M1 0W40 - 5,222kms - 2005 Holden Commodore 3.6L V6
Townsville, Australia
Comments on report:
-Wear metals are within acceptable limits.
-Particle contamination is high and mainly due to dust particles.
-Oil condition appears satisfactory.
Genuine oil and air filter used and replaced.
Refilled with M1 0W40
I might try and find a different air filter.
First sample post: http://www.bobistheoilguy.com/forums/ubb...rue#Post1546536
Glad to see this UOA.
I have the same 0W-40 in my 3.6 Holden, and was planning on running it for about a one year interval or 8 to 10K miles.
I'm going to use M1 0W-30 in the other 3.6 V6 and do UOA's on both to see how they compare.
Dust is the biggest problem, I know well what a pain that is. When you say genuine, are you using an ACDelco air filter?
First samply sheared a lot - it's down into the low-30 weight range. Usually the 0W-40 shears to low 12/high 11 cst range.
In Auz, it MUST be expensive to run M1 0W-40 for only 5k km...I would have run it at least 3 times that! Ouch!
I'm not following you here. When I put the numbers into the viscosity calculator with the datasheet VI of 186, it looks like both samples are still SAE 40 weight at 100C.
Originally Posted By: Falcon_LS
Do you have the GM part number(s) for the air filter?
GM#: 92068161
The oil was in there for over 1 year. The car was not driven for a 6 week period and two 4 week periods.
Be nice to have the 100 degrees Celsius viscosity instead of speculating. Good report.. but I would expect no less with a premium oil at 3.3k miles.
