Industrial hand cleaners?
by KenO
07/26/16 11:58 PM
Shell Rotella T6 in a Altima 2.5
by Grambo
07/26/16 11:24 PM
"Creaking" Conti DWS's?
by Lolvoguy
07/26/16 10:52 PM
Check your car after it's been worked on
by Nick1994
07/26/16 10:15 PM
How are lg android devices now days?
by ram_man
07/26/16 09:42 PM
Dexos 5w30 with highest 100°c Viscosity
by CapitalTruck
07/26/16 09:32 PM
How do you avoid being perceived as a rookie when
by motor_oil_madman
07/26/16 09:27 PM
Oil opinions after dumping FF
by JoelB
07/26/16 09:27 PM
Bulk loading a grease gun?
by buck91
07/26/16 08:59 PM
Sears Battery Pricing
by PeterGreen
07/26/16 08:29 PM
My 12am emergency strut spring repair on a Civic
by Colt45ws
07/26/16 08:19 PM
My upper sidewall pinehole leak fix
by Pokermatters
07/26/16 07:52 PM
snydercn, surfbum, Tmemz4, woollum86, Phil108
58612 Registered Users
27 registered (Charlie1935, ChristianReske, 182RG, Bottom_Feeder, CrazeeDad, 2 invisible), 843 Guests and 14 Spiders online.
58612 Members
66 Forums
252296 Topics
#1944185 - 07/06/10 11:25 AM Cruise control not engaging
EricZoom Offline
Loc: South FLorida
I had my brake light switch replaced recently, and now my CC doesn't seem to work. It goes on and lights up when I press the button on the wheel, but when i'm moving it won't engage it. Can this be related to the brake light switch? Thanks.
04 Mazda6s - M1 EP 5w20
11' Cad SRX - No more DIY OC's, All covered under warranty
#1944194 - 07/06/10 11:35 AM Re: Cruise control not engaging [Re: EricZoom]
CourierDriver Offline
Loc: Tn.
disconnect the neg cable on ur battery and see if it resets thru the computer, I really dont know the answer, but when my dodge stuff acts up , I do that first, sometimes it works.n Leave the cable off for 10 minutes too.
If I told you to invest in something that would cost $24k,go down in value,cost over $2K a year to operate,you would say Im crazy,,,got a car??
#1944197 - 07/06/10 11:39 AM Re: Cruise control not engaging [Re: CourierDriver]
EricZoom Offline
Loc: South FLorida
Thanks, maybe I'll try that.
#1944213 - 07/06/10 11:55 AM Re: Cruise control not engaging [Re: EricZoom]
Jim 5 Offline
Loc: Calgary Canada
Brake switch is the most common issue for cruise control problems given that no electrical switch in the car likely gets as many cycles as this switch.
There are usually two circuits on a brake switch and both of them need to be functioning properly for the cruise to work. Just because your brake lights are functioning, doesn't mean the switch is working properly. I had this same issue on my Chev K1500 a few years ago.
I strongly suspect your brake switch especially since it was recently changed. I'd start by checking if all the wires are connected. There should be at least 4 wires attached.
Jim A
07.5 GMC Sierra 2500HD LMM Rotella 15w-40
09 Odyssey EX-L CT 5w-20
66 Bronco QS 10w-30
08 BMW K1200S Rt 15w-40
08 Pitster Pro X4 Rt 15w-40
#1944217 - 07/06/10 12:02 PM Re: Cruise control not engaging [Re: Jim 5]
SLCraig Offline
Loc: London, ON, Canada
Definitely connected.
When you touch your brakes with cruise on, it will disengage. There is something going on there.
Also, I had the problem on my old Altima where the clutch pedal switch was causing engagement problems of the cruise.
2010 Civic SI sedan 6MT
SynPower 5w30 | Fram Ultra | Pennzoil MTF
#1944218 - 07/06/10 12:03 PM Re: Cruise control not engaging [Re: SLCraig]
Jim 5 Offline
Loc: Calgary Canada
Good point about the clutch pedal switch. If you have one, this would be just as important and likely to wear.
Jim A
66 Bronco QS 10w-30
#1944227 - 07/06/10 12:08 PM Re: Cruise control not engaging [Re: SLCraig]
EricZoom Offline
Loc: South FLorida
My car is an ATX, so no clutch. The only thing is the on/off button comes on. It's when i'm moving, it won't engage.
I went back to where I had it installed, and the guy said since it comes on, it must be something else, not the switch.
#1944247 - 07/06/10 12:30 PM Re: Cruise control not engaging [Re: EricZoom]
Anies Offline
Loc: NJ
I am assuming this is the Cadillac? If it's the Caddy, your BCM will be the culprit. The BCM is bain on most 2000+ GM vehicles. I had lost Cruise Control at some point in my Impala amongst other things and finally replaced the BCM and blam that and everything else that stopped working is now working.
If its the Mazda, I'll leave it to the others.
2012 Nissan Frontier SL V6 (mine)
2014 Ford Fusion SE w/Tech (wifey)
+Dealer Serviced
#1944256 - 07/06/10 12:37 PM Re: Cruise control not engaging [Re: EricZoom]
KrisZ Offline
Loc: Toronto, Canada
If you're talking about your Mazda 6, then the On/Off button is just for arming/disarming the cruise control, and is not dependant on the brake, so your mechanic is wrong and this may be related to the brake light switch.
My Mazda 3 has two light indicators for cruise control, your 6 should be the same, one is called "Cruise Main" and is activated by the On/Off switch, it will remain on, no matter if the cruise is actually engaged or not, pressing the brake pedal will not turn this light off either. Then there is the "Cruise" light that comes on only if the cruise is actually engaged and will shut off if the cancel button or brake pedal is pressed.
If “Cruise” light never comes on when trying to engage cruise, then the brake switch is likely the cause, especially if cruise was functioning properly prior to switch replacement. Also I think your mechanic is just being lazy, because the first rule of troubleshooting is to check the last thing you changed that might be related to the problem, and the brake light switch is directly linked to cruise control operation, instead of dismissing it out right.
Edited by KrisZ (07/06/10 12:45 PM)
2015 Dodge//Grand Caravan-FF dumped
2006 Mazda 3-135k miles
#1944272 - 07/06/10 12:55 PM Re: Cruise control not engaging [Re: KrisZ]
dwendt44 Offline
Loc: Central Wisconsin
Had a Chevy truck once that did this.
The brake switch needed adjustment. Problem fixed.
As the brakes wear, the pedal hung a bit lower, just enough to trip the switch.
Try adjusting the switch for better contact.
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
#1944301 - 07/06/10 01:25 PM Re: Cruise control not engaging [Re: dwendt44]
mechtech2 Offline
Loc: Chicago Area
The brake has a switch/disconnect for the cruise control.
This is almost assuredly your present problem.
#1944379 - 07/06/10 02:24 PM Re: Cruise control not engaging [Re: mechtech2]
EricZoom Offline
Loc: South FLorida
Thanks for all the responses. This problem is obviously happening on my Mazda. If it was the Caddy, I would of been covered under warranty.
I do have the same setup as KrisZ's Mazda3 where there's 2 buttons for the CC, and the main one just turns in on. I'm going back to the [censored] shop tomorrow to have him look at it. Hopefully this Putz will not try to talk his way out of it. It seems to be pointing to a problem with the replaced switch being defective, or
not installed correctly.
#1944673 - 07/06/10 08:14 PM Re: Cruise control not engaging [Re: EricZoom]
Jim 5 Offline
Loc: Calgary Canada
I'd just let him know that you can take it to him where he can fix it for free, or you can take it elsewhere and if it is diagnosed as a brake switch installation problem then you'll be presenting him with the bill.
Jim A
66 Bronco QS 10w-30
