A brief BMW R1100RT story
by Finn
05/28/16 02:29 PM
2015 6.7L Powerstroke Fuel Filter Change
by 2015_PSD
05/28/16 12:51 PM
Caliper question
by supton
05/28/16 12:48 PM
Impressed with Yokohama Geolander A/T G015
by K20FA5
05/28/16 12:13 PM
Need a good tire pressure guage that read over 60
by MetalSlug
05/28/16 11:55 AM
Castrol 0w40 vs M1 0w40 FS ?
by Ndx
05/28/16 11:14 AM
what old Snapper parts to save
by edwardh1
05/28/16 10:56 AM
Interesting lunch hour
by Urshurak776
05/28/16 10:10 AM
Oil and filter for 2010 Ford Taurus Limited
by MetalSlug
05/28/16 10:00 AM
New Hvac Install
by AirgunSavant
05/28/16 08:32 AM
'14 Accord - Honda 0W20 - High vis or lab error?
by vvolcano
05/28/16 08:18 AM
Your old ticker, take care of it
by CourierDriver
05/28/16 07:58 AM
mungchimp, troutwest66, AIRJAC3, bpete65, LEVY
58001 Registered Users
72 registered (4wheeldog, AandPDan, 97f150, 3800Series, 2015_PSD, 007, 6 invisible), 1801 Guests and 324 Spiders online.
58001 Members
66 Forums
249525 Topics
#2097461 - 12/06/10 01:36 PM M1-105 purolator interchange oil filter
Radman Offline
Loc: Detroit, Michigan
I use an oversize Mobil 1-105 filter on my Nissan cars. I would prefer to use a Purolator One. Purolator doesn't have a direct cross reference filter that I can find to match the gasket size on the M1-105. Fram has the 7317 which has far less area than the oversize Mobil. What Purolator filter is a close match to the Mobil?
2006 Maxima 120K M1-105, M1 0W40
2006 Sentra 90K M1-105, GTX 5W30
2010 Altima 20K M1-105, GTX 5W30
2013 Yamaha FZ1 1K PL1410, SRT5 15W40
#2097515 - 12/06/10 02:32 PM Re: M1-105 purolator interchange oil filter [Re: Radman]
chubbs1 Offline
Loc: Merritt Island FL, USA
PL14610 is what I have used. That is the cross to the m1-110. I use the Honda equivalent. There is only a Puro CLASSIC that will come close to that spec. L10193 or WIX 51318. I go longer you go fatter I guess. You might as well stick to those M1-105's.
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#2097630 - 12/06/10 04:29 PM Re: M1-105 purolator interchange oil filter [Re: chubbs1]
KurtJ Offline
Loc: Longview, TX
There is a Pure1 PL10193, with nearly the same dimensions as the Classic L10193, however, its bypass is rated 8-16 psi compared to 15-18 for the Classic.
1999 Toyota Tacoma 3.4L V6 4WD M/T
2010 Hyundai Santa Fe 3.5L V6
#2098470 - 12/07/10 01:25 PM Re: M1-105 purolator interchange oil filter [Re: KurtJ]
Radman Offline
@Kurt & Chubbs ~ Thank you for the cross refernce Purolator numbers. The M1-05 work on both my Nissans. It is always nice to have options and I consider the Purolator One line to be top quality. The can dimensions are similar but it is the gasket dimensions that concern me the most. Have either of you used this on a Nissan application?
#2099132 - 12/08/10 07:45 AM Re: M1-105 purolator interchange oil filter [Re: Radman]
chubbs1 Offline
I personally have not, Nissan stuck a piece of metal to "protect" the oil filter, and I cant go much wider on my altima. The Maxima and Sentra are different year/design so I would just say stick with the M1, You could easily use them for two OCI's. The newer altima's are spec'ed for a filter that is so small it is laughable (it's a motorcycle filter) I just use the filters I use on the Honda's which are at least a little bigger/Longer.
I would be pretty sure that the P1/WIX would fit your car. It crossed over on two websites I used. If it doesn't take it back.
'12 Charger SXT
'12 Charger SXT
#2099572 - 12/08/10 02:24 PM Re: M1-105 purolator interchange oil filter [Re: Radman]
KurtJ Offline
Loc: Longview, TX
I never used one on a Nissan either, sorry.
#2102466 - 12/11/10 05:07 AM Re: M1-105 purolator interchange oil filter [Re: Radman]
Char Baby Offline
Loc: Western NY
The largest filter(and it was quite large) that Purolator had made for a Nissan was #24458 and it has been discontinued. Next is the #14459 and after that is the #14610. I'm sure that there are other numbers that will fit but I am unaware of them at this time.
Each time that I tried oversizing filters on my 04 Altima 2.5s, there seem to be more startup rattle. So, I continue to use the #14610 with the best results.
"Retired"
'80 Firebird FORMULA V8/4bbl-NEW
'06 Mazda 3i 2.0L-Pre Owned
'15 Nissan Altima 2.5 SV-CPO
Still looking for a car for my wife(new, used, CPO)
#2102880 - 12/11/10 02:16 PM Re: M1-105 purolator interchange oil filter [Re: Char Baby]
ZeeOSix Offline
Loc: PNW
FYI ... it was discovered that the 14610 has more media area than the 14459. 14610 @ 105 sq-in and 14459 @ 85 sq-in.
http://www.bobistheoilguy.com/forums/ubb...774#Post2098774
#2103483 - 12/12/10 07:37 AM Re: M1-105 purolator interchange oil filter [Re: ZeeOSix]
Char Baby Offline
Loc: Western NY
This is good to know. I often get the 14459 when I can't find the 14610 during an oil/filter special/sale. I think I'll try to stay with the 14610 when possible. Lately, I've been getting almost no start up rattle with either filter but, most of the time the 14610 gives me the least start up rattle of the two.
"Retired"
