SAE 16. Set at a minimum of 2.3 mPa⋅s at 150C
by wemay
13 minutes 28 seconds ago
1992 Surburban Big Block - M1 10W-30 - 5 year OCI
by bigt61
14 minutes 47 seconds ago
2007 Civic Wiper Blade Contact Fix
by 4thstpositively
32 minutes 39 seconds ago
Got me a new Stihl FS 56 trimmer today
by daddi
Today at 01:02 PM
Truck cap lights.
by wolfehunter
Today at 12:12 PM
filters and oem specs
by mobilaltima
Today at 11:50 AM
H11 bulb options
by asiancivicmaniac
Today at 11:47 AM
Engine oil accidently added into transmission
by Mazatrol
Today at 09:51 AM
Oil for 1996 Mazda B4000 pickup
by schuylkill
Today at 09:16 AM
Shell gas $80 rewards cars for $52 Deal ends 9-1
by gojoneeded
Today at 09:12 AM
Cleaning a carpet stain....Help!
by mjk
Today at 07:39 AM
Windshield: can it be repaired?
by supton
Today at 07:12 AM
pperras01, Grabberblu, Dave_PPE, davebe, Logos
58964 Registered Users
88 registered (86cutlass307, 4thstpositively, 4WD, 1foxracing, 09_GXP, 10 invisible), 1726 Guests and 8 Spiders online.
58964 Members
66 Forums
253775 Topics
Page 1 of 3 1 2 3 >
#2019100 - 09/16/10 07:10 PM 09 Nissan Altima 2.5 CVT Fluid change
jeff194 Offline
Loc: CT
I can't seem to locate the trans drain plug on this vehicle. Do you think any harm would be done if I disconnect the return line, let it pump at idle until I see bubbles, then refill? I really don't want to drop the pan,as if I have a warranty claim, Nissan my use that as a reason to deny a claim.
#2019140 - 09/16/10 08:04 PM Re: 09 Nissan Altima 2.5 CVT Fluid change [Re: jeff194]
dparm Offline
Loc: Chicago, IL
Why would they deny your warranty claim? Honestly, the dealer is not even going to know if you dropped the pan.
If you're that worried, just have the dealer change the fluid.
2011 BMW M3 sedan ZCP
#2019177 - 09/16/10 08:40 PM Re: 09 Nissan Altima 2.5 CVT Fluid change [Re: dparm]
jeff194 Offline
Loc: CT
No thanks on the dealer, Why would they not honor a claim, lol, because they can.
#2019179 - 09/16/10 08:41 PM Re: 09 Nissan Altima 2.5 CVT Fluid change [Re: jeff194]
chubbs1 Offline
Loc: Merritt Island FL, USA
How many miles do you have on that '09? I wouldn't worry too much about it unless you had 60k+. I have the same car and I am saving up for the Dealer to do it. That is a picky Transmission and that is about the ONLY thing I'd have the Stealership do the service for on that engine. JMHO.
Matt
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#2019188 - 09/16/10 08:50 PM Re: 09 Nissan Altima 2.5 CVT Fluid change [Re: chubbs1]
finalyzd Offline
Loc: fairfield,CA
Just did a transmission service on my sisters 09 altima. 90 worth in eneos cvt fluid 13qts. Dealership will charge around 160(drain and fill) to 250(machine). I called them becuz I was skeptical at doing it first. I think a pan drop would be your best bet.
2007 Nissan 350z
Redline 0w30/M1-110
MT-85
Hummer H3
Pentosyn 5w30
Maxlife ATF
#2019207 - 09/16/10 09:13 PM Re: 09 Nissan Altima 2.5 CVT Fluid change [Re: jeff194]
JimPghPA Offline
Loc: Pittsburgh,PA U.S.A.
See if you can find a torque spec for EVERY thing you have to tighten back up. And be sure to use a good method to measure the torque you apply. These modern parts are built with so little excess material that is is real easy to strip them. Rockwell makes a special tool to tighten all bolts on transmissions including the pan. This machine even takes into account if there is anything fouling the thread such as dirt or shavings left over from manufacturing. Before this tool was used there was a high rate of rejects during manufacturing because threads would get stripped from over-torquing them.
If you strip a thread you are opening up a who new can of problems. You will have to go up to a larger size or healy-coil it.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
#2019208 - 09/16/10 09:14 PM Re: 09 Nissan Altima 2.5 CVT Fluid change [Re: finalyzd]
jeff194 Offline
Loc: CT
I think your right, Is the Enos the same color as the NS2?
BTW the car has 30k on it. It was a rental that I bought for my daughter. That's why I am changing it now.
#2019231 - 09/16/10 09:39 PM Re: 09 Nissan Altima 2.5 CVT Fluid change [Re: jeff194]
unDummy Offline
Loc: RI
A single drain/refill every ~15k is good maintenance for a CVT.
And, since its a rental, I'd definitely consider it soon.
Those who say it cannot be done, should not interrupt the person doing it.
Your automaker lied!
Is this a spelling/grammar forum or BITOG?
#2019499 - 09/17/10 08:24 AM Re: 09 Nissan Altima 2.5 CVT Fluid change [Re: jeff194]
finalyzd Offline
Loc: fairfield,CA
I would change it out and eneos fluid is bright red don't know about the nissan fluid color, I'm assuming red as there past fluids have been that color
2007 Nissan 350z
Redline 0w30/M1-110
MT-85
Hummer H3
Pentosyn 5w30
Maxlife ATF
#2019577 - 09/17/10 09:38 AM Re: 09 Nissan Altima 2.5 CVT Fluid change [Re: finalyzd]
barlowc Offline
Loc: Southeast Michigan
Is a pan drop necessary? My understanding is that there IS a drain plug.
My 2008 will hit 30K in December and I was planning to do a single drain/fill at that time and continue to do so every 30K from there on out.
2013 BMW 335i xDrive Sport Line (36K Miles)
#2019629 - 09/17/10 11:03 AM Re: 09 Nissan Altima 2.5 CVT Fluid change [Re: barlowc]
Finklejag Offline
Loc: WA
I had a 07 Altima. I traded it in before it needed a CVT service. Here is a DIY CVT change from my old forum I use to hang out on.
CVT service
2016 Audi A3 2.0T Quattro
#2019634 - 09/17/10 11:09 AM Re: 09 Nissan Altima 2.5 CVT Fluid change [Re: jeff194]
il_signore97 Offline
Loc: Toronto, Ontario, Canada
I changed the CVT fluid on my friend's 2008 Altima 2.5 SL. It was very easy, and there was definitely a drain plug at the bottom of the CVT pan. There is no need to remove the pan.
Basically, we drained the fluid, refilled with the appropriate Redline CVT fluid, and then disconnected the fluid line leading to the radiator to help push the old fluid out of the torque converter. We idled the car for 30 seconds until the fluid started to sputter slightly, and then refilled with the proper amount of fluid. After a good drive, we checked the level according to the FSM procedure, and all was good.
Honestly, the colour of the Nissan NS2 fluid that came out of the CVT was pitch black. Nissan would never know the difference if you used a different fluid. My friend only had 40,000 miles, and it was completely black. The Redline fluid feels silky smooth. Way better than the stock fluid.
il_signore97
'09 Mercedes-Benz C300 Sport Calcite White 6-spd M/T
#2019647 - 09/17/10 11:26 AM Re: 09 Nissan Altima 2.5 CVT Fluid change [Re: il_signore97]
The Critic Offline
Loc: Walnut Creek, CA
They most definitely would know.
The NS-2 fluid has a green-ish tint to it. It also, most likely, has a chemical identifier. In the event of a CVT failure, Nissan will pull a fluid sample and analyze it to ensure that the NS-2 fluid was used. So if your friend experiences a failure under the newly extended 10/120,000 mile warranty, he's screwed.
11 Prius - 133k - M1 EP 0w20/OE
07 Accord 2.4 - 112k - M1 5w20/Fram Ultra Filter
10 Altima 3.5 - 35k - M1 EP 5w30/FU
92 Previa - 160k - Chevron 5w30/Wix
#2019699 - 09/17/10 12:20 PM Re: 09 Nissan Altima 2.5 CVT Fluid change [Re: jeff194]
unDummy Offline
Loc: RI
Really, have you seen Nissan analyzing fluid?
#2019716 - 09/17/10 12:47 PM Re: 09 Nissan Altima 2.5 CVT Fluid change [Re: il_signore97]
barlowc Offline
I wonder if all of that is necessary? I've read elsewhere that Nissan's standard procedure on the CVTs is to simply drain and fill twice. I have the service instructions for a 2007 Sentra and that's what it instructs.
On the topic of fluid, this sounds like the Honda Z1 debate. Personally, I'm not going to take any chances with the 10-year / 120,000-mile warranty and am going to stick with NS-2.
Page 1 of 3 1 2 3 >
