Originally Posted By: RF Overlord
nitehawk, if you have a V6 then you have the Aisin F-21 6-speed, not the FNR5. The F-21 takes Motorcraft Premium Automatic Transmission Fluid, which is actually Mobil 3309 aka Toyota T-IV. My niece has the same car and I did 2 back-to-back drain & fills with T-IV at 30,000 because it was already starting to turn dark. The F21 takes just under 4 quarts for a drain & fill and DOES have a drain plug.
Sorry bout that , yes it is the 6 speed , not the 5 plus it's AWD . Done so much reading on the internet before I did I got myself confusioned .
I talked to the dealer about the location of the drain plug and be darned if I could find it . Saw what I thought might be the drain plug but I was worried if it wasn't I might cause an issue so I went with the pop the line off method which worked fine .
Yea that oil does get dark and it reall didn't smell burnt but I felt better getting most of it out of there .
Wife is the driver of that car and says she thinks it's shifting smoother now . The Amsoil meets the T-IV spec too for the Aisin .
