Spark plug tube gaskets
by supton
05/26/16 01:22 PM
IBM System I and 8" Floppy Disks for MDS
by MolaKule
05/26/16 01:20 PM
Replacing cap bolts- bolt strength?
by ford46guy
05/26/16 12:49 PM
What's worse? Walmart or eBay direct from China?
by CharlieBauer
05/26/16 12:30 PM
When did BITOG start?
by camrydriver111
05/26/16 11:56 AM
Equipment/Calibratio
n Tracking
by racer12306
05/26/16 11:55 AM
Microgreen Oil Filter 50% Off Discount Code
by kohnen
05/26/16 11:24 AM
Mobil Delvac 1 ESP 5w-40 for 2011 TDI?
by ruleof72
05/26/16 10:49 AM
Husquvarna YTH2046 riding mower
by Donald
05/26/16 10:47 AM
Any machinists?
by NavyVet88
05/26/16 09:28 AM
new XG750R flat-tracker
by Mik
05/26/16 08:55 AM
Walmart Supertech 5w20 full synthetic $8.12
by paulswagelock
05/26/16 08:51 AM
watergate528, iamtheanimal, 1991300sl, Rdyno, Darsahn
57993 Registered Users
91 registered (340six, Alfred_B, 2015_PSD, AirgunSavant, 1JZ_E46, 440Magnum, 9 invisible), 1809 Guests and 320 Spiders online.
57993 Members
66 Forums
249432 Topics
#2112308 - 12/20/10 08:45 PM Replaced '05 Suburban 5.3 water pump: easy DIY job
Islandvic Offline
Loc: South Texas
My 2005 Suburban Z-71 w/ 5.3 was leaking coolant yesterday. It was coming from bottom of pump.
About two months ago I flushed the system (DIY) with Prestone Radiator Cleaner then some new Prestone Dex-Cool.
I do not believe the flush had anyting to do with the leak.
I was able to buy from a wholesaler an OEM water pump, T-stat, gasket, and lower AC serpentine belt (all parts OEM AC DELCO) for $203 including tax. Reasonable to me.
Tools needed:
Channel Lock Pliars
3/8" drive socket wrench
Drive extension
15mm socket
10mm socket
Flat head screw driver
Thats it, very easy removal and instalation. I believe the same tools are needed for all GM full size trucks, SUV's.
I even found a 2 part youtube video. VERY informative.
The inside of the pump looked clean with no scaling or gunk build up.
Good luck
#2112320 - 12/20/10 08:55 PM Re: Replaced '05 Suburban 5.3 water pump: easy DIY job [Re: Islandvic]
Burt Offline
Loc: texas
Wonderful and glad to hear it. And they say cars are too hard to work on.
2011 RX350 38k miles
2015 Fiesta SFE eco-boost 7k miles
#2112341 - 12/20/10 09:24 PM Re: Replaced '05 Suburban 5.3 water pump: easy DIY job [Re: Islandvic]
finalyzd Offline
Loc: fairfield,CA
How long did it take you? Annd did you have to remove the fan clutch?
2007 Nissan 350z
Redline 0w30/M1-110
MT-85
Hummer H3
Pentosyn 5w30
Maxlife ATF
#2112402 - 12/20/10 10:31 PM Re: Replaced '05 Suburban 5.3 water pump: easy DIY job [Re: Islandvic]
dgee Offline
Loc: Connecticut
-___- i had to replace the water pump on my 96 Jeep 4.0 TWICE in ONE year. first one was faulty and cracked after 8 months.
12 Accord 2.4 4k - FF 0W20
01 Camry V6 265k - PU 10W30
96 Jeep ZJ I6 173k - Maxlife 10w30
94 Jeep ZJ I6 365k - Formula Shell 10W30
O||||||O
#2112588 - 12/21/10 08:00 AM Re: Replaced '05 Suburban 5.3 water pump: easy DIY job [Re: dgee]
cchase Offline
Loc: New England
And every time you do it, the job goes a little faster. I know the feeling.
#2112598 - 12/21/10 08:08 AM Re: Replaced '05 Suburban 5.3 water pump: easy DIY job [Re: Burt]
Vikas Offline
Loc: NorthEast
You are the first person who thinks Suburban is a C A R :-)
- Vikas
#2112660 - 12/21/10 09:20 AM Re: Replaced '05 Suburban 5.3 water pump: easy DIY job [Re: Islandvic]
Chris142 Online   content
Loc: apple valley, ca
Those pumps are super easy to replace! I've only replaced 1 due to the pump leaking. Usually the gaskets behind the pump leak. Most customers opt to replace the pump while I have it off to replace the gaskets.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#2113806 - 12/22/10 10:32 AM Re: Replaced '05 Suburban 5.3 water pump: easy DIY job [Re: Islandvic]
Islandvic Offline
Loc: South Texas
finalyzd, you asked about the fan clutch...
Mine has dual electric fans. I didnt have to remove them or the fan shrouds.
If I did it again, I could remove and replace in about an hour.
#2114013 - 12/22/10 01:57 PM Re: Replaced '05 Suburban 5.3 water pump: easy DIY job [Re: Islandvic]
Rhymingmechanic Offline
Loc: VA
I replaced the pump on a 2001 Silverado with a mechanical fan. That was an easy job EXCEPT for the fan clutch. None of the parts stores had the proper tool in their loaner program or for sale. I finally borrowed something from NAPA that worked when I rigged it up with two small bolts and some nuts and washers. A tool is needed to hold the pulley while you unscrew the clutch with a big crescent wrench.
The pump was leaking from the weep hole, but the gaskets looked pretty bad and could have been leaking, too.
