2005 Volvo S40 2.4i - Optimal Oil Choice?
by mgm7890
27 minutes 5 seconds ago
Something for a quiet Saturday, vapors...
by OneEyeJack
52 minutes 1 second ago
Ford guys: Crown Vic windshield washer not working
by Jimmy9190
Today at 12:08 PM
Very cold outside, vehicle sitting for a few day's
by 07titan
Today at 11:26 AM
compression fittings and fuel starvation
by eljefino
Today at 10:47 AM
Anyone here make a homemade jump starter pack?
by skyactiv
Today at 10:31 AM
API *SL* Oil Still on Shelf
by CrackyWainwright
Today at 10:17 AM
Jeep "shudders" at 35-40 mph
by Joe_Power
Today at 09:27 AM
How Often to Drain and Refill AT's?
by Gebo
Today at 09:18 AM
Gas water heaters
by spasm3
Today at 08:59 AM
Woman killed by flying manhole cover in Boston
by Mr Nice
Today at 08:56 AM
Fresh oil change - dipstick smells like exhaust
by ragtophardtop
Today at 08:50 AM
wdleighton1, RTS, jhmed80, engus, Rob_Pol
56902 Registered Users
85 registered (Branson304, bbhero, BrocLuno, 90crvtec, BMOC, Boss302fan, 9 invisible), 1870 Guests and 100 Spiders online.
56902 Members
66 Forums
244645 Topics
#1968418 - 07/28/10 01:44 PM Honda gx160 Question
red0944 Offline
Loc: Tennessee
I have a honda gx160 engine on a go kart and it randomly started leaking gas and has gas coming out the muffler. Any ideas what could be causing th problem and how to fix it.
Thanks,
David
#1968424 - 07/28/10 01:51 PM Re: Honda gx160 Question [Re: red0944]
countryboy9799 Offline
Loc: SW MN
It's just leaking out the exhaust? If so the float in the carb is leaking gas into the cylinder, not good because it will get into the oil. I would either fix the carb or put a fuel shut off in the line going to the carb. I have 2 engines that do this and that is the easy fix.
Although if the kids run it themselves they probably wont remember to shut it off.
2012 Subaru Outback 45,000 Miles
1999 Dodge Cummins 125,000 Miles
2014 Toyota Corolla 40,000 Miles
#1968452 - 07/28/10 02:17 PM Re: Honda gx160 Question [Re: countryboy9799]
red0944 Offline
Loc: Tennessee
I think its just exhaust went to crank it this morning and it wouldnt crank, then noticed the puddle of gas and the wet muffler. I'll clean the carb and see if that fixes the problem. Ill also change the oil to try and eliminate an other issues. But the karts are for an actual track so putting the fuel shut off on would be difficult having to constantly turn it on or off.
Thanks for the advice and I'll let you know how it works out
David
#1968456 - 07/28/10 02:22 PM Re: Honda gx160 Question [Re: red0944]
Loc: SW MN
On my mower that does this it wont crank because if you have to much liquid in the cylinder it wont compress. Just have to remove the spark plug and crank a bit to clean the cylinder out.
On my mower that I forgot to shut it off I probably had 3 or 4 oz in a 48 oz sump, I needed to mow so I let it warm up to burn off some gas and when I was done mowing the oil went from originally being at the full mark to over the full mark because of the gas and when I was done mowing it was on the add line, I drained it at this point.
Anyone know if it hurts the oil once the gas has been burned off?
#1968588 - 07/28/10 04:17 PM Re: Honda gx160 Question [Re: countryboy9799]
Cujet Offline
Loc: Jupiter, Florida
Air cooled aircraft engines can use fuel dilution to thin the oil in very cold weather. This makes starting possible in Alaska.
While, it's not "good" for the engine, it works well enough.
However, the aircraft engine oil is different from modern automotive oils (which are much thinner).
I'd guess the needle and seat are bad, possibly due to ethanol in the fuel. I'd replace them. Also consider a fuel shut off valve.
I'd also change the oil.
Turbo's rule.
#1968859 - 07/28/10 09:35 PM Re: Honda gx160 Question [Re: Cujet]
tomcat27 Offline
Loc: Midwest
yes, it sounds like the needle valve is stuck open.
2014 Sentra, 2005 Starcraft Aurora 2410, 2002 Echo
2002 Intrepid, 2002 Liberty, 1998 Dodge B1500
1996 Sebring Jx, 1995 Jeep ZJ, 1970 Cougar, 2001 Camry
#1969347 - 07/29/10 12:57 PM Re: Honda gx160 Question [Re: tomcat27]
red0944 Offline
Loc: Tennessee
Thanks for the advice. I replaced the carb with another spare we had, however the engine still isnt running right have to run partially choked because with the choke off completely it stalls and sputters. Changed and drained the oil there was a lot of gas mixed in with the oil but has been replaced and changed spark plug as well. Any ideas or suggestions on what could be causing the problem with the sputtering. Thanks again for all advice an help.
Daivd
#1969423 - 07/29/10 02:12 PM Re: Honda gx160 Question [Re: red0944]
Loc: SW MN
If you have to run the choke partially it is most likely the carb is gummed up a little or dirty where the jets are. If the jets get plugged less gas can go through and if you choke it then the mixture will be better. You could try seafoam or something similar but if it is gummed up it might take awhile for that to work.
#1969763 - 07/29/10 08:40 PM Re: Honda gx160 Question [Re: countryboy9799]
Pete591 Offline
Loc: Michigan
With that model engine..and I have one...clean carb and it runs like a Ferrari...a little gumming and it floods or hard to start.
#1970228 - 07/30/10 09:27 AM Re: Honda gx160 Question [Re: Pete591]
red0944 Offline
Loc: Tennessee
What would you recommend to clean the carbs I have been told several different things. I have been told not to use regular carb cleaner because it will ruin the seals. Another person told me to use degreaser to clean them but that only seems to get some of the funk not all of it. Any help and suggestions is appreciated.
#1970420 - 07/30/10 12:17 PM Re: Honda gx160 Question [Re: red0944]
tom slick Offline
Loc: Central Coast, Calif.
My GCV160 was only running with the choke on. cleaned the carb twice, and then noticed one of the intake gaskets was slightly pushed up and allowing a big vacuum leak. Check the intake gaskets.
You get what you pay for...
So keep in mind how much you paid for this advice.
