Dope smoking genius Laremy Tunsil NFL Draft Pick!
by GiveMeAVowel
04/29/16 09:50 PM
'13 Honda VFR1200 Motul 10w-50, 5,300 miles.
by montero1
04/29/16 09:35 PM
Anyone Using Spline Sockets?
by JHZR2
04/29/16 09:33 PM
Anyone Tryed Spectra Premium O2 Sensors?
by Mr_Accord
04/29/16 09:16 PM
UPS package tracking is so confusing!
by Klutch9
04/29/16 07:52 PM
Dupont non-stick lube
by buck91
04/29/16 07:47 PM
House electrical wiring question
by road_rascal
04/29/16 07:46 PM
Air pressure question
by aquariuscsm
04/29/16 07:43 PM
Fllow the DOT's
by WyrTwister
04/29/16 07:23 PM
Auto Rx?
by coopns
04/29/16 06:54 PM
Rotella for 6.0L Gasser
by Joefuskie
04/29/16 04:40 PM
Pennzoil Platinum Euro 5W-40
by 1JZ_E46
04/29/16 04:21 PM
Dmax7901, carver1, Handy7rick, sicilien, Crater_77
57738 Registered Users
81 registered (15SilvyEcotec, AirgunSavant, 06AllAmerican, alcyon, 2015_PSD, 9 invisible), 1353 Guests and 94 Spiders online.
57738 Members
66 Forums
248231 Topics
#1865233 - 04/20/10 09:18 PM Cub Cadet 2150 Rear Diff\Transmission Fluid
Vspec Offline
Loc: Pennslyvania
I have a Cub Cadet 2150 purchased around 1999.
It has over 300 hours of service, I'm doing my spring service and have such performed the following...
1. Fuel Filter
2. Air Filter w\pre-cleaner
3. Greased front wheel\front suspension grease points
4. Replaced Spark Plug
I'm going to be servicing the engine with a oil change w\filter.
However the transmission makes a high pitched whirring noise under load, and the shifter is very stiff to move. This unit does not have a filter, and I think some water, and dirt have made way into the rear differential via the dipstick...
I want to know if I can change the fluid safely, and what alternatives to the 100.00 dollars worth of Cub Cadet OEM fluid I can use.
I have no idea the fluid requirements, for viscosity, or ratings and my owners manual doesn't list anything specific, a quick google search didnt turn up much can anyone hear please make some recommendations.
Thanks!
2014 Ford Focus ST
#1865260 - 04/20/10 09:45 PM Re: Cub Cadet 2150 Rear Diff\Transmission Fluid [Re: Vspec]
LargeCarManX2 Offline
Loc: Up here in the NorthWest
I don't think many will answer this because the spec will need to be known to make a recommendation.
I have a 86 Cub Cadet and I use Farm type universal tractor gear/tranmission lube. It works like an hydralic oil, but it won't mush up when moisture rears it's ugly head.
Go read the spec off of the can of tranny/rear lube from Cub cadet.
"Success is the ability to go from one failure to another with no loss of enthusiasm."
Sir Winston Churchill
#1865423 - 04/21/10 05:44 AM Re: Cub Cadet 2150 Rear Diff\Transmission Fluid [Re: Vspec]
automated1 Offline
Loc: Houston,Pa
Found this on a Cub Cadet Discussion:
Per the spec page for the Cub Cadet Tank M48 KW, it uses dual Hydro-Gear PK-12 pumps and White wheel motors. Cub specs the oil as Rimula 15w40, like it does for all the Hydro-Gear equipped ZTRs commercial or residential. Any heavy-duty 15w40 engine oil will work perfectly in these units.
#1865425 - 04/21/10 05:49 AM Re: Cub Cadet 2150 Rear Diff\Transmission Fluid [Re: automated1]
automated1 Offline
Loc: Houston,Pa
People on the site said they have been using Shell Rotella T 15w-40 for all of the cub cadet hydro systems for quite a few years, none reporting any problems or any different function from the CC brand oil.
Hope this helps.
#1865513 - 04/21/10 08:09 AM Re: Cub Cadet 2150 Rear Diff\Transmission Fluid [Re: automated1]
Vspec Offline
Loc: Pennslyvania
Well [censored], thanks guys!
Shell Rotella T 15w-40 it is!
2014 Ford Focus ST
#1865606 - 04/21/10 09:20 AM Re: Cub Cadet 2150 Rear Diff\Transmission Fluid [Re: Vspec]
JTK Offline
Loc: Buffalo, NY
Originally Posted By: Vspec
However the transmission makes a high pitched whirring noise under load, and the shifter is very stiff to move. This unit does not have a filter...
You got me curious with those statements. Shifter? No filter? Does this unit have an "AG" designation somewhere near the "2150" logo? If so, this would be the Cub "Auto gear" transmission which is actually a heavy-duty (and rare) gear drive they had for a few years. You select a gear range with the fender shifter and mash the go pedal on the floor board instead of conventional clutch/shifting. The most common wear part on these transaxles is people wear the clutches out by feathering the go pedal as opposed to keeping it pressed full and regulating ground speed with the fender shifter. The AG trans spec'd the same oil as the hydro equipped units so yes, use the advice you quoted me on earlier. 15w40.
Joel
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#1868263 - 04/23/10 11:40 AM Re: Cub Cadet 2150 Rear Diff\Transmission Fluid [Re: JTK]
Vspec Offline
Loc: Pennslyvania
JTK, this mower does have the setup you are referencing.
Their is a gear selector that goes from N-1-2-3-4-5-6, with a go pedal on the same side.
I will be using Shell Rotella T 15w-40
2014 Ford Focus ST
