45483 Members
64 Forums
193702 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#2034127 - 10/01/10 05:30 PM
5W-40 in a Nissan Maxima VQ35 oil burner?
Loc: Colorado
I'm currently using regular Pennzoil 10W-40 in my Nissan Maxima as it tends to use a quart of 5W-30 every 1k miles. Using 10W-40 has at least cut that number in half or more. The bad thing though is winter is coming and I'd rather not run 10W-40 during the cold months. My manual recommends 5W-30, 10W-30, or 10W-40. I'd like to try a newer 5W-40 oil and maybe keep the oil burning issue down with a better cold start flow for winter. I really can't see how this would be a problem but I thought I'd ask here for opinions.
2002 Nissan Maxima SE 6 speed
#2034134 - 10/01/10 05:39 PM
Re: 5W-40 in a Nissan Maxima VQ35 oil burner?
[Re: kbohip72]
Loc: Sarasota, FL
Rotella 5w40
04 Spec-V, 05 STi, 03 G35
#2034163 - 10/01/10 06:07 PM
[Re: kbohip72]
Loc: Cincinnati
Rotella T5 10w-30 semi-synthetic?
Give it a try and see if the oil burning issue continues. About $12 per jug at Wal-Mart.
How many miles on your 2002?
And can you find Max-Life full syn anywhere? That might be worth a try!
2005 Accord V6 - Pennzoil Ultra - Bosch Distance Plus filter/Amsoil ATF
2005 Highlander V6 - Platinum 5w-30/PureOne filter/Amsoil ATF and gear lube
#2034172 - 10/01/10 06:16 PM
[Re: dkryan]
Loc: Colorado
And can you find Max-Life full syn anywhere? That might be worth a try! It has 103k on it now. When I bought it with 55k miles it was already using almost 1 quart per 1k miles though.
#2034179 - 10/01/10 06:34 PM
[Re: kbohip72]
Loc: Cincinnati
So, should you focus on correcting the reason it is "using" 1 quart per 1k miles, or use a specific oil to correct the "usage?"
Mobil 1 0w-40?
Castrol Syntec 0w-30? I used this oil in my VQ30DE (2001 I30) and not only is it a "thicker 30 weight," it, Maxlife full syn, and RLI SHP 10w30 HD were the only three oils that could stand up to 1.2 mile commutes each way during the winter months. Interpret that as "massive fuel dilution."
Good luck and let us know which oil you select and how the usage is with that oil.
#2034184 - 10/01/10 06:38 PM
[Re: kbohip72]
Loc: Lombard, IL
I'd consider GC 0w30 or Mobil 1 0w40.
2011 Audi S4 sedan S tronic + Stasis exhaust & tune Castrol Edge 5w40 + Mann HU722z
#2034203 - 10/01/10 07:04 PM
[Re: kbohip72]
Loc: London, ON, Canada
Try Rotella 5W40 non synthetic... Why add syn if it uses so much? I run conventional in my '02 because of consumption.
2011 Civic Sport 5MT Pennzoil 5w20 + PureONE Redline MTL
#2034229 - 10/01/10 07:36 PM
[Re: kbohip72]
Loc: Detroit, MI
I'm currently using regular Pennzoil 10W-40 in my Nissan Maxima as it tends to use a quart of 5W-30 every 1k miles. Using 10W-40 has at least cut that number in half or more. The bad thing though is winter is coming and I'd rather not run 10W-40 during the cold months. My manual recommends 5W-30, 10W-30, or 10W-40. I'd like to try a newer 5W-40 oil and maybe keep the oil burning issue down with a better cold start flow for winter. I really can't see how this would be a problem but I thought I'd ask here for opinions. Go figure. A Nissan engine consuming oil
Cars, Trucks, Boats, Power Equipment, Firearms, I use AMSOIL Synthetic Lubricants everywhere...
#2034242 - 10/01/10 07:48 PM
[Re: Johnny248]
I'm currently using regular Pennzoil 10W-40 in my Nissan Maxima as it tends to use a quart of 5W-30 every 1k miles. Using 10W-40 has at least cut that number in half or more. The bad thing though is winter is coming and I'd rather not run 10W-40 during the cold months. My manual recommends 5W-30, 10W-30, or 10W-40. I'd like to try a newer 5W-40 oil and maybe keep the oil burning issue down with a better cold start flow for winter. I really can't see how this would be a problem but I thought I'd ask here for opinions. Go figure. A Nissan engine consuming oil Yeah, weird! I've never even owned a car that doesn't burn oil :D 2 Saturns, 2 VQ35's, an old 2.5L Chrysler, and a SOHC Neon. The Neon was the best for consumption about a quart over 5k MI.
#2034260 - 10/01/10 08:10 PM
[Re: kbohip72]
Loc: Jupiter, Fl
Think of it as UCl without having to add anything to the gas...
'06 Infiniti G35 Sedan 6MT - 145k miles '06 Infiniti FX45 - 90k '08 BMW 528i - 60K '08 CBR1000RR
#2034278 - 10/01/10 08:35 PM
[Re: SLCraig]
Loc: Nebraska
Try Rotella 5W40 non synthetic... Why add syn if it uses so much? I run conventional in my '02 because of consumption. Rotella 5w40 is "sythetic" grp III
09' Nissan Frontier CC 4x4 09' Porshe Boxter S 05' Honda Element 4 Motorycles 3 ATV's
#2034299 - 10/01/10 09:05 PM
[Re: heavyhitter]
Loc: fairfield,CA
z max will help. It soaks into the metal.(sarcasm)
2007 Nissan 350z Redline 0w30/M1-110 MT-85 Hummer H3 Pentosyn 5w30 Maxlife ATF
#2034368 - 10/01/10 11:09 PM
[Re: kbohip72]
Loc: Watertown, New York
Try Maxlife or Mobil One High mileage. 10w30 or 10w40 would probably be fine. If you really want to run 5w40, try Rotella.
1993 Chevy C1500 1999 Saturn SL2 2000 Nissan Quest 1986 Pontiac Trans Am 1940 Ford 9N Tractor
#2034528 - 10/02/10 08:49 AM
[Re: kbohip72]
Loc: Mid-Atlantic
Those recommending GC 0W-30 or Mobil 1 0W-40, could you elaborate why you think those are good choices for the VQ engine in this instance?
I'm trying to decide on a go-to oil for an '03 Maxima similar to OP's but with no oil burning issues. 65K miles, 5K mile OCIs.
#2034585 - 10/02/10 10:29 AM
[Re: cronk]
Loc: Buffalo, NY
Try Maxlife or Mobil One High mileage. 10w30 or 10w40 would probably be fine. If you really want to run 5w40, try Rotella. +1 I'd consider Mobil 1 5W-30 High Mileage as well, as it's almost as thick as 10W-30 at operating temp... http://www.mobil.com/USA-English/Lubes/PDS/NAXXENPVLMOMobil_1_High_Mileage_Oil.aspx
Edited by Nickdfresh (10/02/10 10:30 AM)
