Accord door lock issue....
by gregk24
07/31/16 12:26 AM
2000 Corolla vvt-i rattle on startup?
by 55Test
07/30/16 11:24 PM
Brought home a beater today
by exranger06
07/30/16 11:03 PM
Can someone explain to me the nomenclature of ammo
by Vern_in_IL
07/30/16 10:52 PM
Common for bad shift solenoids to shift good warm?
by DemoFly
07/30/16 09:50 PM
Riding mower with non bearing front wheels
by JHZR2
07/30/16 09:17 PM
Mail popup
by Eddie
07/30/16 09:05 PM
Tundra headlight restoration..
by kenwin30
07/30/16 09:00 PM
High mileage and severe service...
by OneEyeJack
07/30/16 08:44 PM
Who uses Quicksilver Multi-purpose oil
by BrocLuno
07/30/16 08:07 PM
Gumout Q&A with Ryan Tuerck - Answers
by wwillson
07/30/16 07:37 PM
Friend Picked Up New 2017 Hyundai Santa Fe Today
by crazyoildude
07/30/16 07:07 PM
danthemann, rodder98, kenb777, Indyfan3, RM53119
58651 Registered Users
22 registered (alcyon, DevilsRule, Chris B., bdcardinal, bamorris2, Blkstanger, 1 invisible), 720 Guests and 5 Spiders online.
58651 Members
66 Forums
252471 Topics
Page 1 of 3 1 2 3 >
#1903240 - 05/26/10 10:47 AM Best Additive to reduce oil consumption?
Honda2003 Offline
Loc: Arkansas
I have a 2001 GMC extended cab Z71 with the 5.3 Vortec. I bought it new and have ran Valvoline 10w-30 till 75,000 miles then switched to Valvoline Max Life 10w-30. It holds 6qts and I replace 1qt with Lucas Oil Stabilizer every oil change. I got 175,000 mile on it now and its using a little oil now around 1 or more quart's between oil changes. I run it with and without the stabilizer and no difference in the oil consumption. Is there a better additive to help that I should try? Should I change oil brand? Any input is appreciated. Thanks!
2001 GMC Extended Cab 5.3L Mobil Super Extended Mileage 5-30
2013 Ford Edge Limited Motor Craft Syn
2007 Honda R 4x4 GN4 10W-30
#1903247 - 05/26/10 10:55 AM Re: Best Additive to reduce oil consumption? [Re: Honda2003]
Billbert Offline
Loc: California
First off, ditch the Oil Stabilizer. The only thing it is stabilizing is Lucas' income.
If you think you can, or if you think you can't, You are probably right.
Auto Instructor / ASE Master Tech
#1903248 - 05/26/10 10:55 AM Re: Best Additive to reduce oil consumption? [Re: Honda2003]
SubyRoo Offline
Loc: Maryville, TN
I for one would'nt ruin a good oil with Lucas unless its noisy and you want to sell it fast. Especially since the extra thickness obviously isnt helping consumption.
1999 Acura Integra GS-R
#1903250 - 05/26/10 10:57 AM Re: Best Additive to reduce oil consumption? [Re: Honda2003]
d00df00d Offline
Loc: PA
First, check your PCV system. Replace anything that looks at you funny.
Then, run the MaxLife straight with no additive for at least 2-3 oil changes and see if the consumption settles out.
As far as I can tell, Lucas Oil Stabilizer is pretty much bunk; the only thing it's good for is making a busted engine appear trouble-free just long enough for you to sell it. If it makes no difference to you, that's all the more reason to stop using it whatever happens.
2011 Mazda RX-8 R3
Castrol GTX 5w-20
#1903255 - 05/26/10 11:00 AM Re: Best Additive to reduce oil consumption? [Re: Honda2003]
Honda2003 Offline
Loc: Arkansas
It wont hurt my feelings any to ditch the Stabilizer it will cut over $10 off my oil changes. I initially started running the Lucas because when my truck hit 20,000 miles it has this horrible knock on start up worse when cold. I been told this is normal with this truck but drives me crazy. The Lucas seem to help some but not much. Thanks
#1903261 - 05/26/10 11:04 AM Re: Best Additive to reduce oil consumption? [Re: d00df00d]
Honda2003 Offline
Loc: Arkansas
I've cleaned the PCV Valve its the one without the shaker its just straight through. Its been all nasty before but its all good now and has been for a while.
#1903264 - 05/26/10 11:05 AM Re: Best Additive to reduce oil consumption? [Re: Honda2003]
Johnny Offline
Loc: Retired | Wausau, WI
If you have been using the Lucas Stabilizer since 20,000 miles you probably have some stuck piston rings causing the oil consumption. You might need to do some gentle cleaning to help free up the rings.
#1903267 - 05/26/10 11:07 AM Re: Best Additive to reduce oil consumption? [Re: Johnny]
d00df00d Offline
Loc: PA
Good point. Time for some AutoRX maybe? smile2
2011 Mazda RX-8 R3
Castrol GTX 5w-20
#1903274 - 05/26/10 11:13 AM Re: Best Additive to reduce oil consumption? [Re: Johnny]
Honda2003 Offline
Loc: Arkansas
I first started using the Valvoline oil additive in the little red bottle then switched to the Lucas because they discontinued the Valvoline. How do I need to clean? I just changed my oil yesterday. Thanks for the info.
#1903279 - 05/26/10 11:16 AM Re: Best Additive to reduce oil consumption? [Re: d00df00d]
CourierDriver Offline
Loc: Tn.
use an HDEO 5w40 t6 rotella or 15w40rotella triple protection and see if u oil usuage stops, it did for me, and go 8000 miles now on T6 synthetic shell rotella, before adding oil.
If I told you to invest in something that would cost $24k,go down in value,cost over $2K a year to operate,you would say Im crazy,,,got a car??
#1903284 - 05/26/10 11:19 AM Re: Best Additive to reduce oil consumption? [Re: d00df00d]
scurvy Offline
Loc: Chicago IL USA
Best 'additive' for an oil-burning engine would be whatever 15w40 HDEO is on sale. You can try ARX or MMO or [censored] or BBQ to free stuck rings, but 1 quart/OCI isn't terrible. The high detergent HDEO may help free rings as well. Shouldn't have any issues in the summer with it, especially in hot & humid Arkansas.
My Golf & NB typically use 0.75 - 1 liter per OCI... but they often go 20k km [12k miles] or more between oil changes.
You are entitled to your own opinion but not your own facts.
06 VW Golf TDI: Schaeffer 9k 5w40, HU726/2x, EaBP90
12 Mazda 5: Amsoil SSO 0w20, FL910S
#1903298 - 05/26/10 11:29 AM Re: Best Additive to reduce oil consumption? [Re: CourierDriver]
Trav Offline
Loc: MA, Mittelfranken.de
Why don't you try a dino 10w-30 along with a qt of MMO for 1 OCI to get those rings unstuck.If things get better then go to PZ Ultra 5-w30 to keep it that way.75K isn't high mileage,you probably stuck the rings up with that stuff.
#1903302 - 05/26/10 11:32 AM Re: Best Additive to reduce oil consumption? [Re: Trav]
Johnny Offline
Trav, he has 175,000 on the truck now.
#1903303 - 05/26/10 11:33 AM Re: Best Additive to reduce oil consumption? [Re: Johnny]
Chris142 Offline
Loc: apple valley, ca
x2.
02 Wrangler Chevron 10w30
87 F250 napa 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#1903309 - 05/26/10 11:37 AM Re: Best Additive to reduce oil consumption? [Re: Johnny]
Trav Offline
Oh boy getting old is bad for the eyes,thanks for pointing that out Johnny.
Still i think MMO my be of some benefit in a HMO for getting some junk out of the rings.
Page 1 of 3 1 2 3 >
