Avoiding short trips like the plague
by FordCapriDriver
06/25/16 03:11 AM
API CK-4
by JustPlainFolks
06/25/16 02:37 AM
Rotella T
by momo
06/25/16 01:51 AM
3,000 mile OCI/severe service/newspaper delivery?
by Aurora09
06/24/16 11:46 PM
move over esters...time for alkylated napthenes
by Shannow
06/24/16 10:46 PM
ear wax and ear plugs
by motor_oil_madman
06/24/16 09:26 PM
Discount Tire Direct 4th of July Sale
by sopususer
06/24/16 08:37 PM
What kind of oil drain plug gasket is this?
by Chris B.
06/24/16 07:36 PM
by Chris B.
06/24/16 07:34 PM
First time changing oil what to use ?
by sshazam
06/24/16 07:13 PM
toshiba 720p 28" TV hdmi to thinkpad vga cable?
by bmwjohn
06/24/16 06:48 PM
1988 Brougham
by momo
06/24/16 06:38 PM
accobra66, Diehl, Hotrodls1, Koloa, codeman021
58257 Registered Users
39 registered (04SE, chrisri, claluja, b1amgm47, Char Baby, bbhero, 6 invisible), 641 Guests and 10 Spiders online.
58257 Members
66 Forums
250769 Topics
#2085673 - 11/24/10 07:08 AM HHR steering column problem
Roscoe10 Offline
Loc: Alabama
Have an 06 Chevy HHR with annoying thumping, popping sounds coming from underneath the front floorboard. Mechanic says it's the steering column. A check of internet forums on the HHR confirms a significant steering column problem with these cars,as well as the Cobalt, Chevy Malibu and certain Pontiac series. Has anyone had to deal with this problem? If so, what was the cost. Service manager at local Chevy dealer says new steering column and labor runs about 700.00 to 800.00. Is repair very complicated and beyond the capacity of average DIY'er?
#2085703 - 11/24/10 07:46 AM Re: HHR steering column problem [Re: Roscoe10]
qdeezie Offline
Loc: Charlotte, NC
I thought GM had a recall on the steering column. You might want to check on that. I have a friend that has an Impala around that year range that had a recall.
#2085712 - 11/24/10 07:57 AM Re: HHR steering column problem [Re: Roscoe10]
Roscoe10 Offline
Loc: Alabama
GM replaced tons of these under warranty and have sued the manufacturer of the steering columns for 30 million which they claim to have spent on warranty replacements. They do have a recall on the electric steering motor for some cobalts but not the HHR. I'm out of warranty so the cost is on me.
#2085720 - 11/24/10 08:06 AM Re: HHR steering column problem [Re: Roscoe10]
SaturnIonVue Offline
Loc: New Orleans, LA
It sounds as if your issue has been over diagnosed a little. The problem usually in several GM vehicles is not the steering column itself but the intermediate shaft(s). These are the "U-joint" like linkages on either end of the steering column where it goes through the firewall. One, or both may be making the noise. You can figure which one is the problem by having a friend move the steering wheel in a way to make the sounds, while you listen for it under the dash or under the car.
GM, for some reason can't seem to master making and using these things right and the issue has been around for a long time. That popping-thumping sound that you hear is not dangerous but it is very annoying! Please don't get taken for a ride by a repair shop because I would bet a dime against a doughnut that that is the problem. GM often recommends (at least for my Aura) that the shaft be lubed with some "magic lube" and not to replace the part! YMMV. I wouldn't try a repair myself. It won't be cheap at a dealer.
Edited by SaturnIonVue (11/24/10 08:08 AM)
`16 Elantra
`08 Saturn AURA XE, 4Cyl 2.4L - Sold
`06 Saturn VUE, 4Cyl 2.2L - Totaled!
Oil: 5W-30 Quaker State Ultimate Durability & OEM filters.
#2085779 - 11/24/10 09:18 AM Re: HHR steering column problem [Re: SaturnIonVue]
Roscoe10 Offline
Loc: Alabama
Did the magic lube work to reduce/eliminate the noise?
#2085827 - 11/24/10 09:57 AM Re: HHR steering column problem [Re: Roscoe10]
FowVay Offline
Loc: Southeastern USA
My mom's Impala had a clunking sound and it was the little u-joints on the steering shaft. I crawled under the dash and squirted some Penetro-90 on both of the joints and it's been noise free for about 3 years now. I had to remove a under-dash plastic cover to gain access but otherwise it was a easy task.
#2086572 - 11/25/10 03:48 AM Re: HHR steering column problem [Re: Roscoe10]
Actually, I don't know if the "magic lube" actually worked or not to fix the problem. As I recall, it was a bullitin saying not to replace the intermediate shaft but to lube the shaft with a specific lube and gave the GM part number.
`16 Elantra
#2086584 - 11/25/10 05:30 AM Re: HHR steering column problem [Re: Roscoe10]
JustinH Offline
Loc: Texas
LOL. There is no magic lube. It is chassis grease applied with a zerk needle into the fitting.
My ion has the same problem. It is the intermediate shaft, about a $120 part from the dealer. Mine has required grease about once a year for two years now, then the problem goes away.
It is a little U joint that connects part of the steering shaft together.
'10 Toyota Rav4 Sport
'08 Toyota Matrix
#2092094 - 12/01/10 12:17 PM Re: HHR steering column problem [Re: Roscoe10]
bigmike Offline
Loc: Florida
The intermediate steering shafts are a problem for a bunch of vehicles. My dad's Malibu sounds awful, but he just lives with it. My truck had the shaft replaced with an upgraded or newer model, via a TSB. It still makes noise but not as much.
They're just greasing the splines. It probably won't last all that long, maybe 6 months to a year? Depends on the grease used and how long it takes to work out of the splines. It's a bandaid fix.
Take care,
-Mike
2006 Chevy Silverado LT 4.8 - QS 5w30, Napa Gold
2009 Honda Accord LX-P 2.4 - QS UD 0w20, P1 14610
