JASO vs. Auto Oil for non-wet clutch Powersports
by coachvonyo
4 minutes 46 seconds ago
Why Does Some Oil in Engine Smell "Worse"?
by Miller88
7 minutes 30 seconds ago
Kevlar covered v-belt question.
by mrsilv04
29 minutes 47 seconds ago
1991 yamaha xt600 NY registration questions.
by joegreen
Today at 06:18 AM
postal LLV wiper switch arm broke off
by Tuffy1760
Today at 05:07 AM
2GR-FE Water Pump Noise
by The Critic
Today at 03:36 AM
Castrol & Shell oil sale in Oz
by SR5
Today at 02:45 AM
UOA Mobil Delvac MX 15w40?
by nyumski
Today at 02:13 AM
2015 Silverado - Put some chrome
by Realtech214
Yesterday at 10:22 PM
Ticks!
by spasm3
Yesterday at 09:54 PM
shop didn't replace clamps on steering rack
by motor_oil_madman
Yesterday at 09:46 PM
First SSD on Xubuntu 16.04
by Eric Smith
Yesterday at 09:20 PM
myfarmertan, coachvonyo, ionix, Amtecol, DRAX392
57779 Registered Users
79 registered (19jacobob93, A_Harman, 06AllAmerican, anl0109, B320i, 97f150, 8 invisible), 1231 Guests and 323 Spiders online.
57779 Members
66 Forums
248395 Topics
Page 1 of 2 1 2 >
#1945109 - 07/07/10 08:19 AM Need help: MAZDA ATF M-III or Motorcraft Mercon-V
windeye Offline
Loc: NY, USA
I have a 2007 mazda3 that calls for Mazda ATF M-III for power steering. I also have a 2000 Mazda MPV that specs the M-III for the 4-speed automatic transmission (Ford calls the ATX 4EAT-G, Mazda calls it GF4A-EL). I am about to pull the trigger for the Motorcraft Mercon-V based on Ford's ATF application guide, but just found out from one dealer that they do have the M-III available. I need the fluid to do a DIY ATF exchange. Previous trans services were done at a Ford/mazda dealer, and they used Mercon, which is now superseded by Mercon-V. The prices for the two fluids are comparable, so please help me choose which one is better for the 2000 Mazda MPV ATX. Thanks.
#1945114 - 07/07/10 08:22 AM Re: Need help: MAZDA ATF M-III or Motorcraft Mercon-V [Re: windeye]
sangyup81 Offline
Loc: Bowie, MD
if they are similar priced, go with the M-III
#1945149 - 07/07/10 08:56 AM Re: Need help: MAZDA ATF M-III or Motorcraft Mercon-V [Re: sangyup81]
windeye Offline
Loc: NY, USA
Thanks for your comment. My main concern is the performance of the fluid. Motorcraft Mercon-V seems to be a better spec than the old Mazda ATF M-III. If the Mercon-V works well in the 4EAT-G trans of the 2000 Mazda MPV, I'd like to use that, since it's more readily available than the M-III, which took detective work to find out (I had to give the part number to the parts dept; when I simply asked what the ATF for 2000 mazda mpv, I got Dexron-III as an answer; when I told them Dexron-III is not longer made, they the told me to use Mercon-V).
#1945881 - 07/07/10 07:10 PM Re: Need help: MAZDA ATF M-III or Motorcraft Mercon-V [Re: windeye]
unDummy Offline
Loc: RI
I wouldn't bother with either. Use a full synthetic ATF like Mobil1, RoyalPurple, Amsoil, or Redline.
With the typical lack of maintenance that PSF's usually see, I'd upgrade at the 1st opportunity. Mercon-V is a synth blend and a step above mineral DexII/M-III.
Those who say it cannot be done, should not interrupt the person doing it.
Your automaker lied!
Is this a spelling/grammar forum or BITOG?
#1945960 - 07/07/10 08:10 PM Re: Need help: MAZDA ATF M-III or Motorcraft Mercon-V [Re: unDummy]
windeye Offline
Loc: NY, USA
Thanks. Here's the link to the Motorcraft Mercon-V, there's data sheet and a MSDS available. I am no petro engineer, can you confirm that Motorcraft Mercon-V is synth blend?
http://www.fcsdchemicalsandlubricants.com/Main/product.asp?product=MERCON%AE%20V%20Automatic%20Transmission%20and%20Power%20Steering%20Fluid&category=Transmission%20Fluid
Edited by windeye (07/07/10 08:11 PM)
#1965093 - 07/25/10 11:05 AM Re: Need help: MAZDA ATF M-III or Motorcraft Mercon-V [Re: windeye]
FusilliJerry82 Offline
Loc: Richboro, PA
I used Walmart Supertech Dex/Merc (Dexron III/Mercon equivalent) in my 2000 Protege which also calls for M-III with good results. Just change it out more often.
2000 Protege 1.6 215k - Mopar Max Pro 10w-30/Mopar Oil Filter
#1965300 - 07/25/10 03:09 PM Re: Need help: MAZDA ATF M-III or Motorcraft Mercon-V [Re: FusilliJerry82]
miller_cycle Offline
Loc: southern midwest
I've been using SuperTech Dexron VI in my 1999 Millenia's LJ4A-EL (which also calls for M-III) for over two years now, so probably close to 25,000 miles ago. I've also flushed my power steering fluid with Dexron VI around the same time. No issues whatsoever.
#1965879 - 07/26/10 06:52 AM Re: Need help: MAZDA ATF M-III or Motorcraft Mercon-V [Re: windeye]
Char Baby Offline
Loc: Western NY
Hmmm! My daughters Mazda3 2.0L auto calls for M-V IIRC. I'll have to check!
"Retired"
'80 Firebird FORMULA V8/4bbl-NEW
'06 Mazda 3i 2.0L-Pre Owned
'15 Nissan Altima 2.5 SV-CPO
Still looking for a car for my wife(new, used, CPO)
#1965891 - 07/26/10 07:11 AM Re: Need help: MAZDA ATF M-III or Motorcraft Mercon-V [Re: Char Baby]
badtlc Offline
Loc: KC
That is correct and MerconV is not a suitable replacement.
2007 Ford Escape XLS 2.3L ATX, Trop Artic 5W30, MC Fl910s, 135k+
2015 Chrysler T&C, 40k+
#1966887 - 07/27/10 08:16 AM Re: Need help: MAZDA ATF M-III or Motorcraft Mercon-V [Re: badtlc]
Char Baby Offline
Loc: Western NY
I used Castrol Import Multi Vehicle ATF
"Retired"
#1967731 - 07/27/10 08:07 PM Re: Need help: MAZDA ATF M-III or Motorcraft Mercon-V [Re: Char Baby]
chevys10 Offline
Loc: Chicagoland
I have the GF4A-EL transmission in a 2000 Mazda 626. I have changed the fluid twice since new. First time the stealership flushed it with whatever OEM fluid they used, second time I used a combo of Supertech and Meijer brand Dex/Merc. I currently have 15 or so quarts of Valvoline Maxlife ATF that I will be putting in it in a few weeks. I got it for around $3.25 a quart out the door using the Advanced coupon. Seems to be a recommended bang for the buck fluid on the board. I never really noticed a difference in shifting with either previous fluid.
FWIW, the dipstick is stamped ATF M-III or Dexron II, Mercon
2008 Odyssey EX P P520 Fram Ultra Fil
2007 Accord V6 PP530 Bosch D+ Fil
2000 626 2.5L Synpower 10w30 P1 Fil
1997 Ranger 2.3L NG 530 MC Fil
#1967778 - 07/27/10 09:01 PM Re: Need help: MAZDA ATF M-III or Motorcraft Mercon-V [Re: chevys10]
ItsuMitsubishi Offline
Loc: Ajax, ON
This is almost unbelievable. M-V is not a special specification at all, despite what some heads might say.
M-V as a "spec" was chosen because it can be loosely interpreted as Multi-Vehicle or MerconV, which all Multi Vehicle fluids inherently conform to. Mercon V is nothing special either, it's simply the new Mercon, which was identical to Dexron III, which no longer exists. Heck, Dexron VI (VI presumably boasts it's Viscosity Index, and doesn't mean 6) can be used in most Mercon V applications without an issue, only differing in an Afton Chemical addpack over say Lubrizol and being 1cSt thinner, but more shear stable. I mean, the mainstream fluids are pretty much standardized without being officially standardized, causing manufacturers "make up" their own specification names for the "not using a competing brand's spec" reason.
Winter Tires or Insurance Premium?
Irony is...
#1967783 - 07/27/10 09:10 PM Re: Need help: MAZDA ATF M-III or Motorcraft Mercon-V [Re: windeye]
Loc: Ajax, ON
I'm curious why would you consider using an older, non-synthetic ATF from the dark ages (M-III) over the semi-synthetic product of superior quality (Mercon V) which also was intended to superscede it? From personal experience, the GF4A-EL transmission was one of the higher tech boxes of the time, one which the fluid of the time wasn't up to task for. It debuted in 92' when all we had was ATFs that amounted to kerosene mixed with VIIs & red food colouring and many of them failed because the fluid would break down too easily under the heat of the box. It's 2010 now, I'd strongly advise using a better, current spec rather than searching high and low for a doo doo ATF from ye olde days.
Irony is...
#1967876 - 07/27/10 10:46 PM Re: Need help: MAZDA ATF M-III or Motorcraft Mercon-V [Re: ItsuMitsubishi]
chevys10 Offline
Loc: Chicagoland
How about the best of both worlds? A synthetic old school Dex II/Mercon...HA!
http://www.redlineoil.com/product.aspx?pid=50&pcid=9
#1967877 - 07/27/10 10:47 PM Re: Need help: MAZDA ATF M-III or Motorcraft Mercon-V [Re: ItsuMitsubishi]
3311 Offline
Loc: Fl
Mercon v is not Mazda M-V: http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1628444
I saw the above im few places around the net while looking for the correct fluid for my wifes 08 Mazda 3i.
I do agree that M-V is nothing special based on what I cleaned out of the pan. Actually IMO M-V is garbage!! No fluid should be that rancid,discolored and have that much sludge in the pan at 45k (about 80% highway miles, wish I would have done a UOA.
Actually did a drain fill with Castrol Import, then a week later dropped the pan for a filter and used Maxlife Dex/Merc. And after about 8k its working well, actually helped a 2nd shudder that the car would get going up a hill.
04 2500hd 6.0 278k/1k Pen HM 5w30 10w40 mix XG3675 VML ATF Dex
03 C7500 Dmax7.8l 134k ST 15w40,M1ATF Dex
06 2500hd 6.0 220k ? 5w30 ST DexVI PGL
Page 1 of 2 1 2 >
