How Much Olive Oil Do You Use?
by GrtArtiste
48 minutes 49 seconds ago
Hyundai filter 26300-35503 10PK for 35.40 FREE S&H
by GumbyJarvis
Today at 01:10 AM
Dope smoking genius Laremy Tunsil NFL Draft Pick!
by GiveMeAVowel
Yesterday at 09:50 PM
'13 Honda VFR1200 Motul 10w-50, 5,300 miles.
by montero1
Yesterday at 09:35 PM
Anyone Using Spline Sockets?
by JHZR2
Yesterday at 09:33 PM
Anyone Tryed Spectra Premium O2 Sensors?
by Mr_Accord
Yesterday at 09:16 PM
UPS package tracking is so confusing!
by Klutch9
Yesterday at 07:52 PM
Dupont non-stick lube
by buck91
Yesterday at 07:47 PM
House electrical wiring question
by road_rascal
Yesterday at 07:46 PM
Air pressure question
by aquariuscsm
Yesterday at 07:43 PM
Fllow the DOT's
by WyrTwister
Yesterday at 07:23 PM
Auto Rx?
by coopns
Yesterday at 06:54 PM
hdwizard21, raihan, aceracres, kg4geq, red_bulldog
57748 Registered Users
18 registered (bdcardinal, EchoTech1945, Ducked, c502cid, bmod305, 2 invisible), 452 Guests and 112 Spiders online.
57748 Members
66 Forums
248233 Topics
#2045652 - 10/13/10 02:48 PM Pennzoil/Quaker State/Shell Technical Data Sheets
modularv8 Offline
Loc: Texas
Just got of the phone with Shell and the new TDS's are out. It isn't user friendly, but you have to do a product search on the Shell Catalogue.
http://www.epc.shell.com/
Pennzoil Platinum
Quaker State Ultimate Durability
As can see nothing has changed from what I can see (properties), except for the new certifications (GF-5/dexos1).
Hard to believe these were reformulated but still match the old TDS exactly down to the decimal points in terms of properties.
By the way Ultra is not going away. It is up to the retailers to carry it. All the Walmarts here carry it.
Edited by modularv8 (10/13/10 02:54 PM)
2006 F150 5.4L
#2045659 - 10/13/10 02:53 PM Re: Pennzoil/Quaker State/Shell Technical Data Sheets [Re: modularv8]
buster Offline
Loc: NJ
First oils to show a A1/B1-08 rating. The others are 04. Looks good other than the higher NOACK.
#2045713 - 10/13/10 03:28 PM Re: Pennzoil/Quaker State/Shell Technical Data Sheets [Re: modularv8]
ahoier Offline
Loc: Cocoa, FL
Pennzoil has been claiming the "meets latest SN API grades" on some of their packaging for the past couple months now as reported here.....though my local WM hasn't received any of this new product/packaging which stated as such smile
We got the "old" PYB, and then the "new" PYB with the "45% sludge removal" message on the bottle.
Still awaiting the new SN oil - but likely it'll take a bit for it to arrive in stores, since Walmart and the like will be first clearing out their warehouses of the "old" oil before shipping out the "new" packages/bottles smile
#2045790 - 10/13/10 04:46 PM Re: Pennzoil/Quaker State/Shell Technical Data Sheets [Re: modularv8]
blue94 Offline
Loc: wisconsin
So 5w-30 PP is A1/B1-08 while QSUD 5w-30 is A5-02. Odd.
#2046136 - 10/13/10 11:03 PM Re: Pennzoil/Quaker State/Shell Technical Data Sheets [Re: modularv8]
dakota99 Offline
Loc: indiana
Huh weird. Almost seems like QS is a little better than PP. Probably not more to even make a difference, but interesting.
QS 5w30 MRV (-35C) 12,800
PP 5w30 MRV (-35C) 14,800
PP 5w30 pour point -39C
QS 5w30 pour point -45C
QS 5w30 flash point 227C
PP 5w30 flash point 224C
1999 Dodge Dakota - Pennz High Mileage 10w30
2008 Accord EX-L - Mobil 1 0w20
2013 Accord Sport - Mobil 1 0w20
#2046484 - 10/14/10 10:52 AM Re: Pennzoil/Quaker State/Shell Technical Data Sheets [Re: modularv8]
blue94 Offline
Loc: wisconsin
I reading the Lubrizol website it casts a negative light on A1/B1 in general saying "ACEA A1/B1 oils are typically used in older vehicles as they do not provide the minimum performance demanded by the latest OEM specifications."
and
"Prior to ACEA 2008, ACEA A1/B1 was usually coupled with the Ford specification, WSS-M2C913-B. However, a new edition of this specification has been introduced by Ford which requires a higher minimum ACEA performance level of ACEA A5/B5-08. This will further reduce the range of applications for which ACEA A1/B1-08 oils are suitable."
So I guess neither of these oils will meet the updated Ford spec. Does this affect anybody?
I can't figure out if A1/B1-08 may be preferable to A5/B5-02 because the "02" spec is pretty old now.
I'm sure none of this is going to make a spit of difference in my cars but it would be nice to know. I always liked A5 because it specified a longer drain. However, it appears that the new A1/B1-08 has a higher TBN than A5/B5-02. Does that make it a better longer drain oil now?
#2046593 - 10/14/10 12:21 PM Re: Pennzoil/Quaker State/Shell Technical Data Sheets [Re: dakota99]
addyguy Offline
Loc: Canada
I've noticed that as well - that the cold-weather values for QS are just slightly better than PP...weird!
2003 Mazda Tribute LX V-6, 196,850 miles...DEAD.
MM F1 5W-20 conventional + Bardahl + top-offs.
MM MPH2 filter.
#2046662 - 10/14/10 01:15 PM Re: Pennzoil/Quaker State/Shell Technical Data Sheets [Re: addyguy]
sangyup81 Offline
Loc: Bowie, MD
QS tend to use better base stocks and possibly more VIIs but PP uses better additives for cleaning. That's what I've been getting at least
#2559464 - 03/06/12 08:42 PM Re: Pennzoil/Quaker State/Shell Technical Data Sheets [Re: modularv8]
buster Offline
Loc: NJ
Pennzoil High Mileage PDS is dated. I'm going to pass on SOPUS products. They can't even get their website/PDS's correct.
#2561010 - 03/08/12 10:25 AM Re: Pennzoil/Quaker State/Shell Technical Data Sheets [Re: sangyup81]
gogozy Offline
Loc: GTA, Ontario, Canada
i think Noack at 11.5 is very good... maybe too good? slobber
QS Noack Volatility, % 14
PP Noack Volatility, % 11.5
#2561061 - 03/08/12 11:02 AM Re: Pennzoil/Quaker State/Shell Technical Data Sheets [Re: modularv8]
CATERHAM Offline
Loc: Burlington, Ontario, Canada
Nothing 'new' about those TDSs. The QSUD spec' are almost two years old (June 2010).
74 Lotus Europa, 5W-50
86 Porsche 928S, TGMO 0W-20 25% / M1 0W-40 75%
96 BMW 328i, Idemitsu/TGMO 0W-20 70% / M1 0W-40 30%
94 Caterham 7, FUCHS 0W-20
#2561271 - 03/08/12 02:04 PM Re: Pennzoil/Quaker State/Shell Technical Data Sheets [Re: CATERHAM]
gogozy Offline
HI CATERHAM, thanks.
btw, the parts guy told me Honda is about to switch the 0w20 supplier (when I pickup the stuff)
#2561292 - 03/08/12 02:24 PM Re: Pennzoil/Quaker State/Shell Technical Data Sheets [Re: addyguy]
penz08 Offline
Loc: new brunswick canada
I got some 5w20 PP with API SN, is this suppose to perform better? rev easier ?
