Lowering vehicle with alternative coil springs
by OlDirty
25 minutes 30 seconds ago
Remington R1 1911 or Springfield 1911-A1 MIL-SPEC
by MuzzleFlash40
45 minutes 58 seconds ago
2017 Ford F150 3.5 EcoBoost
by DuckRyder
Today at 05:25 AM
Ford Powershift Gearbox Class Action (Oz)
by hpb
Today at 03:50 AM
Central Mississippi automotive goods
by mjoekingz28
Today at 02:11 AM
Free: 5 Quart jug Peak 5W-30
by Indyvwhonda
Today at 01:01 AM
Subaru Oil Burning Class Action
by Bandito440
Yesterday at 11:43 PM
'01 Toyota 3.0: oil to clean up sludge?
by HawkeyeScott
Yesterday at 11:06 PM
What is the purpose of a 4.4 litre oil container?
by vitez
Yesterday at 10:56 PM
Cut Open: Nissan OEM, Bosch D3300 & Mobil M1-110
by davison0976
Yesterday at 10:38 PM
Briggs and stratton flathead?
by pdxglocker9mm
Yesterday at 10:27 PM
Charcoal
by dlundblad
Yesterday at 09:43 PM
Palmer, jessanmark16, danbee, PTT, greasy_knuckles5
57790 Registered Users
70 registered (2015_PSD, AirgunSavant, A_Harman, bbhero, 2002 Maxima SE, beanoil, 11 invisible), 896 Guests and 297 Spiders online.
57790 Members
66 Forums
248441 Topics
Page 1 of 2 1 2 >
#2104795 - 12/13/10 01:29 PM BMW Tire Rotation
Chester32141 Offline
Loc: USA - Florida
My wife's Z4 has the same size tires on the front and back. The dealer told her she should not rotate her tires. They carry slightly different pressure (32/35) ... if she rotates now she can probably go another year or two w/o new tires. If she waits she will need new tires on the back soon ... They are run flat tires w/ the low pressure warning system .... am I wrong in thinking rotating these tires would be a good idea ?
Thank you for any and all input ... cool
#2104798 - 12/13/10 01:31 PM Re: BMW Tire Rotation [Re: Chester32141]
exranger06 Offline
Loc: Guilford, CT
I really don't see why you couldn't rotate them. They're probably directional tires, so just swap them front to back. If the TPMS is like my mother's BMW, it uses the ABS sensors to sense different rotation speeds, so it shouldn't throw any warning lights.
2006 Ford Ranger Sport
1992 Honda Accord EX
1994 Ford Bronco XLT (project)
2014 Subaru XV Crosstrek (wife's)
#2104815 - 12/13/10 01:45 PM Re: BMW Tire Rotation [Re: Chester32141]
Quattro Pete Offline
Loc: Great Lakes
The reason BMW typically advises against tire rotation is that often times rear alignment has some negative camber which causes uneven wear on back tires. If you put those tires on the front, you may experience less than perfect handling (may not be of any concern to some), plus they may become noisy.
But if your rears are worn evenly, then I think I'd attempt rotating them and see what happens. If you don't like it, you can always rotate them right back.
I rotate the tires on mine, but my alignment has been adjusted slightly so that the negative camber is only very slight.
'02 530i (PPE 5W-40)
'15 Q5 3.0T (Edge 5W-40)
#2104830 - 12/13/10 01:59 PM Re: BMW Tire Rotation [Re: Chester32141]
Trajan Offline
Loc: SE PA
What QP said.
I don't bother, due to staggered sizes.
Lack of harm is not proof of benefit.
There are in fact two things, science and opinion; the former begets knowledge, the later ignorance. Hippocrates
#2104834 - 12/13/10 02:06 PM Re: BMW Tire Rotation [Re: Chester32141]
BobFout Offline
Loc: Indiana
Rather than relying on what the dealer says, what does the owner's manual say?
2003 VW Jetta TDI (Sold) / 2015 VW GTI 2.0T
#2104857 - 12/13/10 02:33 PM Re: BMW Tire Rotation [Re: BobFout]
d00df00d Offline
Loc: PA
+1
2011 Mazda RX-8 R3
Castrol GTX 5w-20
#2104860 - 12/13/10 02:35 PM Re: BMW Tire Rotation [Re: Chester32141]
Eddie Online   happy
Loc: Florida, Cape Coral
I read that to maintain maximum performance BMW recommended rotating tires every 3,000 miles. BMW figured that the cost of doing that would would be prohibitive for a daily driver, hence don't bother. They said it takes several thousands of miles for rotated tires to adjust to the new position and during that time a decrease in cornering performance would be evident. Unless you need racing performance, I would rotate every 7-10K miles or so in a RWD recomendation or if anything is in the owners manual, I would folow that.
CX5 Touring 2.5L :-)
#2104873 - 12/13/10 02:51 PM Re: BMW Tire Rotation [Re: BobFout]
Loc: Great Lakes
Absolutely nothing.
#2104875 - 12/13/10 02:55 PM Re: BMW Tire Rotation [Re: Quattro Pete]
Jim 5 Offline
Loc: Calgary Canada
I agree. Also, staggered wheel set-up is fairly common especially on sport package equipped bmw's. I think they say no tire rotation is recommended also for this reason.
My BMW had the same tire/wheel size front/rear and I found the outside edge on the front would wear a little more (not too bad) and the inside edge on the rears would wear due to a little negative camber as well as the center of the tread would wear due to a happy accelerator pedal. Switching fronts to rears and vice-versa helped ensure I got mostly all the tread from a set of tires. I wouldn't hesitate to do it in your situation.
Jim A
07.5 GMC Sierra 2500HD LMM Rotella 15w-40
09 Odyssey EX-L CT 5w-20
66 Bronco QS 10w-30
08 BMW K1200S Rt 15w-40
08 Pitster Pro X4 Rt 15w-40
#2104880 - 12/13/10 02:59 PM Re: BMW Tire Rotation [Re: Quattro Pete]
UG_Passat Offline
Loc: NJ
Higher Rear neg camber isn't a reason why you should not rotate the tires, because most cars these days have the rear cambers more negative than the front. If you rotate them too late... then rotating them up front don't so squat.
Originally Posted By: Trajan
What QP said.
It's due to the staggerred sizes. If they are directional tires, then you cannot rotate at all.
If the tread is assymetric, you can rotate them side to side.
#2104917 - 12/13/10 03:37 PM Re: BMW Tire Rotation [Re: UG_Passat]
Loc: Great Lakes
But the OP does not have a staggered setup:
BMW's stance is not to rotate, regardless if you have a staggered setup or not.
#2104970 - 12/13/10 04:49 PM Re: BMW Tire Rotation [Re: Chester32141]
PandaBear Offline
Loc: Silicon Valley
Ignore what they say, if you have same size front/back, just rotate as much as you like front/back. If your tire is not directional, rotate any way you like. Just make sure to adjust tire pressure afterward and do it frequently, and all is well.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
#2104978 - 12/13/10 04:55 PM Re: BMW Tire Rotation [Re: Quattro Pete]
UG_Passat Offline
Loc: NJ
I missed the OP saying that part. BMW's stance is because most owners are suckered into buying new tires all the time, due to uneven front to rear wear.
the camber is [censored], because VW recommends tire rotation on my Passat, even though the front camber is about -0.5 degress and the rear camber is -1.5 degrees. However, the tire rotations coincide with the 10,000 mile oil change interval-- which is way too long of an interval
#2105003 - 12/13/10 05:25 PM Re: BMW Tire Rotation [Re: Chester32141]
Craig in Canada Offline
Loc: Toronto-ish, Canada
I have an E39. I used to rotate. Even representatives from the tire manufacturers told me to rotate as long as I do it often. I would rotate every 2,000mi or so since it was easy for me to do.
Two things made me stop rotating:
1/ The E39 forum where I participate has a member who moved to Europe from the US. He shares nuggets of wisdom about how things are different "over there". One of the things he pointed out was that NO ONE rotates their tires (at least on BMWs) in Europe because they cause strange high speed handling and stability problems.
2/ I was always chasing quirkly little handling and stability problems. They weren't major, but I noticed and it bugged me. One time I was doing a routine rotation on my summer tires (Toyo T1R at the time) and I was rotating back into the positions they were in when I first put them on the car. Yes, I properly set the pressures back to exactly the same F/R pressures and splits as before I rotated. I felt an immediately change in the car - improved turn in, faster steering response and better stability. It was as if I had an alignment problem fixed or upgraded some component in the suspension.
Between these two points, I was sold. The manufacturer knows what they're talking about and I'm not going to second guess them any longer. Others have provided proof (all of Europe, apparently) and I've witnessed it firsthand at North American speeds. I won't be rotating tires on any BMW again. I'm now on a new set of tires (Michelin PS2s) and they haven't "gone off" or developed any quirky issues in the two seasons I've run them.
I know everyone won't agree, but I'm sold... If you bought a BMW for handling, stability, performance, etc.... don't rotate IMO. Maintain the car to get the most from your tires - keep your alignment in order, watch for wearing bushings and balljoints, watch your tire pressures - and replace them when needed. Some people will dial the rear camber to the most neutral allowed by the spec (instead of the center of the range) to extend rear tire life.
Edited by Craig in Canada (12/13/10 05:30 PM)
#2105005 - 12/13/10 05:28 PM Re: BMW Tire Rotation [Re: UG_Passat]
Loc: Great Lakes
Well it's not like this causes them to have to buy more tires. They just buy them two at a time, not 4 at a time.
Page 1 of 2 1 2 >
