What HDEO oils do crab fishing boats use?
by car51
20 minutes 23 seconds ago
Hornet nest
by sleepery
Today at 03:28 PM
Valvoline syn vs. dino in a power steering system
by Bottom_Feeder
Today at 02:51 PM
Pontiac G8 GT transmission deep pan upgrade...
by Blokey
Today at 02:17 PM
Hearing Aides
by CourierDriver
Today at 02:05 PM
SuperTech PS Fluid made my PS pump sound like new.
by BigD1
Today at 01:34 PM
Double clutching because of worn synchro?
by FordCapriDriver
Today at 01:29 PM
Titan single cab
by cptbarkey
Today at 01:11 PM
How to work dealers on price?
by Huie83
Today at 11:56 AM
MC FL820 6,000km's Cut Open
by Canadastang
Today at 11:28 AM
Loathing specific manufacturer for no reason
by FutureDoc
Today at 11:14 AM
Top Sirloin?
by totegoat
Today at 10:42 AM
lowsapsdieseloil, kit2523, rfabrocini, Tobin28, r0k
58600 Registered Users
92 registered (AKA, 2015_PSD, 97prizm, Al, AIRJAC3, 10 invisible), 1975 Guests and 22 Spiders online.
58600 Members
66 Forums
252273 Topics
Page 1 of 3 1 2 3 >
#1983065 - 08/11/10 03:55 PM Can vehicle run without battery?
Jeff3126 Offline
Loc: S FL
I had to jump my father's E-150 today. We got into an argument about the battery. He says you can run a car without the battery and while running, the alternator alone can run lights, radio, etc. I told hime no, the alternator charges the battery and the accesories are run off the battery.
Who is correct? Thanks.
2006 Ford Ranger, 3.0 V6, M1 5w-20/AAP Total Grip, Fumoto!
#1983076 - 08/11/10 04:04 PM Re: Can vehicle run without battery? [Re: Jeff3126]
Quest Offline
Loc: beaver land EH?
Once you manage to get your car/vehicle started by using a storage battery, the engine should keep the alternator running to the point where it(the alternator itself) shall be able to provide enough power to keep itself running.
in other words: once you successfully turn over your engine and fired up, the alternator itself should be capable of taking over the task of supplying enough electricity to keep the engine running (ignition module(s), computer control, etc.) and you shall be able to undo the battery from that point onwards to prove his point.
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#1983079 - 08/11/10 04:06 PM Re: Can vehicle run without battery? [Re: Quest]
Quest Offline
p.s. all other onboard/electrical accessories run off of the same power source (alternator) where it charges the battery + ignitions+ all the accessories combined. Battery only serve for the sake of turning over the starter motor while still provide enough juice for all the computer controls + ignition controls.
#1983080 - 08/11/10 04:06 PM Re: Can vehicle run without battery? [Re: Jeff3126]
VaderSS Offline
Loc: Cordelia, CA
Semantics... It won't start without a power source of some sort, and it won't run for long without an alternator.
Most spark ignition powered vehicles will run without the battery connected, but doing so can result in electrical surges that are not good for the electrical items.
'88.5 Samurai
'96 Impala SS
'07 Focus ST
'07 BMW F650GS
'08 Gold Wing
#1983081 - 08/11/10 04:07 PM Re: Can vehicle run without battery? [Re: VaderSS]
brianl703 Offline
Loc: Manassas, VA
#1983082 - 08/11/10 04:08 PM Re: Can vehicle run without battery? [Re: Jeff3126]
calvin1 Offline
Loc: Indiana, USA
It depends on the vehicle. Some only use the battery to power the starter and from there on it's just along for the ride. Others, especially newer ones use the battery as a reference voltage and require it to be in circuit for the car to operate properly. For example, I know for a fact that I can start my 2003 Taurus just fine off jumper cables with no battery. It will even sit there and idle and you can put it in gear and start to drive off but at about 15MPH it dies. I had a dead cell in my battery and I was doing everything I could to just get over to the parts store.
Edited by calvin1 (08/11/10 04:11 PM)
1994 BMW 530i/5spd - M1 0w40
#1983083 - 08/11/10 04:08 PM Re: Can vehicle run without battery? [Re: brianl703]
brianl703 Offline
Loc: Manassas, VA
In some cars the alternator is, under some conditions and especially at idle, not capable of supplying the full electrical demands of the vehicle.
#1983086 - 08/11/10 04:11 PM Re: Can vehicle run without battery? [Re: brianl703]
dparm Offline
Loc: Chicago, IL
The battery provides some level of protection in the rest of the electrical system from surges and drops. It would run but I can't really recommend it. Depending on the car's wiring, it may not work without the battery.
2011 BMW M3 sedan ZCP
#1983088 - 08/11/10 04:13 PM Re: Can vehicle run without battery? [Re: brianl703]
Jeff3126 Offline
Loc: S FL
I call it a draw. My father used to have a motorcycle in the '70s that could run off the magneto only with no battery. Thanks for the replies.
BTW I started my ranger, pulled the neg cable off and the vehicle continued to run. Turned the lights on, and she shut off.
Edited by Jeff3126 (08/11/10 04:15 PM)
#1983095 - 08/11/10 04:21 PM Re: Can vehicle run without battery? [Re: Jeff3126]
expat Offline
Loc: Canada
"I call it a draw."
Poor looser?
#1983105 - 08/11/10 04:40 PM Re: Can vehicle run without battery? [Re: dparm]
fdcg27 Online   content
Loc: OH
+1.
An old-school shade tree method of determining whether your problem was with the alternator or the battery was to start the engine and then disconect the negative cable from the batt.
If the thing continued running, and everything functioned with the lights on (horn, turn signals; high draw items IOW), then your problem was the batt. If the thing died at once, your problem was the alternator.
I have always though that disconecting the battery from a running vehicle was a bad idea.
There are VOMs for a reason, and a simple one is pretty cheap, and has a host of uses.
12 Accord LX 53K HGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 159K Delvac 15W-40
#1983117 - 08/11/10 04:56 PM Re: Can vehicle run without battery? [Re: fdcg27]
Panzerman Offline
Loc: Port Orange, Florida
I would say you need the battery in all newer vehicles. The alternator runs 13.5 volts to the battery which then sends out a stable amount of electricity to feed everything, I think unhooking a battery would "hopefully" blow out a fuse for the computer and all the electronics, if not it would fry alot of stuff by force feeding it high unregulated voltage. I started a Polaris atv without a battery and it blew every light bulb, because the battery was removed to stop the unwanted voltage. Bad idea. Cars can run without the alternator, and alot of stock car drivers take off the belts to get more power and just charge the battery after the race for the next start.
2007 Ford F-150 FX-2 73,000
2007 Ford F-150 FX-4 198,000 (Sold to the Son).
2006 Dodge Ram 2500 Sport 4x4 69,000
2002 Lincoln Continental 153,000
#1983121 - 08/11/10 05:03 PM Re: Can vehicle run without battery? [Re: Panzerman]
highmilegeguy Offline
Loc: michigan
No.
A battery is an integral part of the electrical system.
Removing the bat from the system when running will damage or destroy components.
#1983166 - 08/11/10 05:57 PM Re: Can vehicle run without battery? [Re: highmilegeguy]
ItsuMitsubishi Offline
Loc: Ajax, ON
Installing a large capacitor into the electrical system of a car works wonders, and keeps things safe!
Winter Tires or Insurance Premium?
Irony is...
#1983195 - 08/11/10 06:26 PM Re: Can vehicle run without battery? [Re: expat]
eljefino Offline
Loc: ME
There are milliseconds between diodes in the rectifier when zero current is being produced. One would be relying on the filtering capacitors in the radio etc to backfeed the rest of the car's electricity during that time.
In "ice road truckers" they were doing a routine inspection on an always-idling truck and discovered the batteries fell out and were somewhere on the tundra...
My old mercedes diesel would have run without any electricity at all, roll started, if it had a long enough run to build up heat without glow plugs. Popular escape vehicle for the EMP fearing crowd...
Page 1 of 3 1 2 3 >
