Oil change on 2001 civic with some engine noises
by llmercll
19 minutes 7 seconds ago
Valvoline Cerulean
by Ramblejam
21 minutes 55 seconds ago
Highlander timing belt
by Carguy21
43 minutes 28 seconds ago
Saw my old Saturn Wagon in the wild!
by eljefino
Today at 04:23 PM
Went with Primewells
by Eric Smith
Today at 04:06 PM
121R Battery Group Size Alternatives ?
by neilwestlawn
Today at 03:52 PM
PARTS MASTER #67060, unknown miles, 2013 RAM truck
by car51
Today at 03:41 PM
All you ever wanted to know about carbon ceramics
by dparm
Today at 03:36 PM
New, UNUSED PSL-10241 CUT OPEN
by car51
Today at 03:27 PM
How bad is this?
by cnl64590
Today at 02:21 PM
Mag1 or ST Dino: what would YOU use?
by car51
Today at 01:54 PM
Ustria?
by Pontual
Today at 11:48 AM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
104 registered (69GTX, afoulk, 2cool, 1989outlaw, 2002 Maxima SE, Atesz792, 10 invisible), 1620 Guests and 198 Spiders online.
56834 Members
66 Forums
244322 Topics
#1974660 - 08/03/10 05:09 PM 3.5 hp Briggs and Stratton hard to start when cold
Popinski Offline
Loc: Ohio, USA
I have an old Briggs and Stratton 3.5 classic engine. When the engine is dead cold, the primer has trouble sucking in fuel. The primer itself is in good condition. After about 10 pumps on the primer, I can finally feel fuel coming in and my mower is ready to start. When the engine starts, it hesitates on idle and I have to push the primer to force fuel into the engine or else it'll stall. After doing this for about 3 minutes, the last 2 minutes where it is forcing fuel itself, the engine is weak. After about 5 minutes, or when the engine is warmed up, it goes to full power and back to normal; starting is good and strong with one pull.
Note: All maintenance has been done and I put carb cleaner mixed with gas every year.
"It doesn't matter what religion you are in, who you pray for, what you believe in, because the only thing you worship is OIL".
#1974689 - 08/03/10 05:39 PM Re: 3.5 hp Briggs and Stratton hard to start when cold [Re: Popinski]
demarpaint Offline
Loc: NY
Are you sure the primer is good, and the little hose that goes to it? I had one that was pumping well but the hose had a small tear in it, and was leaking. It could appear to look good and not be delivering enough fuel when you pump it. The carb float could be out of adjustment as well. Those are two areas I'd be looking at. Is the choke working properly?
God Bless Our Troops
#1974810 - 08/03/10 07:50 PM Re: 3.5 hp Briggs and Stratton hard to start when cold [Re: demarpaint]
Panzerman Offline
Loc: Port Orange, Florida
I think its the hose going to the primer, just one pin hole lets it suck air. I had a hard starting lawnmower once, I just gave it a snort of ether and it fired right up first pull. Not very healthy, but those Briggs are indestructable and the motor still outlived the deck.
2007 Ford F-150 FX-2 71,000
2007 Ford F-150 FX-4 192,000
2006 Dodge Ram 2500 Sport 4x4 64,000
2002 Lincoln Continental 148,000
#1974970 - 08/03/10 10:18 PM Re: 3.5 hp Briggs and Stratton hard to start when cold [Re: Panzerman]
Popinski Offline
Loc: Ohio, USA
If it's the primer hose then why does it act normal when the engine heats up? I checked for gas leaks, there are none.
#1976336 - 08/04/10 10:21 PM Re: 3.5 hp Briggs and Stratton hard to start when cold [Re: Popinski]
yeehaw1960 Offline
Loc: Nebraska
Ain't no hose. Pull the tank, remove the carb and blow it out. Empty every drop from the tank. Replace diaphram if necessary. Will be a whole new engine. OLD POST FOLLOWS.
Take the air filter off the carb. Take a digital picture from top view to remember what's what. Take the two bolts out that hold the carb/tank assembly on the engine. One in center close to engine ˝ or 3/8 inch, one on spark plug (right) end, 7/16 or 3/8 inch, as you look at assembly. As you pull the assembly off, you’ll have to finagle the linkage off the top of carb. Remember how the rod and spring(s) look (take digital picture) for reinstallation.
Take the 5 screws out that hold the carb to tank. Pull apart. Push primer bulb to get all gas out of carb. Blow it out with air if you have it, but remember to keep track of the spring on bottom of carb. If you blow compressed air into the little hole at the base of the long pick up tube, you may pop your primer bulb. Dump as much gas out of tank as possible. Blow air into reservoir on top tank or wipe out with rag as good as you can. Go to repair shop (with diaphragm/gasket) and get a new one. Reassemble and mow away! The thin diaphragm goes on the tank, then the gasket, then the carb. Have fun!
