Volkswagen Looks to Build Its Own ‘Gigafactory’
by HTSS_TR
05/27/16 04:55 PM
QSAD 5W20 UOA 5,504 miles 2011 TAURUS 3.5
by dustyroads
05/27/16 04:48 PM
Why you need a dash cam
by Rand
05/27/16 04:12 PM
Performance exhaust question
by 007
05/27/16 04:08 PM
Positive results with BG109
by rainman49
05/27/16 03:11 PM
I have have put a lot of thought into this oil.
by Mathew_Boss
05/27/16 02:45 PM
CARQUEST Premium Oil Filter
by AirgunSavant
05/27/16 01:40 PM
The world's most harrowing route to school
by HTSS_TR
05/27/16 01:18 PM
STP 3614 Purolator cut and view
by sprite1741
05/27/16 12:58 PM
Finally saved up and bought my 1st car
by rocky8314
05/27/16 12:33 PM
Yellow dot and valve stem alignment
by qdeezie
05/27/16 12:30 PM
Shipping from Amazon
by grampi
05/27/16 12:14 PM
LEVY, Timmytimmy, Peakboy91, TimingBeltKing, watergate528
57997 Registered Users
72 registered (2oldtommy, aquariuscsm, 01_celica_gt, AlienBug, afree, 901Memphis, 3 invisible), 1781 Guests and 315 Spiders online.
57997 Members
66 Forums
249492 Topics
Page 1 of 3 1 2 3 >
#1981996 - 08/10/10 04:27 PM Oil change before smog test
saturnsw2 Offline
Loc: Southern CA
I need an oil change before getting a CA smog test. I failed by 4 points HC on the low speed (15mph) test. It passed everything else with flying colors. So I need to minimize the HC. A simple servicing should nudge it into compliance.
I changed the plugs and air filter. The old plugs looked fine. It was running great before and still is, no difference.
Oil is at about 7k -- mostly long highway trips -- so it's due. Started with Kendall 5w30, but makeup has been MaxLife 10w30. It stopped a small leak, and there's no more blue smoke at startup so it probably helped the valve seals. Uses a little less too. So I'll stick with MaxLife, or another HM if they're all just as good.
What viscosity though? Is it worth seeking out 10w30? Will higher vis, HM, or both help my HC for the smog test? Or will any fresh oil do that just as well?
If I can find a MaxLife change I'll go for it. Otherwise I'll get whatever's cheap and put HM in for makeup oil.
I'm going through 1qt/7-800mi, typical for an old Saturn S (188k). Otherwise the car runs great.
#1981999 - 08/10/10 04:34 PM Re: Oil change before smog test [Re: saturnsw2]
5sfe91 Offline
Loc: Corpus Christi,Texas
Kendall makes a HM oil I've seen it a Pep Boys if you want to continue using Kendall.
And welcome
1991 Toyota Celica 320,000 miles
Current fill
Peak 5w-30
#1982000 - 08/10/10 04:34 PM Re: Oil change before smog test [Re: saturnsw2]
StevieC Offline
Loc: Niagara Falls, ON, CA (near)
welcome to BITOG!
I would suck some Seafoam through a vacuum line with the engine revving at 2K RPM and fully warmed up.
Changing the oil will not help nudge a high HC at idle.
A long good drive with a PEA fuel based cleaner will if you have time before your next test.
If you have worn plugs have them replaced with the proper AC Delco ones.
Is your thermostat the correct temperature for your vehicle or did you change to a cooler one?
How many miles on the current coolant temperature sensor? If it is original this might be the cause.
Is your MAF clean? or is your MAP sensor worn out?
'06 Hyundai Sante Fe - 330K KM's
Current Oil: RLI 0w30 (Ask me why)
Don't be part of the Sheeple, check frequently for wool over your eyes. wink
#1982002 - 08/10/10 04:35 PM Re: Oil change before smog test [Re: 5sfe91]
eljefino Offline
Loc: ME
Yes do it and get 'er good and hot as well.
I liked pennzoil Long life 15w40 (but any HDEO will do) in an oil burning saturn, ran better too especially sitting in traffic getting warm then nailing the gas when the light turned green.
#1982013 - 08/10/10 04:48 PM Re: Oil change before smog test [Re: eljefino]
spasm3 Online   content
Loc: out there
run the tank low and put a lot of alcohol, denatured perhaps 20% or more. some e-85 fuel if you have a station nearby. after the test fill up .
13 elantra 46k 5w30 ultra
03 chevy avalanche67k pyb
02 saturnsc1 66k 0w40 castrol
01 saturnsc1 185k being rebuilt
93 ciera 79k 5w30 havo
#1982019 - 08/10/10 04:52 PM Re: Oil change before smog test [Re: spasm3]
Shannow Offline
Loc: Oz
I wouldn't run a smog test on fresh dino.
I'm thinking that there's going to be a short period of time early in an oil's life where it's more volatile than later.
Prolly wrong.
Nissan TD - Edge 5W30 A3/B4
L67 3.8 - Magnatec Stop Start 10W30
Mower - Preconditioned Edge 5W30, plus 5W50/SAE30
#1982021 - 08/10/10 04:52 PM Re: Oil change before smog test [Re: eljefino]
jona20062000 Offline
Loc: Memphis, TN
Hi,
Your problem made me want to read up, and here is a link I think would be helpful, too (for other noobs like me).
http://www.smogtips.com/failed-high-hydrocarbons-HC.cfm
#1982023 - 08/10/10 04:53 PM Re: Oil change before smog test [Re: StevieC]
saturnsw2 Offline
Loc: Southern CA
I'm concerned about hurting the cat if it's on its last legs.
No time for this. I do it periodically though -- maybe once a year.
Done. The old ones didn't seem worn at all when I pulled them out (~30k on them).
No, it's the correct one.
It's the "good" brass one so it was replaced at some point, but no idea how long ago. Seems the car runs too well for this to be bad.
I'll check.
Thanks!
#1982026 - 08/10/10 04:56 PM Re: Oil change before smog test [Re: saturnsw2]
StevieC Offline
Is your CEL on? If not then it's a stuck ring problem given the information you have given me. Do they check to see if the breather/PCV's are hooked up or do they just sniff the pipe?
Disconnecting them for the test and venting to the atmosphere (both if you have them, will help the HC's for sure if the rings are stuck as it won't be venting the blow by back into the engine.
Connect after your emission test and then concentrate on unsticking your rings with a seafoam soak etc.
Steve
#1982028 - 08/10/10 04:57 PM Re: Oil change before smog test [Re: jona20062000]
HTSS_TR Online   content
Loc: Lake Forest, CA
I would change oil now and add a bottle of fuel system cleaner such as Chevron Techron or Redline SI-1 in one tank before smog check.
Maxlife is available at Kragen, may be at Walmart. I stay with 5W30 or 10W30.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#1982038 - 08/10/10 05:14 PM Re: Oil change before smog test [Re: StevieC]
saturnsw2 Offline
Loc: Southern CA
Steve et al,
No CEL. Of course the rings are stuck but that's Saturns for you. Like I said, I don't want to do a Seafoam or whatever because that can definitely take a toll on the cat, which might be marginal. Besides I have nowhere to do this. It makes a smoky mess which would not go over well in my condo or neighborhood. Compression is fine. And I doubt this is affecting my low speed HC.
Just 4 points and I'll pass. So I'm hoping new plugs and filter, clean oil, pumped up tires, and a cool damp morning will do it, along with anything else that's simple.
Denatured alcohol might be a good idea. I was thinking about HEET which is the same thing, but maybe a bottle of that is not enough.
Also, I'm not changing my own oil, so it's hard to be choosy about brand. They charge too much for "premium" oil so I've been getting a basic $20-25 change then topping up with HM.
#1982042 - 08/10/10 05:16 PM Re: Oil change before smog test [Re: HTSS_TR]
saturnsw2 Offline
Loc: Southern CA
What about doing the test with that stuff in there?
#1982043 - 08/10/10 05:18 PM Re: Oil change before smog test [Re: StevieC]
saturnsw2 Offline
Loc: Southern CA
Everything has to be hooked up or the car won't pass "visual" inspection in CA.
I did check this, no cracks/leaks and the PCV valve seems fine (rattles like it should).
#1982057 - 08/10/10 05:38 PM Re: Oil change before smog test [Re: saturnsw2]
I would not do it.
My '94 LS400 was barely passed smog check some years ago, I used 1 bottle of SI-1 in 1 tank before the next smog check, the result was passing with 90% margin or more.
Since then I added 1 bottle of SI-1 or Techron in a tank before smog check for all my cars.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
#1982076 - 08/10/10 06:04 PM Re: Oil change before smog test [Re: StevieC]
Chris142 Offline
Loc: apple valley, ca
Originally Posted By: StevieC
welcome
I am going to disagree with you here. Changing the oil just before a smog test is a trick us Ca folk have been using for years to get through the Ca emission test.
I hope that the OP will post the before and after results for us to see.
Edited by Chris142 (08/10/10 06:04 PM)
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
Page 1 of 3 1 2 3 >
