Actually I think is holds the inlet valve open on this particular eengine, when starting make sure the throttle is open, also the valve clearance needs to be set correctly for the release to work correctly.
Here is one reference to it, but there are many others with details of how to do it correctly, and many references of people replacing battery and starters to find the same thing and then adjust the valves and all is good.http://www.mytractorforum.com/showthread.php?t=32134
Edited by 100td (11/29/10 05:07 PM)
