Anyone here gotten late life orthodontics?
by LoneRanger
08/29/16 12:30 PM
iPhone Touch Disease
by Pop_Rivit
08/29/16 11:22 AM
Windows RUN (tool) troubleshoot
by Triple_Se7en
08/29/16 10:58 AM
Spark plug gaps
by SpeedyG75VW
08/29/16 10:27 AM
Funny Craigslist ad
by Drew99GT
08/29/16 10:23 AM
Formula Shell dino
by Camprunner
08/29/16 10:05 AM
Linux Distro for laptop
by LeakySeals
08/29/16 09:24 AM
GM Pickup Trucks With G-80 Locker Read This
by Silverado12
08/29/16 09:12 AM
M1 EP 0w20, 12764 mi oci, 50302 mi 2013 RAV4
by SF0059
08/29/16 08:25 AM
AC blows dead animal smell with a huge vibration!
by puredata
08/29/16 08:04 AM
Oil consumption early vs. late in OCI
by skaughtz
08/29/16 08:03 AM
Kaepernick disses national anthem
by grampi
08/29/16 07:19 AM
LazLong, gioburk, turrican, GGilbert, leje0306
58952 Registered Users
104 registered (1JZ_E46, 74Scout, 901Memphis, Al, 87sammy, AirgunSavant, 6 invisible), 1763 Guests and 9 Spiders online.
58952 Members
66 Forums
253721 Topics
#211680 - 01/27/05 06:58 PM Can you put grease on the strut mount bearings?
JoggingGuy Offline
Loc: Spring TX
I was curious if anyone has put grease on the front strut mount bearings or do they have to stay dry? The bearing between the upper spring seat and the strut mount. It would seem that if I replaced the rubber boot and it covers the whole rod area and seals off the spring seat too, you could grease this bearing without having it exposed to the environment. Hmmmm [Big Grin] [freaknout]
#211681 - 01/27/05 09:00 PM Re: Can you put grease on the strut mount bearings?
kenw Offline
Loc: Houston
Mine (toyota) had a slight amount of grease in them when I bought new ones.
#211682 - 01/27/05 09:57 PM Re: Can you put grease on the strut mount bearings?
Quest Offline
Loc: beaver land EH?
struts/shocks are designed to be self-lubricating. DO not introduce any foreign grease/lubricant that may get into the oil and upset it's chemical composition.
Try keeping your strut/shock shaft dirt-free is the only way to go.
#211683 - 01/27/05 11:57 PM Re: Can you put grease on the strut mount bearings?
JoggingGuy Offline
Loc: Spring TX
I'm not talking about the rod, I'm talking about that round bearing that sits between the upper spring seat and the upper strut mount. Here is a picture of the bearing: http://www.rockauto.com/ref/KYB/Detail.html?sm5110.jpg
#211684 - 01/31/05 12:40 PM Re: Can you put grease on the strut mount bearings?
BlazerLT Offline
Loc: Canada
I would do it!
I did it on my Escort and my strut bearing failures vanished.
#211685 - 02/01/05 10:48 PM Re: Can you put grease on the strut mount bearings?
JoggingGuy Offline
Loc: Spring TX
quote:
Originally posted by BlazerLT:
I would do it!
Hey Blazer,
How did those bearings fail? Did they just wear out or were they physically damaged during use?
#211686 - 02/01/05 10:55 PM Re: Can you put grease on the strut mount bearings?
BlazerLT Offline
Loc: Canada
Just more or less ground themselves to dust.
No lubrication whatsover and seeing they are in the wheel well, they got exposed a lot of grime and salt.
Grease them.
#211687 - 02/02/05 11:01 PM Re: Can you put grease on the strut mount bearings?
andyd Offline
Loc: Marshfield , MA
At about 225k, I replaced the front strut cartridges on my 88 BMW 528e. At that time, I re-packed the upper bearings with wheel bearing grease. MY wife's 86 needs the same treatment. I've been lubing them with white spray lube as a band aid.
#211688 - 03/09/05 09:38 PM Re: Can you put grease on the strut mount bearings?
bulwnkl Offline
Loc: Arizona
Yes, grease them. They are (should be?) at least very lightly oiled/greased from the factory. They won't fail nearly as quickly as wheel bearings, but they still need lubrication.
#211689 - 12/01/05 10:49 PM Re: Can you put grease on the strut mount bearings?
CelicaGT6 Offline
Loc: Santa Barbara, CA
I re-greased an old set of strut top bearings when I swapped in my new KONIs. I washed out the old grease and grim by soaking overnight in Simple Green.
After sufficiently cleaning it out such that no grit was felt, and it was completely dry, I packed the bearings with Redline's CV-2 grease.
As good as new. [Smile]
#211690 - 12/01/05 11:17 PM Re: Can you put grease on the strut mount bearings?
CelicaGT6 Offline
oops. double post.
