Discount Tire Direct 4th of July Sale
by sopususer
06/24/16 08:37 PM
Bible Students?
by Eddie
06/24/16 07:51 PM
What kind of oil drain plug gasket is this?
by Chris B.
06/24/16 07:36 PM
by Chris B.
06/24/16 07:34 PM
First time changing oil what to use ?
by sshazam
06/24/16 07:13 PM
toshiba 720p 28" TV hdmi to thinkpad vga cable?
by bmwjohn
06/24/16 06:48 PM
1988 Brougham
by momo
06/24/16 06:38 PM
Permatex Silicone Tape
by Warstud
06/24/16 06:28 PM
Walnut Grips Really Make A Difference !
by billt460
06/24/16 06:25 PM
PC freezing up when streaming sports
by sleepery
06/24/16 05:52 PM
Use a heavier oil or HM oil?
by mclasser
06/24/16 05:42 PM
Kendall GT-1 (w/titanium?) 20w-50 for airheads
by Samzone
06/24/16 05:20 PM
Koloa, codeman021, chryslerconcorde, VolCntry73, OilyWaterMIXER
58254 Registered Users
94 registered (69GTX, 2015_PSD, AEHaas, 97f150, andyd, 9 invisible), 1567 Guests and 14 Spiders online.
58254 Members
66 Forums
250764 Topics
#2004418 - 09/01/10 11:47 AM synthetic vs conventional transmission fluid
rryam Offline
Loc: NC
I'm about to change my tranny filter and fluid. was wanting to put synthetic back in but not draining the converter, dont know how. Is it ok to mix synthetic with the conventional that will be left in the converter? Auto is a 2003 Gram Am 2.2 4cylcinder 125,000 miles.
#2004423 - 09/01/10 11:50 AM Re: synthetic vs conventional transmission fluid [Re: rryam]
Mau Offline
Loc: Thornhill, Ontario, Canada
yes its ok to mix
07 Acura TL Type S 6MT - PP 5w30/Fram Ultra XG7317
07 Honda CRV AWD - Motomaster Formula 1 5w30/Fram Ultra XG7317
#2004424 - 09/01/10 11:50 AM Re: synthetic vs conventional transmission fluid [Re: rryam]
sciphi Offline
Loc: Upstate NY
Disconnect the top cooler line (if it's similar to my Buick, that's the return line), get a barb and a hose, and do a cooler-line flush with the syn ATF. That will get ~90% new ATF into the transmission.
Maxlife ATF is syn, and easily available.
2013 Toyota RAV4 XLE
2012 Chevrolet Cruze Eco
#2004426 - 09/01/10 11:51 AM Re: synthetic vs conventional transmission fluid [Re: rryam]
Kestas Offline
Loc: The Motor City
There's no harm in mixing the two. But a complete fluid exchange would be better. Search on this subforum using my name for a writeup on this procedure.
#2004427 - 09/01/10 11:52 AM Re: synthetic vs conventional transmission fluid [Re: sciphi]
addyguy Offline
Loc: Canada
I just ended up having syn ATF put in my tranny, even though I didn't ask for it, or expect it - shop used Wynn's universal ATF, and it's 100 PAO fluid!
:P
2010 Kia Soul 2U - 2.0L I-4, auto, 86k miles.
QSGB 5W-20, NAPA select filter(?)
#2004538 - 09/01/10 01:14 PM Re: synthetic vs conventional transmission fluid [Re: addyguy]
Kaboomba Offline
Loc: SE WI, USA
@addyguy: groovy. syn ATF = mmmmmmm, goooooood
Kaboomba
94 Buick Park Ave 108K miles, aging gracefully though totalled!
95 Merc Sable 92K miles, raised from the dead by me
#2004566 - 09/01/10 01:41 PM Re: synthetic vs conventional transmission fluid [Re: Kaboomba]
rryam Offline
Loc: NC
Does anyone have an idea how much fluid the converter on my trans might hold? 2003 Grand AM 2.2 4 cylcinder.
#2004677 - 09/01/10 03:23 PM Re: synthetic vs conventional transmission fluid [Re: rryam]
mechtech2 Offline
Loc: Chicago Area
For a pan drop change, figure you only change about 1/2 the fluid.
Much better than before, but not perfect.
This is why people do line flushes, or install a drain plug on the pan to do subsequent drop drains [to approach 100% after a few changes].
#2005167 - 09/02/10 12:03 AM Re: synthetic vs conventional transmission fluid [Re: rryam]
Gary Allan Offline
Loc: Pottstown, PA
Automatic Transmission, 4T40-E Initial Fill..........6.9 quarts
Automatic Transmission, 4T45-E Initial Fill..........6.9 quarts
Automatic Transmission, Total Fill
4 speed 4T45-E..........12.9 quarts
4 speed 4T40-E..........12.9 quarts
7 vs. 13 quarts. Consider that there will be mixing in the converter as you purge it. 15 quarts should be enough to get it somewhere in the 90% range.
http://lube-direct.com/gallan/
#2007389 - 09/04/10 11:09 AM Re: synthetic vs conventional transmission fluid [Re: Gary Allan]
Cutehumor Offline
Loc: USA
I do the pan drop/filter change on my 96 sunfire. there's no pan drain bolt in mine. I must have all kinds of ATF mixed in there over the years with no flushing. wink
09 Chevy Cobalt 2.4L 88k miles Peak 5w30
09 Pontiac Vibe 2.4L 98k miles Pennzoil platinum 5w30
