For Sale: 2004 Ram 1500
by RamFan
Today at 02:10 PM
2005 Volvo S40 2.4i - Optimal Oil Choice?
by mgm7890
Today at 12:58 PM
Something for a quiet Saturday, vapors...
by OneEyeJack
Today at 12:33 PM
Ford guys: Crown Vic windshield washer not working
by Jimmy9190
Today at 12:08 PM
Very cold outside, vehicle sitting for a few day's
by 07titan
Today at 11:26 AM
compression fittings and fuel starvation
by eljefino
Today at 10:47 AM
Anyone here make a homemade jump starter pack?
by skyactiv
Today at 10:31 AM
API *SL* Oil Still on Shelf
by CrackyWainwright
Today at 10:17 AM
Jeep "shudders" at 35-40 mph
by Joe_Power
Today at 09:27 AM
How Often to Drain and Refill AT's?
by Gebo
Today at 09:18 AM
Gas water heaters
by spasm3
Today at 08:59 AM
Woman killed by flying manhole cover in Boston
by Mr Nice
Today at 08:56 AM
Formula413, Cruzingoose, klob, beaglefet, bsmith3
56907 Registered Users
94 registered (901Memphis, Andy636, 3800Series, 1989outlaw, Abakev, amerendino, 6 invisible), 1819 Guests and 109 Spiders online.
56907 Members
66 Forums
244646 Topics
#1889203 - 05/13/10 03:44 AM Gas treatment in 2-stroke engine?
Popinski Offline
Loc: Ohio, USA
I put gas treatment in my fuel in my 2 gallon fuel jug for my 4-stroke lawnmowers and I need to make 1/2 gallon of 2-stroke oil/gas mix for my trimmer. Is it ok if I use my gas treatment/gasoline mix?
"It doesn't matter what religion you are in, who you pray for, what you believe in, because the only thing you worship is OIL".
#1889253 - 05/13/10 06:12 AM Re: Gas treatment in 2-stroke engine? [Re: Popinski]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
Most brands you will be OK, but others not. Ask the manufacturer of your fuel treatment.
What brand? What type? (stabilizer, cleaner, booster, UCL?)
#1889256 - 05/13/10 06:16 AM Re: Gas treatment in 2-stroke engine? [Re: Popinski]
Oil_Can_Harry Offline
Loc: Maryland, USA
I use a mixture of FP60 and Schaeffer's Neutra in my 2 cycle fuel and straight gasoline for my outdoor power equipment and my OPE runs like a champ. I've stored fuel up to two years without a problem and the gas smells as fresh as the day I pumped it.
With ethanol now the norm, I would be afraid to store any fuel without some kind of stabilizer or conditioner added.
2000 Toyota Tundra reg cab SR5 V8
2009 Mercury Grand Marquis LS
#1889287 - 05/13/10 07:04 AM Re: Gas treatment in 2-stroke engine? [Re: Oil_Can_Harry]
Cmarti Offline
Loc: Ohio
I Treat all the gas in a 15 gallon container with Seafoam or MMO to stabilize it while in storage. I use this gas in 4 cycle equipment and I also draw from this container when I need to make my 2cycle mix at the oil's recommended ratio. No problems in 20 years.
I have never had carbon buildup in 2cycle equipment, but that may be due to using quality oil and correct carb settings.
#1889465 - 05/13/10 10:50 AM Re: Gas treatment in 2-stroke engine? [Re: Popinski]
boraticus Offline
Loc: Canada
How much fuel treatment did you put in the original 2 gallon container?
I regularly add Seafoam to my straight gasoline then use it to mix two stroke fuel. No bid deal. You'd have to put a lot, I mean like around a quart of fuel treatment into two gallons of fuel to have any effect on a two cycle engine. Even then, I doubt that it would have any detrimental effects.
My Echo equipment have approx. 10 oz. fuel tanks. Once a year I'll run an oz. of Seafoam in with a tank of fuel. Never had a problem. That's a 10% mix of fuel treatment to fuel. If your mix is less than that, I certainly wouldn't be sweating it.
I've never read nor heard of a fuel treatment causing problems if used anywhere near it recommended proportions.
I've read of some people having problems with Stabil going bad and had a half bottle or so of it change colour and go into an almost jelly state once. Hence the use of Seafoam now.
#1889661 - 05/13/10 02:18 PM Re: Gas treatment in 2-stroke engine? [Re: boraticus]
kcfx4 Offline
Loc: indiana
most high quality oem(husqvarna, etc) oil has stabilizer right in their little jug. and since your not affecting the ratio at all (way your doing it) it would not be a problem what-so-ever
If it has an engine, but not a blue oval or yellow deere, i probably dont own it
#1889850 - 05/13/10 05:53 PM Re: Gas treatment in 2-stroke engine? [Re: kcfx4]
Brett Miller Offline
Loc: Arizona
I always put a little Stabil in my 2 cycle mix. I've never had a problem.
#1890192 - 05/14/10 02:22 AM Re: Gas treatment in 2-stroke engine? [Re: Pablo]
Popinski Offline
Loc: Ohio, USA
Gumout complete fuel system cleaner.
#1890273 - 05/14/10 06:59 AM Re: Gas treatment in 2-stroke engine? [Re: Popinski]
Deltona_Dave Offline
Loc: Deltona, FL USA
Gumout should be okay. I made the mistake of using Techron and was told it was not recommended for 2-stroke air cooled engines. Did not seem to harm them. I have used Sta-bil, seafoam, and am going to try mmo. My main concern nowdays is E10 gas dissolving the carburetor gaskets on OPE.
Dave
Emergency Vehicle Technician Law Enforcement
2013 Hyundai Sonata GLS 2.4
2013 Kia Optima EX 2.4
2012 Mazda3 2.0 SkyActiv
