Electrical shock at the grocery store
by Merkava_4
05/30/16 11:42 PM
Another should I change my oil thread
by dan_erickson
05/30/16 10:53 PM
new HDM part number for lacrosse headlamp recall
by lucerne06
05/30/16 08:48 PM
snapper blade control is stiff
by edwardh1
05/30/16 08:44 PM
is my extension cord bad?
by motor_oil_madman
05/30/16 08:33 PM
Done with Sandisk USB Sticks
by JHZR2
05/30/16 08:20 PM
Pineapple Margaritas
by sleddriver
05/30/16 08:12 PM
Replacing Drywall In The Bathroom (Insulation)
by Warstud
05/30/16 07:56 PM
351W build with a flat tappet
by ssregal39
05/30/16 07:30 PM
Fuel injector cleaner that will run the engine?
by Red00Jetta
05/30/16 07:12 PM
Car's models of 1990 and now
by HTSS_TR
05/30/16 07:02 PM
Another dealer oil change story
by mclasser
05/30/16 06:36 PM
ph9, Kurt34556, Skullzaflare, Jakes_Lawn, Aarrghhh
58031 Registered Users
41 registered (CKN, andrewp1998, chrisri, clinebarger, bdcardinal, Abakev, 9 invisible), 750 Guests and 313 Spiders online.
58031 Members
66 Forums
249616 Topics
#2106925 - 12/15/10 02:47 PM Napa Gold vs Pure One
Deltona_Dave Offline
Loc: Deltona, FL USA
The photos are from a Napa Gold 1356 and a Purolator Pure One 14610. Both fit my Nissans. The 1356 is from my Titan, 7500 miles using 5W-30 Pennzoil Ultra. The 14610 is from the Altima, 4000+ miles using PYB 5W-30. I am not comparing the performance, but the media size and build of both.
Here is the 1356 opened. Silicone ADBV, Thread End Bypass. Coil spring for bypass. Media held up well. Thick Nitrile gasket. Large inlet holes.
PureOne Breakdown. Silicone ADBV, Funky bypass spring (looks like a 45rpm record adapter), Silicone gasket (thin), smaller inlet holes, but more of them. Media held with metal clip. Media held up fine.
Media comparison: PureOne on top, NG on bottom.
Base of 1356
NG's media. Seam is glued. Less pleats than P1 (I did not count, just eyeballed).
I would use either one with confidence. I like the P-1's grippy can, and silicone gasket. I like the NG's thick gasket, and coil spring for the bypass.
Right now I am experimenting with a XG7317 (gold can) on the Titan. Altima has a PL14610. The Extended guard seems to be a good filter and I got it for less than the NG. I will buy NG's when Napa has them on sale though. PureOne's seem to be the best bang for the buck on my Nissans.
Dave
Emergency Vehicle Technician Law Enforcement
2013 Hyundai Sonata GLS 2.4
2013 Kia Optima EX 2.4
2012 Mazda3 2.0 SkyActiv
#2106975 - 12/15/10 04:04 PM Re: Napa Gold vs Pure One [Re: Deltona_Dave]
Sayjac Offline
Loc: The Old North State
Thanks for the pics. What stands out immediately (like Bill's Subie filter pics) is the difference in media area. Thread end bypass takes up space. Might not mean anything, but it is impressive.
With you on the P1 texture, like it too. And some great deals on them at AAP, especially with online codes.
How do you get a XG for < Napa Gold? Either the NG is too high, or you got a deal on the XG.
#2107048 - 12/15/10 05:19 PM Re: Napa Gold vs Pure One [Re: Deltona_Dave]
AMC Offline
Loc: South Eastern, CT
Thanks for the comparison and the pics! I still don't think I like the combination of the tiny inlet holes holes and large, dense media element on the P1s. That is a tiny filter element on the NG though!
11 Chevy Silverado - PP 5w-30
10 Ford Focus - WH 5w-20
14 Yamaha Super Tenere - Delo 5w-40
1oz TCW-3 Per 5 Gallons of Fuel.
#2107071 - 12/15/10 05:34 PM Re: Napa Gold vs Pure One [Re: AMC]
ZeeOSix Offline
Loc: PNW
If you add up the area of all the small holes in the base plate they will be same or greater than the area of the main mounting hole in the base plate. Everyone looks at holes and automatically assumes they are restrictive ... LOL This goes for the holes in the center tube also, and the annulus area around the end caps. The guys who design filters make sure there isn't a "choke" point somewhere in the filter.
#2107089 - 12/15/10 05:45 PM Re: Napa Gold vs Pure One [Re: Sayjac]
My Dad picked up the XG at the Navy Exchange for just over 5 dollars. NG's are running about 7.50 locally.
I need to go back to skool. Both have 8 inlet holes. I am happy with either filter, but tend to lean on the P1 as they can be had cheaper with good deals at AAP or Amazon.
Dave
Edited by Deltona_Dave (12/15/10 05:48 PM)
#2111262 - 12/19/10 10:09 PM Re: Napa Gold vs Pure One [Re: Deltona_Dave]
pavelow Offline
Loc: Orange Park, FL
I think the Napa Golds and the Pure Ones are the best filters on the market. I use both and tend to go with whichever is on sale...right now I have a stockpile of Pure Ones to use up.
06 Pontiac GTO LS2
08 Chevy TrailBlazer SS LS2
#2111272 - 12/19/10 10:22 PM Re: Napa Gold vs Pure One [Re: Deltona_Dave]
j_mac Offline
Loc: wv
How do the AAP coupon codes work?
#2111297 - 12/19/10 11:04 PM Re: Napa Gold vs Pure One [Re: Deltona_Dave]
flyingtoaster Offline
Loc: Rancho Cucamonga, CA
The P1 I dissected had a solid rubber adhesive between the end plate and filter media that was absolutely impenetrable. It is easier to see when you clean the filter with gasoline.
2006 Honda S2000
Rotella T6 5w40, OEM Filter
Amsoil MTF
Amsoil 75w140
ATE SL.6
#2111377 - 12/20/10 05:37 AM Re: Napa Gold vs Pure One [Re: j_mac]
Sayjac Offline
Go the Advance site, pick your products, at checkout enter a code based on the amount spent, and see confirmation of code applied. Example, if BIG5 still works, one could get 3 P1's for ~$ 3.35 each, plus tax, with in store pickup.
fyi, there are many codes out there, some still work, some don't. All code threads are on the promo board, but here's some. HTH
http://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2095835#Post2095835
http://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2108031&page=1
http://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2091516&page=1
