Inner Tie-rod removal
by Sawdusted
02/06/16 09:54 PM
What's a good price for a 2013 4Runner?
by Gebo
02/06/16 09:34 PM
Chrysler 42LE - avoid synthetic gear lubes
by Wampahoofus
02/06/16 09:15 PM
Nose mask (car bra) tab repair
by aquariuscsm
02/06/16 08:53 PM
Eye Watering HeadCold ! Help!
by SumpChump
02/06/16 08:43 PM
Dean tires?
by Corollaman
02/06/16 08:32 PM
Discount Tire Direct Presidents Day Sale
by sopususer
02/06/16 08:21 PM
New CarQuest R85372-A43301 cut open
by WellOiled
02/06/16 08:11 PM
Pennzoil Ultra old SN formula.....
by mv6845
02/06/16 08:07 PM
80 Hypoid?
by ledslinger
02/06/16 07:46 PM
Whatever happened to Meyer's invention?
by OneEyeJack
02/06/16 07:07 PM
window tinting
by crestwood
02/06/16 07:05 PM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
88 registered (01_celica_gt, 77GrandPrix, 2015_PSD, 69GTX, 5 invisible), 1268 Guests and 192 Spiders online.
56834 Members
66 Forums
244338 Topics
Page 1 of 2 1 2 >
#1895769 - 05/19/10 12:10 AM Riding Mower Battery- How long do they last?
Happy Birthday Robenstein Offline
Loc: Central IA
Bought one for my Tecumseh powered MTD and it has lasted 23 months. I hook a maintenance charger up to it regularly. Warranty says it has a one year warranty. Is it normal for one to die that early?
2011 Triumph Speedmaster
1986 Chevy Monte Carlo SS
1970 Chevy Nova
2006 Scion TC
#1895770 - 05/19/10 12:11 AM Re: Riding Mower Battery- How long do they last? [Re: Robenstein]
Loc: Central IA
Its a Super Start from O Reillys btw. Is there a better brand out there. The clerk mentioned its made by Interstate.
1970 Chevy Nova
2006 Scion TC
#1895821 - 05/19/10 03:50 AM Re: Riding Mower Battery- How long do they last? [Re: Robenstein]
WishIhadatruck Offline
Loc: Grand Rapids, MI
The only rider I've ever owned is my JD lawn tractor that I bought new in 2002. The only time I've ever touched the battery was when I moved it out of the way a few years ago to lube the steering gear. It still works good. It just sits in the tractor unused in my shed during the winter except for the few times I might turn the headlights on to light up the shed. I definitely should take better care of it, I can't believe it keeps working so well.
1996 Buick Roadmaster Wagon
2014 Cruze Eco Manual
2003 2500 Suburban, 8.1L
#1895823 - 05/19/10 04:04 AM Re: Riding Mower Battery- How long do they last? [Re: Robenstein]
Garak Offline
Loc: Regina, Saskatchewan, Canada
I don't know if it's normal. Mine did the same thing (same brand and everything), however, with the same type of care. I never let it freeze or die, and as I recall, it lasted a couple months shorter than yours did.
Mine didn't die a slow, lingering death. It was rather sudden. How was yours?
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#1895832 - 05/19/10 05:05 AM Re: Riding Mower Battery- How long do they last? [Re: Garak]
Loc: Central IA
It was pretty sudden. It started like it was running low, cranking the engine slowly. The next time nothing. I hooked a booster pack up to get it going. My maintenance charger says its charged but has no juice. I tried cleaning the cable just in case that was the issue.....nope.
1970 Chevy Nova
2006 Scion TC
#1895854 - 05/19/10 06:31 AM Re: Riding Mower Battery- How long do they last? [Re: Robenstein]
Garak Offline
Well, I guess we were in the same boat. Same brands, similar conditions, and same failure. I charged it one day at a low amperage. It showed fully charged. Next day, I went to use it, dead as a doornail.
#1895883 - 05/19/10 07:38 AM Re: Riding Mower Battery- How long do they last? [Re: Robenstein]
daman Offline
Loc: Bad Axe, MI
Sounds like your maintenance charger is junk,you need to use a "float" charger one that turns it's self off then on as voltage is needed.
you should have gotten longer service then that.
"Always"....Mobil 1
Current fill: AFE 0w30
#1895943 - 05/19/10 08:52 AM Re: Riding Mower Battery- How long do they last? [Re: Robenstein]
Hitzy Offline
Loc: Ottawa, Canada
Mine went the same way, about the same life....a little over 2 years. Says charged, but will barely turn it over.
Picked one up from carquest last week for $20, made in the USA, works great so far, cranks it over easily.
#1896245 - 05/19/10 01:06 PM Re: Riding Mower Battery- How long do they last? [Re: daman]
Loc: Central IA
Nope it turns off and on as well. Yellow when charging and green when charged and on standby. I used it just the other day to charge up my wifes battery when she left her lights on by mistake.
1970 Chevy Nova
2006 Scion TC
#1896293 - 05/19/10 01:39 PM Re: Riding Mower Battery- How long do they last? [Re: Robenstein]
TurboLuver Offline
Loc: SW Ohio
I am going on my third year with a battery I picked up at AAP, it stays hooked up to a battery tender all winter. The battery in my JD was 10 years old when I replaced it(no battery tender), replaced it with another JD battery, kinda pricey though.
#1897164 - 05/20/10 07:55 AM Re: Riding Mower Battery- How long do they last? [Re: TurboLuver]
deeter16317 Offline
Loc: SE, PA
The L&G batteries don't last that long in my experience..typically two years is all I see. I have a couple tractors that use full-size car batteries, and they last tens of years...I always assumed it was because it was of better construction?
Make sure your charging system on the equipment is operational...sometimes those solid state voltage regulators go bad and overcharge. I had one fail on a Gravely, and it was putting 19 volts out before it finally just quit charging.
2004.5 Dodge 2500 Cummins
#1897566 - 05/20/10 01:41 PM Re: Riding Mower Battery- How long do they last? [Re: deeter16317]
Bear Offline
Loc: Rochester, NY area
I had a Walmart battery last 6 years. The current one is only two seasons old. My only grip is they eliminated the carry handle - the bastages!!!
2014 Ford F150 4X XLT
2008 Honda CRV
#1899223 - 05/21/10 10:23 PM Re: Riding Mower Battery- How long do they last? [Re: Bear]
Loc: Central IA
Well I think I foudn the culprit. It was leaking acid. I have some spray on cleaner/acid detector and when you spray it if the yellow turns pink or red you have an acid leak. It was leaking pretty good it turns out. When I pulled it, there is plenty of acid corrosion that was not there when I put it in.
Im going with the 19 buck wal mart one. No use in paying 8 bucks more for a battery that wont last.
1970 Chevy Nova
2006 Scion TC
#1899439 - 05/22/10 08:48 AM Re: Riding Mower Battery- How long do they last? [Re: Robenstein]
Tom NJ Offline
Loc: Virginia
I've been getting about 4-5 years out of my riding mower batteries with no charging or other maintenance. Would applying a charge over winter help the battery last longer? If so, can anyone recommend a cheap charger. Since I am paying less than $10/year for the battery, an expensive charger doesn't make much sense.
Tom NJ
#1899518 - 05/22/10 10:21 AM Re: Riding Mower Battery- How long do they last? [Re: Tom NJ]
Tdbo Offline
Loc: Ohio
I have been getting 3-4 years out of mine. The best was a Huskee (TSC) that went 4. However, I had another Huskee that went 2 years. The most that I ever got out of a JD battery (the last one cost me $46) was 2 years. I have gotten to the point any more that I simply go to Wally World and get the $19 special and replace it when it dies. It's cheaper and easier to do so and they last as long as anything else I've ever been able to find.
2012 Honda Accord LX-P 78K
2008 Ford Mustang Pony Package Convertible 13K
2006 Honda Odyssey EX-L 72K
2003 Ford Ranger 3.0 Supercab 88K
Page 1 of 2 1 2 >
