Dope smoking genius Laremy Tunsil NFL Draft Pick!
by GiveMeAVowel
04/29/16 09:50 PM
'13 Honda VFR1200 Motul 10w-50, 5,300 miles.
by montero1
04/29/16 09:35 PM
Anyone Using Spline Sockets?
by JHZR2
04/29/16 09:33 PM
Anyone Tryed Spectra Premium O2 Sensors?
by Mr_Accord
04/29/16 09:16 PM
UPS package tracking is so confusing!
by Klutch9
04/29/16 07:52 PM
Dupont non-stick lube
by buck91
04/29/16 07:47 PM
House electrical wiring question
by road_rascal
04/29/16 07:46 PM
Air pressure question
by aquariuscsm
04/29/16 07:43 PM
Fllow the DOT's
by WyrTwister
04/29/16 07:23 PM
Auto Rx?
by coopns
04/29/16 06:54 PM
Rotella for 6.0L Gasser
by Joefuskie
04/29/16 04:40 PM
Pennzoil Platinum Euro 5W-40
by 1JZ_E46
04/29/16 04:21 PM
hdwizard21, raihan, aceracres, kg4geq, red_bulldog
57748 Registered Users
43 registered (901Memphis, 2015_PSD, Alex38, Bryanccfshr, bmwjohn, 8 invisible), 920 Guests and 97 Spiders online.
57748 Members
66 Forums
248231 Topics
Page 1 of 2 1 2 >
#2022994 - 09/20/10 11:32 PM Motorcraft filter on an '03 Corolla?
panthermike Offline
Loc: Phoenix, AZ
Just wondering if there's a MC filter that will work on the 1ZZFE engine? The direct replacement is the FL-836, but I like using the longer version(currently using PL14477). Plus, the FL-836 isn't easily obtainable.
Reason I want to use an MC filter is the durable construction, availability, silicone ADBV, and it's only $3.67 at Walmart. The only one I can see working is the FL-400S?
Anyone have any experience with this? Thanks.
'16 Ram Sport 1500;FF
'15 Lincoln MKC; PP 5w30 21K
'77 F250 "Ol Yeller"; Kendall/Mos2
'98 ES300; ML/Biotech 200K
#2023032 - 09/21/10 12:10 AM Re: Motorcraft filter on an '03 Corolla? [Re: panthermike]
Gary Allan Offline
Loc: Pottstown, PA
The FL400S should work. What more are you looking for? I think your restrictions are in diameter. The FL400S is as long as you'll find in MC with that diameter.
http://lube-direct.com/gallan/
#2023113 - 09/21/10 02:40 AM Re: Motorcraft filter on an '03 Corolla? [Re: Gary Allan]
901Memphis Online   content
Loc: Northern Kentucky
Purolator Class L20195 are the same as the old Motorcraft FL400s that were longer before they shortend them IIRC. The bypass valve may be in a different location though.
I use 20195s on my Taurus and it calls for FL400s, which are shorter now.
2002 Buick Century 125k - Built 4T65e(Maxlife) - M1 0w40 /Fram Ultra XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#2023333 - 09/21/10 10:23 AM Re: Motorcraft filter on an '03 Corolla? [Re: Gary Allan]
panthermike Offline
Loc: Phoenix, AZ
If the FL-400S will work, that would be perfect. Especially the new size, which is probably still longer than the PL14477 that I'm using now.
Are you positive the FL-400S will work? Thanks for your responses.
#2023350 - 09/21/10 10:39 AM Re: Motorcraft filter on an '03 Corolla? [Re: panthermike]
panthermike Offline
Loc: Phoenix, AZ
The only thing I noticed is that the O.D. for the factory filter is 2.69". The FL-400S is 2.98". Thread size is the same.
#2023802 - 09/21/10 04:52 PM Re: Motorcraft filter on an '03 Corolla? [Re: panthermike]
sunfire Offline
Loc: Ca, US
I just opened a ST3614 (oversize for 1ZZFE) from my father's Camry 2AZ-FE. Wasn't impress with the ADV which was thin and very stiff. It was only in use for 6 months about 7K miles. The leaf spring and ADV weren't clued to the filter. They were designed to fit snug into the filter.
Edited by sunfire (09/21/10 04:54 PM)
2005 Toyota Corolla LE | 65,000 | PYB 5W-30
#2023825 - 09/21/10 05:09 PM Re: Motorcraft filter on an '03 Corolla? [Re: panthermike]
sunfire Offline
Loc: Ca, US
The O.D. of 2.98" on the FL-400S should work fine. The ST3614 has the same O.D. was used in my father's Camry.
#2026836 - 09/24/10 06:58 PM Re: Motorcraft filter on an '03 Corolla? [Re: panthermike]
JMJNet Offline
Loc: TX, USA
I am not sure for Corolla but the Camry's 2.2L base filter size (where the gasket meets) is only around 2.7x". Measure it with a caliper. So I am not sure if 2.98" size will work? It is too big. I got the feeling that the filter OD size is the same between Camry 2.2L and Corolla?
Edited by JMJNet (09/24/10 06:59 PM)
  • 2004 Toyota Sienna
#2027484 - 09/25/10 03:20 PM Re: Motorcraft filter on an '03 Corolla? [Re: panthermike]
sunfire Offline
Loc: Ca, US
Did an oil change today to PYB 5W-20. The FL-400S just barely fits my 05 Corolla. The outer rim of the gasket is almost over the edge of the filter base. The filter's dome is still well above the plastic under covers. No leaks yet after a 5 mile drive.
I may have found my new favorite filter. Walmart had plenty FL-400S around. Filter looks well constructed.
#2028328 - 09/26/10 12:54 PM Re: Motorcraft filter on an '03 Corolla? [Re: sunfire]
panthermike Offline
Loc: Phoenix, AZ
Does it still hit the oil filter base enough for you to be comfortable with it, a good seal?
#2029002 - 09/27/10 08:40 AM Re: Motorcraft filter on an '03 Corolla? [Re: panthermike]
sunfire Offline
Loc: Ca, US
There are other bitog members that have used the FL-400S sucessfully in their 9th gens with no problems (use search function).
The wider gasket is completely 100% in contact with the filter base. I would not have used the FL-400S otherwise. But its very close to the edge. Where as the L14476/7 had extra play room and gasket was in contact with the mid section the filter base.
If you decide to try the FL-400S have a backup filter (L14477) ready incase you are not comfortable.
Edited by sunfire (09/27/10 08:43 AM)
#2029233 - 09/27/10 12:25 PM Re: Motorcraft filter on an '03 Corolla? [Re: sunfire]
panthermike Offline
Loc: Phoenix, AZ
Thanks for the info. I'll just try it out, there's a Walmart near if I'm not comfortable. I feel more comfortable now that other 9th gen owners have used it sucessfully. The 14477 is what I use now, I like it but it's $6.00/filter, whereas the FL-400S is $3.67. I'll update when I do the oil change, thanks again.
#2048668 - 10/16/10 03:17 PM Re: Motorcraft filter on an '03 Corolla? [Re: panthermike]
panthermike Offline
Loc: Phoenix, AZ
Success! No leaks and the filter fits just fine. Like Sunfire said, right at the edge of the base.
Anyone who owns a 9th gen Corolla should look into this.
#2048861 - 10/16/10 07:40 PM Re: Motorcraft filter on an '03 Corolla? [Re: panthermike]
ZeeOSix Offline
Loc: PNW
Maximized! thumbsup
A filter's brand name doesn't matter ... what's inside does.
#2050357 - 10/18/10 12:19 PM Re: Motorcraft filter on an '03 Corolla? [Re: panthermike]
blue94 Offline
Loc: wisconsin
Thanks for posting this. I've heard this could be done but this is the most complete post (with pictures) to confirm fitment and clearance. thankyou
Page 1 of 2 1 2 >
