Will ATP205 help with a head oil leak
by NattyBoh
15 minutes 36 seconds ago
Why is 100% gas more expensive in the city?
by TurboFiat124
20 minutes 26 seconds ago
Trouble getting a copper pipe sweat fitting sealed
by NateDN10
28 minutes 40 seconds ago
Murphy oil
by TurboFiat124
33 minutes 21 seconds ago
I think I'm getting pure gas again
by eljefino
57 minutes 37 seconds ago
CV boots ripped on Chevy Blazer
by dlundblad
Today at 07:02 PM
Built-in pour spout on Delvac jugs
by fdcg27
Today at 06:45 PM
Mobil 1 question
by Moondawg
Today at 06:36 PM
Mold & Moisture Resistant Drywall
by Warstud
Today at 06:36 PM
FRAM EG 3614, 5,000 miles, CUT OPEN
by car51
Today at 06:25 PM
FRAM XG2, 10,xxx miles CUT OPEN
by car51
Today at 05:33 PM
MC FL-820S, 7.6K miles, 2012 F-250
by car51
Today at 04:41 PM
NJ1911, SneakyTacos, DaveD, 8o8is, Texasdude74
58584 Registered Users
113 registered (182RG, 2015_PSD, 4WD, 69GTX, 901Memphis, 7 invisible), 1784 Guests and 14 Spiders online.
58584 Members
66 Forums
252208 Topics
#2075053 - 11/12/10 04:05 PM Difference between 85W-90 and 75W-90 gear oil?
lairdwd Offline
Loc: Boston
I just did a drain and fill on my 93 beater altima manual transmission. The stuff I pulled out was 75W-90 GL4 from 10 years ago. It was pretty bad.
I replaced it with NAPA sta-lube 85W-90 GL4. That stuff was thick! I'm wondering if it's too thick for the New England winters. My owners manual indicates 75W-90 and 80W-90 are good for +40F to -40F. It lists 85W, but I don't know if that's the same as 85W-90.
Edited by lairdwd (11/12/10 04:05 PM)
#2075057 - 11/12/10 04:09 PM Re: Difference between 85W-90 and 75W-90 gear oil? [Re: lairdwd]
Drew99GT Offline
Loc: Colorado Springs
It's likely going to make shifting impossible in cold weather and make a huge dent in fuel economy. I'd get some 75w-90 in there.
#2075071 - 11/12/10 04:17 PM Re: Difference between 85W-90 and 75W-90 gear oil? [Re: lairdwd]
qdeezie Offline
Loc: Charlotte, NC
You should get that stuff out of there as soon as possible and go back with 75w-90.
#2075093 - 11/12/10 04:42 PM Re: Difference between 85W-90 and 75W-90 gear oil? [Re: lairdwd]
unDummy Offline
Loc: RI
There is no need to change it out. Keep it unless it becomes unbearable.
Shouldn't be too bad. I've used the 85w90 year round. It'll be a tad slow the 1st couple shifts during the couple weeks of the Northeast freeze wave every Jan/Feb. Rest of the year was fine.
A bottle of Lubegard gear oil supplement can make up for the cold stiffness.
Those who say it cannot be done, should not interrupt the person doing it.
Your automaker lied!
Is this a spelling/grammar forum or BITOG?
#2075102 - 11/12/10 04:51 PM Re: Difference between 85W-90 and 75W-90 gear oil? [Re: unDummy]
lairdwd Offline
Loc: Boston
Shouldn't be too bad. I've used the 85w90 year round. It'll be a tad slow the 1st couple shifts during the couple weeks of the Northeast freeze wave every Jan/Feb. Rest of the year was fine. A bottle of Lubegard gear oil supplement can make up for the cold stiffness.
Thanks folks. Any chance this will congeal and provide no protection in say the few days a year it goes below 14F? I really don't want to pull it all out unless I'm causing risk to the transmission.
#2075104 - 11/12/10 04:53 PM Re: Difference between 85W-90 and 75W-90 gear oil? [Re: unDummy]
chubbs1 Offline
Loc: Merritt Island FL, USA
I'm gonna side with you on this, Before you change everything out just wait and see, you should be fine. I have direct experience with the cold and gear-oil even though I live in FL now. tongue2
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#2075112 - 11/12/10 04:59 PM Re: Difference between 85W-90 and 75W-90 gear oil? [Re: lairdwd]
tinmanSC Offline
Loc: Oswego, IL
I did the same thing on my manual Lexus SC300. I put in a oil that was thicker than called for (this is actually a very long story and frustrating, I will not infuriate you with the details) I ended up draining it in the middle of winter in my garage -- VERY COLD! -- and putting in 75W-90. Shifting was a problem on cold mornings, the oil change resolved the issue. I cannot stay that you will have the same problem, but this is my experience.
Cost of Hobby=2L
(Where L=Cost of Lubricant)
95 Lexus SC300 [email protected], 2000 [email protected] both VML Full Syn+Purolator PSL20195(soon to be Wix)
#2075149 - 11/12/10 05:40 PM Re: Difference between 85W-90 and 75W-90 gear oil? [Re: lairdwd]
aquariuscsm Offline
Loc: South Texas,USA
That`s the same gear oil chart that`s in my car`s manual. Get some Amsoil MTG.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Syntec 10W40/Fram Ultra
Amsoil MTG(tranny)
Amsoil 80W90 GL5(rear diff)
Mobil 1 ATF
Redline Water Wetter
#2075651 - 11/13/10 11:15 AM Re: Difference between 85W-90 and 75W-90 gear oil? [Re: aquariuscsm]
lairdwd Offline
Loc: Boston
So far so good. It's definitely a bit stiff, but seems ok when it warms up. Contrary to the gear oil spec chart in the OP, I have read that 85W-90 is good all the way to 0F, and this post indicates sta-lube flows pretty good for an 85 weight oil.
BTW, I do see that NAPA also has a GL-3/GL-4/GL-5 80W-90 for $3.29 a quart. I probably should have used that, but I wanted to stick with GL-4 only.
One thing for sure though is that I will have to alter my downshifting habits. I like to downshift a lot and use the engine as a brake. Can't do that if it's too stiff. Maybe I'll take the advice and get the lubegard gear oil additive.
It was down almost a quart, and now shifts much smoother. Hopefully will add life . Would like to get 25 years of service out of this vehicle before sending it off to the crusher
#2075717 - 11/13/10 12:31 PM Re: Difference between 85W-90 and 75W-90 gear oil? [Re: lairdwd]
mechtech2 Offline
Loc: Chicago Area
Your old oil was beat up and sheared to a thinner viscosity.
Also drained when warm?
So of course the new stuff will appear thicker.
The differences are small between 75-80 and 85-90 [everything else the same].
I am not sure that that particular lube is the best for manual trannys.
Wear should be good, but good shifting is not addressed.
#2076178 - 11/13/10 11:28 PM Re: Difference between 85W-90 and 75W-90 gear oil? [Re: lairdwd]
Loobed Offline
Loc: Northern California, USA
I didn't know they made 75w gear oil in 1993.
I think the only difference is cold viscosity. They should both be a 90 weight when up to operating temps. Your 1993 gears are probably loosey goosey, and the heavier oil might be unnoticable or even better.
Engine: 2001 GM 5.3L LM7
Current Fill: Valvoline Synpower 5w-30 w/Pure-One PL25288 filter
I.M.N Oil Enthusiast
#2078029 - 11/15/10 08:24 PM Re: Difference between 85W-90 and 75W-90 gear oil? [Re: Loobed]
lairdwd Offline
Loc: Boston
So far so good. After it heats up, it's very nice. Man, I did not realize how shot my old oil was. But those Altima's are rock sold man, despite my lack of education on gear oil changeover. No cheap parts in the transmission like the Honda garbage, so I think it's probably ok, despite the abuse.
With the new gear oil in, it's very smooth. Prior to that, I could not get a smooth transisition between shifts no matter how delicate I was with the clutch. It would always give that knocking sound like when you let the clutch out too fast without accelerating enough. That's what motivated me to do the fluid changeover. Glad I did.
