Rotella for 6.0L Gasser
by Joefuskie
Today at 04:40 PM
Pennzoil Platinum Euro 5W-40
by 1JZ_E46
Today at 04:21 PM
TGMO 0W20 7700 miles UOA
by micmac
Today at 03:45 PM
"Low Coolant" light doesn't vanish.
by OpenClose
Today at 02:07 PM
Is running "Engine flush" before a change legit?
by OpenClose
Today at 01:59 PM
Who Owns A Beater?
by Red91
Today at 01:09 PM
What prevents pics from being viewed on posts?
by daves66nova
Today at 12:42 PM
QS Filter Miles
by Yup
Today at 12:23 PM
Denso Irdium plug at 68k miles
by SHOZ
Today at 12:19 PM
Chrome bumpers from RockAuto. Good quality?
by mrsilv04
Today at 12:00 PM
Krown Rust Proofing illegal in U.S.
by Warstud
Today at 11:49 AM
fixing the t/a
by turtlevette
Today at 10:55 AM
Dmax7901, carver1, Handy7rick, sicilien, Crater_77
57738 Registered Users
92 registered (1JZ_E46, 2015_PSD, 2004tdigls, Astro14, Abakev, aquariuscsm, 8 invisible), 1707 Guests and 103 Spiders online.
57738 Members
66 Forums
248221 Topics
#19730 - 03/03/03 04:36 AM Best Dino oil for cold weather climate?
Tommy2 Offline
Loc: Montréal, Canada
Hello everyone. I am learning a lot from this website and wanted to ask what is the best dino oil out there for this cold weather and my driving habits.
Currently I live in Montreal, Canada and using 10w30 Castrol in my Taurus SHO. I start the car in 40ºF (heated garage) and drive it to work (4 miles one way) and park it outside where it averages from -10ºF to 5ºF. Then I use my automatic remote starter which starts the vehicle every 2 hours to "keep" the fluids warm.
What are your opinions, should I stick with Castrol's 10w-30 or should I use another dino oil. I don't use synthetics because I change my oil every 3 months/3K miles. Thanks.
#19731 - 03/03/03 05:12 AM Re: Best Dino oil for cold weather climate?
Ken2 Offline
Loc: Washington St.
Use a 5W-30 in the winter. Or use a synthetic 5W-30 for just the winter oil change.
I don't like to idle an engine to warm it. I prefer to start it and drive it easy as soon as it's driveable.
Ken
[ March 03, 2003, 09:13 PM: Message edited by: Ken2 ]
#19732 - 03/03/03 07:14 AM Re: Best Dino oil for cold weather climate?
ryansride2017 Offline
Loc: The coal hills of eastern PA
I think you are doing far more damage by idling the car [No no] just to "keep the fluids warm". In that type of climate, I would use a good quality synthetic in the 0W30 grade and change the oil every 5K miles to offset your cost increase.
#19733 - 03/03/03 12:53 PM Re: Best Dino oil for cold weather climate?
Patman Offline
Loc: Oakville, Ontario
Castrol GTX doesn't have very good cold weather properties, I'd say next winter you should run either Pennzoil 5w30 or Havoline 5w30, both of which have very good cold weather behavior.
#19734 - 03/04/03 08:08 AM Re: Best Dino oil for cold weather climate?
Al Offline
Loc: Elizabethtown, Pa
[Welcome!] I would go for the 5W stuff and also would not do the 2 hour remote start stuff...bad idea. [Smile]
#19735 - 03/03/03 11:32 PM Re: Best Dino oil for cold weather climate?
PontTransAm1978 Offline
Loc: Maine
quote:
Am I reading that Right? Doesnt everyone in here give praise to GTX? And I asked if using 5w-30 to break in an engine was ok, and everyone said yes.... [Frown] I havent changed the oil yet from what came in the factory. Should I consider something else?
#19736 - 03/04/03 12:46 AM Re: Best Dino oil for cold weather climate?
Patman Offline
GTX does show very good wear numbers, but it's not so stellar cold weather properties mean it's better to be used in a warmer climate.
[ March 04, 2003, 04:47 PM: Message edited by: Patman ]
#19737 - 03/04/03 05:48 AM Re: Best Dino oil for cold weather climate?
Tommy2 Offline
So what non-synthetic oil brand should I use for winter?
#19738 - 03/04/03 01:42 PM Re: Best Dino oil for cold weather climate?
Patman Offline
Out of the stuff commonly available to us Canadians, Pennzoil and Havoline have the best cold weather properties out of the dino oils. Although if it gets down below -25C where you live, I'd highly suggest going with synthetic for the winter.
[ March 05, 2003, 05:43 AM: Message edited by: Patman ]
#19739 - 03/04/03 04:17 PM Re: Best Dino oil for cold weather climate?
JonS Offline
Loc: USA
I would recommend Havoline 5w-30. I use it in MN and all winter it is -20f at night. If you have colder than -30f go with a synthetic.
#19740 - 03/06/03 06:28 PM Re: Best Dino oil for cold weather climate?
Oldswagon Offline
Loc: ON
I use Pennzoil dino in temperatures around -35C and had no problems. Considering the temperature, it builds up pressure well.
#19741 - 03/10/03 05:45 AM Re: Best Dino oil for cold weather climate?
mebanditws6 Offline
Loc: Evansville, In.
For cold weather starting, I've found cheap ole Coastal to do very well in 20 degree weather. Only reason I used this stuff was to do an auto-rx treatment cause it was cheap. But I went from GTX HM 10w40 to Coastal HM (high mileage) 10w40, and the first cold start there was a noticeably quicker pressure build up with the Coastal, pretty much instantaneous whereas the GTX took about at least a second to build pressure.
Jason
