1997 Saturn P0326 No power
by nwjones18
08/29/16 04:29 PM
Can I use lower weight ?
by ST2008
08/29/16 04:25 PM
Amsoil 0W-30 Honda S2000 40,259 OCI w/bypass
by slalom44
08/29/16 03:32 PM
Holdup
by Whitewolf
08/29/16 03:14 PM
boosting diesel perf using propane/CNG/meth added
by columnshift
08/29/16 03:04 PM
HP for '96 Toyota Corolla?
by Benzadmiral
08/29/16 03:04 PM
Gene Wilder Dies at 83
by John_Conrad
08/29/16 02:52 PM
Simple oil question, Honda GCV 160
by Popsy
08/29/16 02:49 PM
BMWs Remote 3D View
by HTSS_TR
08/29/16 02:25 PM
I changed my p.s. fluid, it's easy (with pics)
by TmanP
08/29/16 02:20 PM
Abandoning the Fumoto Valve Plan
by CrackyWainwright
08/29/16 02:18 PM
New Shed/Garage, A Couple Questions
by Bob5150
08/29/16 01:08 PM
LazLong, gioburk, turrican, GGilbert, leje0306
58952 Registered Users
98 registered (2oldtommy, Al, 2015_PSD, 09_GXP, 8 invisible), 1743 Guests and 11 Spiders online.
58952 Members
66 Forums
253735 Topics
#2034245 - 10/01/10 07:51 PM Oil filter for Kohler Courage SV470-620
raaizin Offline
Loc: NJ
This engine clls for 12 050 01-S. The fram is PH8172 I believe. Is the number for NAPA Gold 1056??
#2034263 - 10/01/10 08:13 PM Re: Oil filter for Kohler Courage SV470-620 [Re: raaizin]
Sayjac Offline
Loc: The Old North State
Funny you should ask. Just changed my oil today, but decided to re-use the Kohler filter this time. But, I was looking for a cross reference for the Kohler filter. Here's what I came up with. Wix 51056, Fram PH8172 and in Purolator the L35310.
It does seem the Napa Gold number is the FL1056, the specs look right.
#2034276 - 10/01/10 08:33 PM Re: Oil filter for Kohler Courage SV470-620 [Re: Sayjac]
raaizin Offline
Loc: NJ
The Napa filter I have is 1056 not fl1056 are they the same?
#2034327 - 10/01/10 09:56 PM Re: Oil filter for Kohler Courage SV470-620 [Re: raaizin]
Sayjac Offline
Looking closer the online cat. # says FIL 1056, but yeah, it's the same filter.
#2034334 - 10/01/10 10:19 PM Re: Oil filter for Kohler Courage SV470-620 [Re: raaizin]
motorcity Offline
Loc: Michigan
Here guys
I personally run Motorcraft FL400s or Purolator Pureone equilvalent but on some Kohlers their isn't enough clearence
"Briggs/Kohler type" 3/4" X 16 threads 8-11 PSI Bypass Gasket 2.734"OD X2 .430"ID 0.226" thick
Length" Wix Purolator Hastings Kohler B&S Baldwin MotorCraft AC Walmart JD
2.3" 57035 NA LF503 2805001 492932 B7165 NA NA? NA ?
2.7" 51056 L35310 LF302 1205001 492056 B1410 NA PF2210 NA AM125424
3.4" 51348 L10241 LF157 5205002 491056 BT223 FL793 PF53 ST3614 AM101207
4.8" 51516 L20195 LF134 NA NA B243 FL400A PFL400A ST3600 ? 
Edited by motorcity (10/01/10 10:22 PM)
#2034831 - 10/02/10 05:14 PM Re: Oil filter for Kohler Courage SV470-620 [Re: motorcity]
JTK Offline
Loc: Buffalo, NY
Yeah, the OP's single cyl Courage has the filter oriented in such a way, you're limited on size choices. On the Courage V-twins like mine, the sky is the limit with space. I run FL400's. The blocks are pretty much identical to a Command block.
Joel
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#2034975 - 10/02/10 08:32 PM Re: Oil filter for Kohler Courage SV470-620 [Re: Sayjac]
raaizin Offline
Loc: NJ
sayjac, Thanks!!!!and I guess the eyes are starting to go :)
