This oil was run from 04/19/10 until 10/15/10. It was 10W-30 PP with a Napa Gold oil filter. My last UOA looked good enough that I decided to run the oil longer this time. I went about 4-5000 miles past the point where my dummy light for my OLM went off. It does not show a % for my car.
I drive pretty gentle most of the time.
Wix air filter. Air filter changed at 110k, 120 & 130k miles on the odo. I'm changing it every 10k now.
Blackstone Coments:
This is the longest oil run yet for the 3.8L in your Grand Prix and lead (from bearings) increased quite a bit. Universal averages show typical wear levels for this type of engine after about 4,700 miles on the oil. All other wear looks pretty good, so we're not sure why lead is high. If any leaded fuel or octane booster was used, that might explain it. Or maybe you're racing. The TBN was strong at 4.6, but we can't recommend going more miles on the oil with lead increasing. Watch your oil pressure and check back in 8,000 miles. Hopefully a shorter oil helps lower wear.
Comments welcome. I've got PP 5W/30 in it now with a NapaGold oil filter and plan to run it a shorter amount, maybe 3 changes per year instead of trying for twice a year like this run. Actually I might do a much shorter run of 5k or something just to see if the lead will drop. Lead is up quite a bit which doesn't make me happy. Still no sign of a return of the intake gasket coolant leak that was repaired in the spring of '08. Hopefully it is gone for good. My other car had high lead with PP this last time as well. Maybe PP has changed or the fuels where I live are giving me grief, who knows. Or maybe I should go back to the days of 3k mile oil changes, jk.
Code:
OIL PP 10W30 PP 5W30 PP10W30 PP10W30 PYB10W30 PP5W30 M110W30 M110W30
MILES IN USE 11.8k 9.8k 7.4k 5.0k 3.4k 5.1k 5.7k 4.9k Uni Avg
MILES 139.0 127.2k 117.5k 110k 87.1k 80.5k 70.4k 64.8k
SAMPLE TAKEN 10/15/10 4/19/10 11/11/09 6/20/09 6/10/08 2/28/08 9/2/07 7/3/06
ALUMINUM 4 3 3 2 2 3 3 2 3
CHROMIUM 1 1 1 1 1 1 1 1 1
IRON 13 12 9 8 9 24 14 8 13
COPPER 27 24 25 19 21 28 39 30 17
LEAD 38 15 8 5 9 4 21 19 8
TIN 0 3 0 0 2 1 0 0 1
MOLYBDENUM 53 54 49 48 3 52 98 83 65
NICKEL 1 1 0 0 0 1 0 0 0
MANGANESE 0 0 0 0 0 0 0 0 0
SILVER 0 0 0 0 0 0 0 0 0
TITANIUM 0 0 0 0 0 0 0 0 0
POTASSIUM 2 3 0 2 7 11 1 3 7
BORON 29 33 29 36 114 34 47 52 45
SILICON 11 12 15 11 29 13 12 12 11
SODIUM 1 2 2 2 8 10 5 4 24
CALCIUM 3020 3020 2809 2944 2018 2919 2184 2354 2078
MAGNESIUM 13 10 10 10 7 12 11 13 90
PHOSPHORUS 676 725 649 639 646 656 538 589 691
ZINC 776 907 728 832 784 819 675 745 848
BARIUM 0 0 0 0 0 0 0 0 0
INSOLUBLES 0.4 0.3 0.3 0.3 0.2 0.3 0.3 0.3
WATER 0 0 0 0 0 0 0 0
FLASHPOINT ºF 400 390 390 410 400 400 410 420
SUS VIS 210ºF 60.9 57.1 58.2 59.2 56.6 57.9 58.6 60.8
cSt @ 100ºC 10.46 9.40 9.70 9.99 9.24 9.63 9.83 10.44
TBN 4.6 3.1 3.4 n/a n/a 3.9 3.7 n/a
Blackstone Coments:
Code:
