'88 Caddy Brougham - dark oil + lifters noise
by momo
06/29/16 02:57 AM
Which Oil
by Jamn
06/29/16 02:11 AM
Oil for Binding Foundry Sand
by smw
06/29/16 01:38 AM
Found a good high zinc breakin oil
by 1977c10phxdriver
06/29/16 01:12 AM
What is this radio modulating sound?
by Pontual
06/29/16 01:00 AM
The reason brake fluid can be Dot 3&4 - Viscosity!
by CharlieBauer
06/29/16 12:56 AM
No injector pulse, '92 Prelude, F20B, GSR ECM
by redhat
06/29/16 12:02 AM
Finding #1 Cylinder
by motorguy222
06/28/16 11:31 PM
Sure Filter 2821A C&P
by funflyer
06/28/16 11:27 PM
Can Kies save multiple phone info?
by daves66nova
06/28/16 11:25 PM
Tie-Rod Brands? AcDelco, B&A, Mevotech, MOOG
by Mr_Accord
06/28/16 10:23 PM
Engineer and Frog
by Koop
06/28/16 09:05 PM
dougsangster, CrazyCalvinW, mal86, smw, Crobinson16
58311 Registered Users
24 registered (Darris, cobra7279, Bookmaker, dec219644, alcyon, 2 invisible), 830 Guests and 12 Spiders online.
58311 Members
66 Forums
250966 Topics
Page 1 of 4 1 2 3 4 >
#191786 - 05/19/06 10:54 AM benefits of 20w50?
jayno20 Offline
Loc: Indiana, PA
i have a 2000 chrysler sebring with about 90k on it, i have been using 10w30 since i'ved owned it.. what benefits come along with using 20w50? is it better for the engine or what i've heard of a lot of people using it..
#191787 - 05/19/06 11:05 AM Re: benefits of 20w50?
Jonny Z Offline
Loc: Austin, TX
No. I've heard a lot of people also smoke cigarettes.
#191788 - 05/19/06 12:14 PM Re: benefits of 20w50?
Weasel Offline
Loc: California
You don't want 20w-50 in your Sebring. It is an oil of higher viscosity at all temperatures. In engines with large clearances due to design/assembly, or severe bearing and oil pump wear, a thick oil can improve oil pressure and reduce noise. However, thicker oil requires more energy to pump and results in more drag on moving parts than thinner oil. In your car you would likely experience a reduction in fuel economy and slower response than the 10w-30. In my Integra which had 260k miles and was burning some oil I switched from Mobil 1 10w-30 to 15w-50, and the loss of power was dramatic, enough so that if I hadn't sold the car I would have put up with the quart per 500 miles consumption in exchange for the power.
Will it kill your engine? No. Maybe if used in below 5f to 10f temps.
Is there ever a good reason to use it? Sometimes (some will disagree.)
Should you use it in your car? That's up to you, but I wouldn't do it.
#191789 - 05/19/06 12:25 PM Re: benefits of 20w50?
hominid7 Offline
Loc: North Texas
20w50 is best left for older german cars and lawn mowers. 90K on your seabring is nothing to worry about. Keeping up a regular oil change interval with a decent 5w30 or 10w30 is the best thing you can do for it. I believe the recommended oil for your car would be 5w30 however not the 10w30 you are using.
#191790 - 05/19/06 12:31 PM Re: benefits of 20w50?
hominid7 Offline
Loc: North Texas
quote:
[Off Topic!]
But interestingly 3x the population in Japan smoke cigarettes and they live longer then we do!
I think McDonalds is doing us more harm than RJReynolds. We should have a "fast food sin tax". [Patriot]
#191791 - 05/19/06 05:52 PM Re: benefits of 20w50?
TallPaul Offline
Loc: By Detroit
Unless you are experiencing low oil pressure, stay with the 10w30. I would go with a robust 10w30 like high mileage. If pressure is somewhat low you could run a 10w40, but if you need 20w50 the engine is probably in pretty bad shape.
#191792 - 05/19/06 06:08 PM Re: benefits of 20w50?
toocrazy2yoo Offline
Loc: Herndon, Virginia
Jay if you owned it since new, keep running the 30W, 5W or 10W. This thing burning oil, or something? Sludge under the oil cap? Jeez, 90K is nothing assuming of course, good practices were followed. Run a 5W20 with a 1.5 oz. dose of VSOT, and you should be spot-on! 90K is just getting warmed up though, you're almost broken in, should be no need for 20W50!
[Off Topic!] [Off Topic!]
The Japanese (and pretty much the entire Asian continent) eat a lot of fish, veggies and rice. The average Asian finds all of our fare here too heavy with meats, fats, and sugar. They do smoke like chimneys, and with the diet, you rarely see overweight Asian folks other than Sumos. Fat will kill you quicker.
Fat slows you down throughout your life..The smokes merely keep a 65 year old from reaching 75, 85, and beyond). Ya can't live forever, right?
#191793 - 05/19/06 08:14 PM Re: benefits of 20w50?
Iain Offline
Loc: US/UK
[No no]
[No no]
I run Mobil 1 5W-20 in my Gen4 Taurus and it loves it.
You may want to consider Redline 5W-20. It's generally considered a thicker oil. Based on it's HTHS rating, some might even say it's a thin 5W-30.
#191794 - 05/19/06 08:20 PM Re: benefits of 20w50?
MIAMI-DADE Offline
Loc: Florida
I tried 20w50 in my 88 Town Car awhile back when i had it.It sounded like a really broken washing machine till it got warmed up.Went back to 10w30 and all was well on 10w30 till i sold it at 200k miles.
#191795 - 05/19/06 08:23 PM Re: benefits of 20w50?
Auto-Union Offline
Loc: NEPA
Casrtol GTX Hi-Miles, 5w-30.
#191796 - 05/19/06 08:52 PM Re: benefits of 20w50?
Dominik Offline
Loc: Brampton, Ontario, Canada
Well I used M1 15W-50 in my '95 Saab 900 NA and I had noticed absolutelly no difference in power once the engine reaches its normal temperature then the difference between VIS of say ~11 for W30 and ~18 for W50 should not be detectable. Granted during first few minutes after start up you will hear the difference especially with dinos but later I think not.
I also used it once in my papa's Altima with the 2.5 litre 4cyl. engine rum much quieter but start up was a bit harder, had to crank it just a bit longer but again no sluggishness and quiet running.
P.S.
The difference in viscosity between 15W-40 HDEOs
and 20W-50 PCMOs is only 2-3 centistokes plus 20W/50s are likely to shear a bit more than 15W-40s so a thousand miles or so into OCI you might end up with the same vicosity oleum in your crank case yet HDEO are being praised (I know mostly for their robust addpack and stability). I think in hot climates and for short periods of time i.e. dot live it in untill cold morning are gonna make it hard to start 20W-50 might give you the protection you need.
Now the thin oil crowd will take care of me [Dual]
#191797 - 05/19/06 08:56 PM Re: benefits of 20w50?
BrianWC Offline
Loc: Louisiana
I may be tone deaf or something but I've never been able to hear a difference between 15W50 and 0W20.
#191798 - 05/20/06 09:03 AM Re: benefits of 20w50?
Dominik Offline
A lot of engines will run a bit quieter on say one type of 10W-30 oil a opposed to onother 10W-30 this fact is well documented here on this forum now running an oil that is much thicker like 20W-50 or HDEO 15W-40 might even heighten such an auditory experience, this fact has also been well documented on this forum.
Like I said the thin crowd has got me in their cross hairs already.
Anyone from OZ please like help and stuff [SPAZ!]
#191799 - 05/19/06 10:33 PM Re: benefits of 20w50?
Norm Olt Offline
Loc: Pac NW
Hows about mixing a couple of quarts of 10W-30 and a couple of quarts of 15W-40, i.e., Chevron Supreme & Delo vs. going to the 20W-50?
I use this 50/50 mix in my '73 450SE with no problems, oil pressure is good, etc.
#191800 - 05/19/06 10:41 PM Re: benefits of 20w50?
427Z06 Offline
Loc: Austin, TX
quote:
Originally posted by Dominik:
A lot of engines will run a bit quieter on say one type of 10W-30 oil a opposed to onother 10W-30 this fact is well documented here on this forum...
The only FACT that's well documented here is that SOME people perceive a difference, NOT that it is actually quieter. Further, it has yet to be established that this perceived difference in any way effects the wear in an engine.
[ May 20, 2006, 01:58 PM: Message edited by: 427Z06 ]
