Originally Posted By: goneflyfishin
What oil weight and type would you recommend for street and highway use?
Nice Mopar! I've got a 69 Road Runner myself.
Well, you could play the guessing game as to what viscosity will work best for your given application or you could install an oil temp gauge AND oil pressure gauge. What you're looking for is 9-to-10 PSI per 1000 RPMs and no less than 45PSI at idle. So about 45-to-65PSI operating range in an old mechanically sound Mopar would be about right.
Some people love to see the oil pressure gauge pegged at 80PSI at start up, and I know some of these people, but still can't convenience them to go with a less thick viscosity.
If a 40 grade is the oil that works best, I'd go with 5W-40 Synthetic. But more than likely a 10W-30 HDEO, preferably synthetic, will give you everything you need.
Also, a PAO synthetic is proven to withstand increased fuel dilution if the carburetor is running a little too rich, something to consider.
