Any harm in using a Motorcraft FL910S on a Tacoma?
by jongies3
05/28/16 08:50 PM
A/C performance woes...
by SEMI_287
05/28/16 08:49 PM
Red Line 10W30 Motorcycle oil particle count
by bulwnkl
05/28/16 08:08 PM
Microgard 51334 cut open
by dlundblad
05/28/16 08:07 PM
Differential Fluid Selection..
by Warstud
05/28/16 07:13 PM
The morality of riding a bike married with kids
by fdcg27
05/28/16 07:00 PM
Best synthetic oil for cleaning out an engine.
by anylettuce
05/28/16 06:58 PM
2013 ford fusion AC stank.
by leeaspell
05/28/16 06:46 PM
Cesna Citation Mustang - First impressions
by OVERKILL
05/28/16 05:35 PM
5.4 3V under valve cover pics & solenoid failure
by 04SE
05/28/16 03:50 PM
New safety spec for 2017 F1 cars...
by mcrn
05/28/16 03:35 PM
M1-101 after 10k on a 95 Sunfire 2.2 OHV pushrod
by slacktide_bitog
05/28/16 03:18 PM
mungchimp, troutwest66, AIRJAC3, bpete65, LEVY
58001 Registered Users
92 registered (04SE, advocate, 2015_PSD, 29662, ag_ghost, abycat, 6 invisible), 1430 Guests and 329 Spiders online.
58001 Members
66 Forums
249539 Topics
#1882634 - 05/06/10 03:30 PM UOA with Lubro-moly
sdan27 Offline
Loc: Michigan
This is on a Case 821 front end loader with a Cummins 8.3L engine. It has about a 20 quart oil capacity so I used three cans of MoS2. We used to use Texaco Ursa that had a descent amount of Moly. We switched to an oil that didn't have any and the iron count went from single digits to 20 which is about the same now. That might be coming from the high fuel content which about doubled since the last oil change. Even though the unit does see a lot of idling, the last time the fuel was this high it was due to a leaky fuel pump. I'm going to replace the fuel lift pump in hopes to bring the fuel level back down. The unit has 9740 total hours with 322 hours on this oil change.
Iron 22
Chrome 1
Al 1
Cu 1
Pb 1
Sil 3
Sod 5
Pot 1
Moly 163
Bor 9
Mag 978
Ca 1328
Ph 947
Zn 1155
Fuel 4.6%
Soot .2%
Vis Cs 12.6
TBN 4.7
Ox 16
Nit 23
'94 F250 Powerstroke. LF9691 primary oil. AH1141 air filter. FS1282, FF5320 fuel filter. WF2071 coolant filter.
#1882684 - 05/06/10 04:28 PM Re: UOA with Lubro-moly [Re: sdan27]
zddp77 Offline
Loc: n.j.
Use Chevron Delo 400 or Ursa LE and you dont need Lubro-Moly. BTW not much Moly in Lubro-Moly.
#1882741 - 05/06/10 05:18 PM Re: UOA with Lubro-moly [Re: zddp77]
Johnny Offline
Loc: Retired | Wausau, WI
I think the Lubro Moly he used as actually the MoS2 additive, which is all moly.
#1883243 - 05/07/10 06:18 AM Re: UOA with Lubro-moly [Re: Johnny]
dnewton3 Offline
Loc: Indianapolis, IN
I'd keep an eye on the fuel if it's "double" the last UOA. Clearly, you already have a plan of attack; that's good.
Rest looks really good.
Edited by dnewton3 (05/07/10 09:14 AM)
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#1883310 - 05/07/10 07:53 AM Re: UOA with Lubro-moly [Re: dnewton3]
Jim Allen Offline
Loc: NW Ohio
Regardless of the higher-trending iron (which is really not all that high taken on it's own), and the high fuel (not related to the oil), this is a great report for a 9700 hour engine.
Jim Allen
Keepin' the Good Old Days of Four Wheeling Alive
#1914315 - 06/05/10 07:58 PM Re: UOA with Lubro-moly [Re: sdan27]
Tornado Red Offline
Loc: Saint Paul (ex-San Diego)
167 ppm of moly is a good amount, not too much and not too little.
'03 Golf TDI, 578k miles: Bosio DLC764, GT1749VB, Malone Tuning, PP 2.5" DP, G60/VR6, Koni Reds, Recaros, Akebonos, DG Panzer
#1915915 - 06/07/10 02:16 PM Re: UOA with Lubro-moly [Re: zddp77]
daman Offline
Loc: Bad Axe, MI
The thing holds 20 qts man.
"Always"....Mobil 1
Current fill: AFE 0w30
#1916395 - 06/08/10 01:20 AM Re: UOA with Lubro-moly [Re: daman]
chevrofreak Offline
Loc: Billings, MT
I think the MoS2 particles might not be accurately detected with a typical UOA.
I <3 Red Line oil
#1986728 - 08/15/10 02:55 PM Re: UOA with Lubro-moly [Re: chevrofreak]
BigRich954 Offline
Loc: nj
why?
#1986766 - 08/15/10 03:37 PM Re: UOA with Lubro-moly [Re: chevrofreak]
Tornado Red Offline
MoS2 absolutely shows up in a used-oil test. It is obvious, especially when used with an oil that does not contain any moly, such as M1 TDT.
#1988291 - 08/17/10 03:32 AM Re: UOA with Lubro-moly [Re: zddp77]
lipadj46 Offline
Loc: Western NY
Yes there is, tons of it, well more like grams of it. Nice to see a UOA with MoS2 in a diesel. Who was it that always claims about MoS2 eating copper in a diesel environment?
Edited by lipadj46 (08/17/10 03:36 AM)
2002 Toyota Corolla, 65k miles, Mobil 1 0w30
2004 WV Passat Wagon 94k Miles, Rotella T6
2002 Land Rover Discovery Totaled RIP
#1990388 - 08/18/10 10:04 PM Re: UOA with Lubro-moly [Re: lipadj46]
sdan27 Offline
Loc: Michigan
We use an engine oil that does not normally contain any moly so it seems to show up pretty well. I've done about a half dozen more with similar results.
