeJack
07/30/16 08:44 PM
Who uses Quicksilver Multi-purpose oil
by BrocLuno
07/30/16 08:07 PM
Gumout Q&A with Ryan Tuerck - Answers
by wwillson
07/30/16 07:37 PM
Friend Picked Up New 2017 Hyundai Santa Fe Today
by crazyoildude
07/30/16 07:07 PM
danthemann, rodder98, kenb777, Indyfan3, RM53119
58651 Registered Users
20 registered (Char Baby, alcyon, 1foxracing, BobsArmory, 4 invisible), 837 Guests and 7 Spiders online.
58651 Members
66 Forums
252471 Topics
Page 1 of 2 1 2 >
#2125661 - 01/03/11 12:36 PM Best Additive For Small Rear Main Seal Leak???
wemis Offline
Loc: West Virginia
I have a 1999 Mitsubishi Eclipse. It has 133,000 miles on it. It's a 5 speed. I've never had any major problems with it, knock on wood. I had to take it to the garage to have them find an oil leak. They said it was the oil pressure sending unit and replaced it. They also noted that the rear main seal was leaking about a drop or two of oil ever 45 minutes. I know that's not much oil at all. I do not want to replace the rear main seal due to the high cost of it(Estimated $600 or $700). My question is what should I do? I am a compulsive and addicted researcher and reviewer. I research and review almost EVERYTHING I buy. I have read multiple posts and reviews, both positive and negative about Bar's Leaks Rear Main Seal Repair, Lucas Engine Oil Stop Leak, Auto-RX, Marvel's Mystery Oil, etc. I am kind of at a standstill and can't decide on what to try to fix the leak. I have never used any stop leak product or additive in my life! Any input, review, or personal usage report would be greatly appreciated! Thank you all for your time!
#2125665 - 01/03/11 12:40 PM Re: Best Additive For Small Rear Main Seal Leak??? [Re: wemis]
Thax Offline
Loc: VA
I would try using a high mileage oil , if that does not seem to stop the leak I would try the Bar's leak rear main seal repair. What oil are you currently using?
97 Grand Prix GTP
11 Jetta 2.5 SE
ASE P2 Parts Specialist
AIA Import Part Specialist
KIA certified Technician
#2125669 - 01/03/11 12:45 PM Re: Best Additive For Small Rear Main Seal Leak??? [Re: Thax]
Turk Offline
Loc: MN
I used Val. Maxlife 5-30 and it stopped the same type of oil leak in the Camry... Try that 1st. thumbsup
03 GMC Sierra 4x4 200k M1 0-40+PU
00 Saturn SL2 89 YO Lady Car 92k, Edge Ext
98 Saturn SC2 Rare "Red Hot" 165k, Edge Ext
97 Camry 245k, Maxlife
#2125674 - 01/03/11 12:47 PM Re: Best Additive For Small Rear Main Seal Leak??? [Re: Thax]
wemis Offline
Loc: West Virginia
I am currently using Castol GTX High Mileage. On that note, I have tried a LOT of different oils. I have never tried a fully synthetic though. Also, I never knew the rear main seal was leaking before recently. In the past, the car has been using oil. I can honestly say I don't know how much because I hadn't been using it was my daily driver until recently. I wanted to start checking it and recording all results but that has gotten messed up since it started leaking oil via the oil pressure sending unit. I want to get a detailed diagnosis about how much oil it's using now that the main leak was fixed. I'm just trying to determine how to go about fixing the rear main seal leak first. I have read very good things about Valvoline MaxLife on here as well as Mobil Clean 5000. As far as the Bar's Rear Main Seal fix is concerned, should I worry about it "gunking" up my engine? I am very open to trying about anything based on the good reviews I've read on here about MMO, Auto-Rx, etc. I know they are cleansers in a sense and worry about them making the leak worse. I'm kind of all over the place as far as a "fix" on this one. I start reading and I get my mind running on all sorts of products! I'm definitely OCD when it comes to wanting what's best for my vehicles!
#2125677 - 01/03/11 12:48 PM Re: Best Additive For Small Rear Main Seal Leak??? [Re: Turk]
wemis Offline
Loc: West Virginia
Thanks for your input! I have read good things about Maxlife oil! I'm almost due for an oil change so I may just try that first before going with the stop leak product.
#2125678 - 01/03/11 12:50 PM Re: Best Additive For Small Rear Main Seal Leak??? [Re: wemis]
Thax Offline
Loc: VA
+1 on the Valvoline Maxlife , its a great oil and is pretty thick in the 5w-30 or 10w-30 flavors so I would give that a shot. I use it in my girls saturn ion and have had zero problems.
97 Grand Prix GTP
11 Jetta 2.5 SE
#2125684 - 01/03/11 12:55 PM Re: Best Additive For Small Rear Main Seal Leak??? [Re: Thax]
wemis Offline
Loc: West Virginia
Do you think that would cut down on oil consumption as well as fix the leak? As I stated before, I definitely want to figure out exactly how much it's leaking per month or 1000 miles.
#2125718 - 01/03/11 01:20 PM Re: Best Additive For Small Rear Main Seal Leak??? [Re: wemis]
jstutz Offline
Loc: NC
Try the Maxlife. It has gotten a lot of great reviews. If it does not aid in oil consumption/leakage, then move to the other additives or a thicker grade of oil such as 10W40 high mileage. Stay away from the MMO and Auto RX as neither will help you with a leaking rear main seal. If you wanted to clean up an engine or free up a sticking lifter then maybe you could try them. Stay safe and just try the max life. If you are still getting some leakage, maybe try the max life 10w40.
#2125719 - 01/03/11 01:20 PM Re: Best Additive For Small Rear Main Seal Leak??? [Re: wemis]
umungus1122 Offline
Loc: PA
Well I can give you my experience with rear main seal leaks. On a 92 GMC pick up, I was using PP 5 and 10/30 and it would pour out. Tried Auto rx, nothing. Went to Castrol 15w/40 and the leak almost completely stopped. Currently have a chevy 1500 that was leaking when I bought it, used Auto RX, and the leak almost vanished.
"Just walk away, and I promise you safe passage out of the wasteland."
'95 Chevy 1/2t 305 200k - Mobil semi-syn 7500 10w-30, CARQUEST Blue filter
#2125733 - 01/03/11 01:38 PM Re: Best Additive For Small Rear Main Seal Leak??? [Re: umungus1122]
wemis Offline
Loc: West Virginia
Thank you all for your input. I am going to start with trying Maxlife and see what happens. Have any of you used Bar's Rear Main Sealer?
#2125770 - 01/03/11 02:07 PM Re: Best Additive For Small Rear Main Seal Leak??? [Re: wemis]
Thax Offline
Loc: VA
I have used the leak sealer on a honda accord that had about 280k , it worked a little bit but did not stop the leak. However this was a big leak and I dont think anything short of replacing the seal would have fixed it . In the end we just donated the car to charity and got a used car. I would just try the Maxlife in 10w-30 , its a pretty thick 30 weight with a good seal conditioning additive package so that would be my first shot then after that 10w-40 and failing that the Bar's Stop leak.
97 Grand Prix GTP
11 Jetta 2.5 SE
#2125991 - 01/03/11 05:20 PM Re: Best Additive For Small Rear Main Seal Leak??? [Re: wemis]
electrolover Offline
Loc: TEXAS
if the car is a stanard you had better get it fixed quick or you will be buying a new clutch soon.
i would go maxlife 10/40 or 10/30 with lucas
2004 F150 5.4 160k-Castrol TXT 5/40, Distance+ 3410-KREEN
2004 Explorer 4.0 130k-PU 5w30, Distance+ 3410
#2126032 - 01/03/11 05:47 PM Re: Best Additive For Small Rear Main Seal Leak??? [Re: wemis]
keesue Offline
Loc: San Francisco
I used a lot of stop leak products to stop two leaks I had to avoid having to pay to have it done. They were an annoyance to say the least. Only one product worked - No Leak: http://www.goldeagle.com/brands/no_leak/default.aspx
Within 200 miles, my engine seal leaks stopped. I then used their stop leak for a power steering leak on my steering rack. That leak stopped within 200 miles where nothing else ever worked. I was able to avoid having to spend $1,100 plus dollars on a new rack with labor and re-alignment as well as the cost of the engine seals and the labor associated with that. I am a happy camper. That was some time ago. My driveway is finally clean.
Not saying it will work for you, but it sure worked for me; and, No Leak is the cheapest of all of them. Go figure...
I should add that these leaks were not gushers. They were leaks.
Edited by keesue (01/03/11 05:50 PM)
Edit Reason: clarification
1981 Turbo Volvo with over 313,000 miles (bought new)
2001 S60-T5 Volvo
#2126047 - 01/03/11 05:59 PM Re: Best Additive For Small Rear Main Seal Leak??? [Re: wemis]
Trav Offline
Loc: MA, Mittelfranken.de
For a real small leak i might try Max life or ARX.
Not my favorite product for other issues but to be fair a lot of folks seem to have some success with it in these cases,i think its probably a lot safer than a lot of stop leaks that will swell seals up like an elephants trunk,something you really don't want.
A major leak at the rear seal indicates seal damage and will need to be replaced,don't toast the rest of the seals with a product that swells them up trying to fix this one.
IMHO use the least aggressive product.
#2126486 - 01/04/11 03:57 AM Re: Best Additive For Small Rear Main Seal Leak??? [Re: Trav]
wemis Offline
Loc: West Virginia
Thanks for the review of the No Leak product. I had never heard of it. I am going to try MaxLife 10W-30 first to see if that fixes it. If it doesn't, I am going to try the stop leak products. Since it's not a gushing leak and is very small IMO, there has to be at least ONE stop leak product that will fix it! Thank you all for your knowledge and input! I greatly appreciate it!
Page 1 of 2 1 2 >
