Hypothetical Question On Incorrect Filters
by Triton_330
05/25/16 12:18 AM
Pennzoil $2.99/qt at tractor supply!
by Chris142
05/24/16 10:25 PM
Brother passed away this morning
by oilboy123
05/24/16 10:21 PM
Changed oil tonight - what a fine evening
by pacem
05/24/16 10:10 PM
Interesting observation on Ultra
by RusskiBoSS
05/24/16 08:48 PM
2009 Honda Civic Cooling fan running continuously
by Doog
05/24/16 08:31 PM
adhesive for pea gravel?
by xfactor9
05/24/16 08:19 PM
Micro guard Gl14609 150 hours
by robo339
05/24/16 08:02 PM
walking thru a Harbor Freight is better than sex
by turtlevette
05/24/16 07:58 PM
'14 Durango 3.6L, PUP 5w20, 7.5k, TBN/TAN
by Mantooth
05/24/16 06:59 PM
Advice: Odyssey or Sienna?
by Barwich
05/24/16 06:43 PM
Any HR specialists out there?
by bustednutz
05/24/16 06:23 PM
Hokie_Dave, ant3a, afterburnerbg, SupraSaiyan, Bighorn2500
57973 Registered Users
36 registered (Andy636, 2015_PSD, bdcardinal, Barwich, 1977c10phxdriver, 901Memphis, 3 invisible), 837 Guests and 106 Spiders online.
57973 Members
66 Forums
249370 Topics
#210246 - 09/07/02 12:44 AM GREASE BLEEDING
mikeyoilnutt Offline
Loc: San Bruno, CA
DOES ANYONE KNOW WHAT CAUSES GREASES TO BLEED? I UNDERSTAND IT IS WHEN THE OIL
SEPARATES FROM THE THICKENER, BUT WHY DO SOME GREASES BLEED WHILE OTHERS DO NOT.
BOUGHT SOME AMSOIL SERIES 2000 GREASE AND LOADED IT TO MY GREASE GUN AND 2 WEEKS
LATER THE GREASE WAS BLEEDING HEAVILY OUT THE BACK OF MY GREASE GUN FROM WHERE I
HAD IT HANGING. WHAT CAUSES THIS. THANKS, MIKEYOILNUTT.
#210247 - 09/07/02 01:43 AM Re: GREASE BLEEDING
MolaKule Offline
Loc: Iowegia - USA
I have the same thing happening my supply of Racing Grease and I position the gun down where the "grease out" side for the snorkel is down.
Grease is a "porous" mixture and oil globules do seem to migrate or "diffuse" through the thickeners. I have yet to see a grease that doesn't do that when stored in a hot area, such as my steel shed. I usually take a paint stirring stick and remix the oil and thickener in a large plastic bowl before loading into a grease gun.
#210248 - 09/07/02 02:09 AM Re: GREASE BLEEDING
GeorgeCLS Offline
Loc: Columbus, Ohio
Rule #1, especially with synthetic greases, is to back off the plunger from your grease gun when not in use! ALL grease is made to 'bleed' to some degree. Greases are generally composed of 90% oil and 10% "thickener" or sponge. When you squeeze a sponge with oil in it, the oil will come out in liquid form. Same with grease. Squeeze it as in a bearing and the oil will come out and lubricate; we are lubricating with oil just as if you had an oil can and were applying oil drops at a time. When the pressure is off the grease, the sponge or thickener soaks the oil back into the body/sponge. Synthetic greases may be a little more prone to do this in a grease gun that has been left cocked/loaded as, in the case of the Amsoil, a pretty thin base oil probably used in the grease and the PAO base oil may have softened or shrunk the rubber seal a bit.
Back to rule #1. Irrespective of whether it is syn or mineral, always back the plunger off completely when the gun is not in use. If not, you will find the grease's lubricant, the oil, on the floor of your oil room and may be left with nothing but thickener in the gun. Thickeners do not lubricate well...
George Morrison, STLE CLS
#210249 - 09/07/02 04:49 AM Re: GREASE BLEEDING
Loc: San Bruno, CA
GEORGE GLS, THANKS FOR THE INFO ON THE GREASE PLUNGER. I DID NOT KNOW THAT. MIKEYOILNUTT
