this is a uoa of a 1997 ford crown victoria. the car had 86,009 at time of change .6 months and 7171miles on oil. the car is in perfect running condition. didnt add any make up oil but At the time of change it was about a qt low in oil. motorcraft oil filter
the car is driven with good care. i drive it like a granny. i have went WOT 3 times since i brought the car in july with 78k miles. stay in texas so its pretty warm, but north texas does get 30F - 40F cold at times
Currently running German Castrol 0w30 With pureone oil filter. I’m try to push it between 12k and 15k and do a uoa
BlackStone Comments
KELVIN: What a great engine! This oil was in use 7,171 miles, but the viscosity didn't degrade and the oil didn't
overly oxidize (insolubles were low at 0.2%), so the oil held up really well. Universal averages show typical wear for
this engine type at 4,600 miles on the oil. Wear metals read low, which suggests no wear-related issues inside the
engine. The high silicon likely isn't dirt since wear is low, but check air filtration, just in case. It's probably from excess sealer or lube; both are harmless. The 2.7 TBN shows some active additive left (1.0 is too low). Use 9K next.
The Universal Averages are the second row of numers
Aluminum 4 3
Chromium 1 1
Iron 18 14
Copper 7 5
Lead 0 2
Tin 1 0
Molybdenum 93 62
Nickel 1 1
Manganese 0 2
Silver 0 0
Titanium 0 0
Potassium 1 1
Boron 45 56
Silicon 27 15
Sodium 11 21
Calcium 2551 2193
Magnesium 15 112
Phosphorus 675 702
Zinc 718 850
Barium 0 1
The second row of numbers are what they should be
Sus viscosity @210’F 62.2 / 58-68
Cst viscosity @ 100’C 10.84 / 9.7-12.7
Flashpoint in ‘F 425 / >365
Fuel% Antifreeze% 0.0 /0
Water % 0.0 /0
Insolubles % 0.2 / Tbn 2.7
BlackStone Comments
Aluminum 4 3
Chromium 1 1
Iron 18 14
Copper 7 5
Lead 0 2
Tin 1 0
Molybdenum 93 62
Nickel 1 1
Manganese 0 2
Silver 0 0
Titanium 0 0
Potassium 1 1
Boron 45 56
Silicon 27 15
Sodium 11 21
Calcium 2551 2193
Magnesium 15 112
Phosphorus 675 702
Zinc 718 850
Barium 0 1
Water % 0.0 /0
