Jury Duty
by dishdude
08/29/16 12:42 AM
Mercon LV or MaxLife
by buck91
08/28/16 11:46 PM
VW Electric Plans
by Y_K
08/28/16 10:49 PM
Oil Recommendation for Nissan 3.5 V6 113,000 miles
by BlueSmoke16
08/28/16 10:10 PM
Sticky Ear Question - Speak Up!
by Ducked
08/28/16 10:07 PM
House hunting follies
by Jarlaxle
08/28/16 09:36 PM
Goodbye, Stubby
by Inspecktor
08/28/16 09:35 PM
Undercarriage
by jay929
08/28/16 09:31 PM
$1200 Cabela's Gift Card For Sale- Louisville, KY
by FirstNissan
08/28/16 08:37 PM
Motor oil recommendations, '04 Toyota Sequoia
by ShadowSix
08/28/16 08:21 PM
Quick Question About Car Battery Quality And Price
by crazyoildude
08/28/16 07:44 PM
Shelf Life of Gas Stabilizer.
by George7941
08/28/16 07:34 PM
gioburk, turrican, GGilbert, leje0306, DLL
58951 Registered Users
30 registered (bbhero, DemoFly, DeafBrad, c502cid, asiancivicmaniac, 3 invisible), 754 Guests and 12 Spiders online.
58951 Members
66 Forums
253707 Topics
Page 1 of 2 1 2 >
#1871027 - 04/25/10 09:43 PM Parasitic draw test
JHZR2 Offline
Loc: New Jersey
Hello,
Which way do you test for parasitic draw, ammeter between the negative cable and battery terminal or positive cable and terminal?
I always thought it was on the + side, as all current must originate there, but I figure that based upon resistances, dissipation as heat, etc., not all has to return to the negative.
Yet Ive heard elsewhere to do it on the negative side.
Does it matter? Is one way better than the other?
#1871042 - 04/25/10 09:54 PM Re: Parasitic draw test [Re: JHZR2]
tom slick Offline
Loc: Central Coast, Calif.
Do both and see if there IS any difference
You get what you pay for...
So keep in mind how much you paid for this advice.
#1871055 - 04/25/10 10:00 PM Re: Parasitic draw test [Re: tom slick]
JHZR2 Offline
Loc: New Jersey
I will, but it is pouring here for the next few days...
#1871060 - 04/25/10 10:04 PM Re: Parasitic draw test [Re: JHZR2]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
I've always done it on the + side. No deep thought really, just figured if juice is leaking.....
#1871076 - 04/25/10 10:17 PM Re: Parasitic draw test [Re: Pablo]
brianl703 Offline
Loc: Manassas, VA
It does not matter. The readings will be the same on either side of the battery, so long as you connect the meter with the correct polarity. If you do not the digital meter will indicate a negative reading with a - sign. You could ignore that - sign, as surely the vehicle is not charging the battery when the engine is running.
#1871083 - 04/25/10 10:30 PM Re: Parasitic draw test [Re: brianl703]
J. A. Rizzo Offline
Loc: Chicago, IL
It's really the negative terminal where the current comes from. Current is moving electrons, and electrons are negatively charged. So the negative terminal is where all the electrons are congregated, waiting to flow over to the positive terminal. I know, it's opposite what you'd think, but in reality, the negative terminal blows and the positive terminal sucks.
Tradition is nothing but an excuse to not be creative.
#1871085 - 04/25/10 10:34 PM Re: Parasitic draw test [Re: brianl703]
JimPghPA Offline
Loc: Pittsburgh,PA U.S.A.
I think instead of "as surely the vehicle is not charging the battery when the engine is running." You wanted to say "as surely the vehicle is not charging the battery when the engine is NOT running."
Edited by JimPghPA (04/25/10 10:34 PM)
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
#1871096 - 04/25/10 10:43 PM Re: Parasitic draw test [Re: JHZR2]
XS650 Offline
Loc: Northern CA
When you hook your meter between the battery and the cable, it's a good idea to put a jumper in parallel with the meter and leave it connected for a few seconds after you connect the battery. Some cars draw many amps briefly after you connect the power.
Fortunately the fuse in my ammeter protected the meter when I learned that.
Whenever you find yourself on the side of the majority, it is time to pause and reflect.
--Mark Twain
#1871098 - 04/25/10 10:43 PM Re: Parasitic draw test [Re: JimPghPA]
brianl703 Offline
Loc: Manassas, VA
You are correct, I omitted the "NOT"!
#1871208 - 04/26/10 12:39 AM Re: Parasitic draw test [Re: brianl703]
Shannow Offline
Loc: Oz
Yep, what comes out must go in, or it doesn't come out in the first place.
Was messing around with exactly this on the E30 the other day.
0.8 Amps for quite some time until everything goes into sleep mode, then less than 20mA when it's asleep.
Apparently 12 min commute isn't enough for a flat battery to recover, so I disconnected the -ve at each end of the trip until it was happy again...that's how I found out my commute is exactly 12 minutes.
2003 Navara 3.0Di - Edge 5W30/25W50
1997 Caprice L67 - Magnatec Stop Start 10W30
#1871427 - 04/26/10 09:13 AM Re: Parasitic draw test [Re: Shannow]
Vikas Offline
Loc: NorthEast
Do it on the negative side because that is the one which is removed first
#1871914 - 04/26/10 03:26 PM Re: Parasitic draw test [Re: Shannow]
mechtech2 Offline
Loc: Chicago Area
Either side should read the same.
But sometimes there is more than one ground .
Putting your meter in series on only one would show a difference from a single '+' lead.
#1872250 - 04/26/10 08:41 PM Re: Parasitic draw test [Re: mechtech2]
JHZR2 Offline
Loc: New Jersey
That was kind of my thought. Multiple grounds, different resistances back to the battery terminal, etc. may make some difference in practical terms. Measuring off the positive terminal as the origination of all current means it is all accounted for.
#1872290 - 04/26/10 09:27 PM Re: Parasitic draw test [Re: JHZR2]
Shannow Offline
Loc: Oz
If there's a single terminal connected to the battery, that's where all the juice collects.
Positive and negative have to match if there's nothing else on the post.
#1872343 - 04/26/10 10:23 PM Re: Parasitic draw test [Re: Shannow]
Rabbler Offline
Loc: Canada
It shouldn't matter but I always do it on the Negative. Draw should be less than 90 ma once all the controllers have timed out. Make sure you disable under hood light if equipped.
Page 1 of 2 1 2 >
