Mobil 1 jug sale at Meijer 2 day sale
by a1mfw
07/28/16 07:08 PM
Win 10 Problem
by GrtArtiste
07/28/16 07:06 PM
AC Shrader valve removal tool
by chiefsfan1
07/28/16 05:54 PM
Fuel pumps in carb engines
by Donald
07/28/16 05:40 PM
Changing Automatic Transmission Fluid
by Cristobal
07/28/16 05:26 PM
DELO 5W40 Synthetic UOA ?
by alanwayne1908
07/28/16 05:03 PM
DELO 5W40 Synthetic
by alanwayne1908
07/28/16 05:01 PM
93 J30t...worth it or not?
by Lolvoguy
07/28/16 04:56 PM
Chevron Supreme $2.29 Fred Meyer
by sprite1741
07/28/16 04:37 PM
Would you let a teenager house sit?
by VeeDubb
07/28/16 04:32 PM
FYI Dollar General has windshield fluid for $1 gal
by Rat407
07/28/16 03:54 PM
Got my Micro Green oil filter in from the 50% sale
by PolarisX
07/28/16 03:45 PM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
107 registered (alanwayne1908, a1mfw, aquariuscsm, AlaskaMike, 2165, 2015_PSD, 6 invisible), 1862 Guests and 11 Spiders online.
58632 Members
66 Forums
252368 Topics
#1868508 - 04/23/10 03:34 PM dexos1
C2H5OH Offline
Loc: California
THE NEW DEXOS OIL – WHEN & WHERE WILL YOU USE IT?
GM’s new Global Engine Oil Standard for gasoline engines is “dexos1”. It will be factory for all GM vehicles starting with the 2011 model introduction. It replaces current GM oil service ratings on a global basis and will therefore become the recommended oil for most GM vehicles in North America.
Oil companies are already trying to limit interest in this higher quality oil standard. It may be a coincidence but oil sales reps appear to be aggressively soliciting long term contracts with shops before ILSAC GF-5 and dexos1 are introduced. It’s clear that most oil companies prefer that you use the lower standard ILSAC GF-5 products in EVERY car. In my opinion, these long term contracts are designed to discourage any shift to the higher quality (and less desirable for the oil company) dexos1 approval.
Oil companies have a significant history of encouraging shop owners, technicians and consumers to ignore OEM proprietary oil service rating in favor of the less stringent American Petroleum Institute (API) and International Lubricant Standards and Approval Committee (ILSAC) service ratings. Most oil companies will make a dexos1 approved product. But, it will be more convenient and they believe more profitable for them to sell the cheaper ILSAC approved products. Some niche marketers will continue to sell products that are not approved by anyone (and promote them as premium products).
This is an ideal time to avoid any long term oil purchase contracts! Dexos, API/ILSAC and ACEA are all introducing new oil service ratings before the end of this year. Other existing oil service ratings like VW 504/507 will also start to have a much bigger impact on independent shops during the same time period. It is essential that shop owners retain the freedom to rapidly change oil purchasing strategies and vendors during this period of transition.
Of all the upcoming changes, GM dexos1 will, in my opinion, be the most important for independent shop owners. It will replace both GM 6094M and GM 4718M. But, its positive impact should go far beyond GM cars and the shops that service those GM cars.
GM dexos1 will solve the following problems that are poised to create huge difficulties for all shop owners.
• The term “Synthetic” is meaningless in North America. - Shop owners and consumers alike assume that this term indicates superior quality. But, it is increasingly used as nothing more than a ploy to lure un-educated buyers into products that inflate oil company profits without a corresponding benefit to the consumer. This could result in a compromised reputation and liability for the shop owner. The GM dexos1 approval will offer assurance of the type of quality that is expected of a “synthetic” product. Informed shop owners will ignore the term “synthetic” and look for dexos1 approval instead.
• Consumers and shop owners do not recognize a difference between low HTHS and high HTHS oil products. - The desire for “better” oil products is driving consumers and shop owners to inadvertently select high HTHS oil products for low HTHS applications. The oil companies desires to offer ILSAC approved products of perceived higher quality has resulted in low HTHS “synthetic” products being used in high HTHS applications. This has already resulted many cases of serious engine damage and shop liability. GM dexos1 and dexos2 approvals should help identify the difference between high HTHS and low HTHS products.
• Oil requirements are often compromised for the North American Market. -Volvo, Jaguar and Land Rover all reduce their oil service rating requirements for vehicles marketed in North America. The availability of cost effective ACEA A1/B1 approved oil products is extremely limited in North America. GM dexos1 promises to be very cost effective and surpass ACEA A1/B1 and similar low HTHS requirements. It should be ideal for these European import low HTHS applications as well as GM applications. It will also serve as the most sensible upgrade for other American and Asian applications.
• Consumers desire longer drain intervals and fuel efficiency. - Long drain intervals are hard to achieve with XW-20 and XW-20 is still not appropriate for many cars. GM dexos1 approval appears to assure the best combination of fuel efficiency and extended drain potential in a low HTHS XW-30 or XW-20 oil product.
The new GM dexos approvals will help solve a lot of problems for informed shop owners. And, they will bring attention to a serious developing problem that many shop owners aren’t currently aware of. That is the increasingly common engine damage caused by using low HTHS SAE 5W-30 oil products in high HTHS SAE 5W-30 applications. In fact, dexos1 should draw attention to all modern oil service ratings (ACEA, Proprietary, HTHS, etc).
To take advantage of the opportunities that dexos1 represents, shop owners will need to retain the flexibility to adjust their oil purchasing patterns. When oil reps call on you, the first thing you should do is ask: “do you have a dexos1 approved product?” Until they can answer yes to that question, any discussion of oil purchase contracts is premature!
Kevin S. McCartney is an industry leader in automotive cooling and lubrication training programs and educational materials. He has also worked in the research and development of alternative fuels, emission inspection programs and hybrid electric vehicles. He can be contacted at 209-873-1155 or [email protected]
Copyright 2010 Kevin S. McCartney [email protected] 209-873-1155
All rights reserved – Do not copy, duplicate or distribute without permission
#1868725 - 04/23/10 08:04 PM Re: dexos1 [Re: C2H5OH]
Papa Bear Online   content
Loc: Leamington, ON, Canada ..... r...
What does that last line say ?? .....
I never was too bright - now old age and forgetfulness complicate things as well" crazy
2016 Dodge GC deep cherry CVP drive
#1868739 - 04/23/10 08:14 PM Re: dexos1 [Re: Papa Bear]
JHZR2 Offline
Loc: New Jersey
I believe the poster is the author actually.
